    1.3k Posts 300 Posters 3.1m Views 298 Watching
    • charly2008C
      charly2008
      This is a new milestone. I find this tool opens up new design possibilities. The loft tool works very well and easy to understand. Especially because the geometry of the forms can be calculated in advance. Thanks for this wonderful tool.
      The last image below is an almost perfect Moebius band. Unfortunately, the last segment is not closed.
      Moebius.skp
        This is already too impressive 👊
        • fredo6F
          Here is the Moebius ribbon with closure
          Moebius - curviloft.skp
          • H
            hgdn
            Fredo,
            Great impact for SU users in creating 3d models. With yours I am not afraid of creating 3d models from now on..still new!!! Easy and powerful plugins eventhough you give bug warnings but I have not seen any thing so far!!
            Genius and generous Fredo 😄
              Ruturaj
              Thank you Fredo Sir,
              you are great
              Many Many Many THANK you.
              I'm shocked man 😲
              This plugin is very helpful thank you.
              Thanks,
              RuturaJ
                @lapx said:
                I've tried it as well. Thanks Fredo for such a wonderful. Can you get it to maintain a sharp edge? I noticed it round the corners. Would be nice to have this as an option if available.
                These tools do work very well.... 💚
                The form is auto-smoothed ? You can always select the resultant group and right-click > soften, and set sliders to 0 and all edges will un-smooth/un-soften etc...
                or view > hidden_geometry toggle to 'on' and use erase+ctrl+shift to un-soften wiped edges [also remember that erase+ctrl softens wiped edges and erase+shift hides wiped edges - but you must select hidden lines to unhide them using entity info, as there is not erase >> unhide equivalent key-combo...]
                • massimoM
                  massimo Moderator
                  Already a must-have plugin. Thank you Fredo. 👍
                  • charly2008C
                    charly2008
                    Some ideas with Grow and Curviloft
                    Untitled.skp
                    • charly2008C
                      charly2008
                      In some forms it comes to interesting but not unanticipated results.
                      • fredo6F
                        Charly,
                        There are still missing features in Loft along Path, in particular about spiral specific treatments.
                        But if you can post your model, I can have a look and see if this can be handled.
                        • charly2008C
                          charly2008
                          Hi Fredo,
                          attached you wil have a similar model because the first one i have deleted. I selected each segment separately. Thanks again for your plugin, thanks for your efforts.
                          Karl (Charly)
                          Test1.zip
                          • charly2008C
                            charly2008
                            The same shape with small modifications
                            • L
                              lapx
                              Thanks Tig! I'll try it out 🎉
                              • Didier BurD
                                Didier Bur
                                Hi Fredo,
                                I get a bugsplat EVERYTIME I try to "loft by spline", no matter the method used. Any possible conflict with other plugins ?
                                F: J'ai un bugsplat directement après avoir cliqué l'icône, quelle que soit la méthode de sélection que j'utilise pour les faces, contours, chemins, etc. Est-ce qu'il y a à ta connaissance un conflit possible avec un autre plugin (ceux de TIG par exemple, qui font un job similaire ?).
                                Je suis scotché, là...
                                DB
                                • fredo6F
                                  @didier bur said:
                                  Hi Fredo,
                                  At what step do you get the bug splat: selection, preview, generation of geometry?
                                  Is it with any model?
                                  I don't think there are conflicts with other plugins, and anyway not TIG's ones, because I have them in active my environment.
                                  • Didier BurD
                                    Didier Bur
                                    @Fredo6: at any time, either in a blank new model, or in a model with geometry in it.
                                    The bugsplat occurs as soon as I click on the icon, once I have selected contours or faces and the path (no problem with selection. 😲
                                    I'm considering to start with an empty Plugins folder (except curviloft of course 😄 ) to see what happens.
                                    DB
                                    • urgenU
                                      urgen
                                      ...Oh, Fredo,thank you very much! 👍
                                      --pupil forever...------
                                        djorkaeff
                                        Very good and promising plugin. Thank you for your effort and generosity!
                                        • JClementsJ
                                          JClements
                                          Hi Fredo:
                                          Is there anyway, once the surface group is created, that it could store the Curviloft parameters used? That way the user, if they had not completed all the surfacing, could verify and reuse those settings at a later time.
                                          Perhaps there could be an eyedropper that could "suck up" the values of an existing surface-group and paste them into the Curviloft dialog?
                                          I have been doing a bit of testing using contours from CAD and comparing the results with the Sandbox tool. I was not able to reduce the total curviloft surfaces (triangles and quadrangles) between contour elevations compared to the triangulated surfaces sandbox creates BUT Curviloft places its surfaces where they SHOULD BE unlike Sandbox which places surfaces that "bridge" across vertices of the same elevation ...that is a big time saver.
                                          • pep75P
                                            pep75
                                            This is a brilliant Plug-In...Super. Fredo fantastic!!! This is just what SU needed, just that little extra spline modelling tool. And for free! Better then the Booltools where you'll have to pay for and works 25% of the time...
                                            Fredo you're my hero!
                                            • 65
                                            • 66
                                            • 6 / 66
