    [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26
    2.2k Posts 573 Posters 4.2m Views 575 Watching
      prismcnd
      Well I would really like to thank you Tom and Tig, after a couple of days i found the culprit, apparently i had a couple of older versions of the LibFredo6 filefolder in my plugins directory and after removing them everything is back to normal. Stupid mistake and thank you for your help.
      β€œWhatever the mind of man can conceive and believe, it can achieve.” -W.Clement Stone (American best selling Author and Founder of Combined Insurance Co (now a part of Aon Corp.), 1902-2002)
        thmnka84
        Could someone please give me more detailed info about how to install lebfredo6 34 c?
        Can get it running...
        all the best
        AA
          all the best
          AA
          Did you look at the screenshot of the first post? Are your files located like that?
            chouaibcl65
            thank youu
              thebestvip84
              thks alot ,u r my hero πŸ˜„
              • W Offline
                wyatt
                I figured out what was happening regarding the errors I was getting last week. The problem was organizer.rb. For the LibFredo6 plugins to work, both LIBFREDO6_Dir_34 and FREDOSCALE_Dir_20 must be added to the SmustardOrganizerExcludeFolders.txt file. As far as I can tell that does not effect the functionality of Fredo's scripts. Not sure if anyone else uses Organizer, but now you know.
                Wyatt
                  bobbybobbob
                  @exodiaangel said:
                  do i need to be a special type of member or something to download the roundcorners thing? coz i am SO confused πŸ˜• ❓
                  HELP PLEASE!!
                  its not you, its this site... if there was just a "DOWNLOADS" section....
                  I'm trying as well. still haven't found it....i registered, but now the spot that previously said that files are only for members is nowhere to be found.
                  also confusing which topic is the "top" topic. fear not, just keep searching this site, and hopefully i'll find it before i loose interest in rounding my corners...funny thing is, i had this plugin last year, but lost it some how...so i guess i went through all this before! sheesh.
                  but at least i'm begininning to see that Fredo6 is "the one".
                    Hi guys,
                    The plugins are regularly posted in (attached to) the first post in their respective topic when the author first "published" his plugin. I cannot really say it more clear. To search for a certain plugin, best is to start here:
                    http://forums.sketchucation.com/viewtopic.php?f=323&t=23989
                    (This is a "sticky" post at the top of this subforum).
                      agamemnus
                      Hi Fredo,
                      Thanks a lot for fixing the greying-out issue!
                        Mia
                        NEW VERSION 3.1c
                        Needed for for FreeScale 2.0c
                        see http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=144178#p144178
                        Hi!
                        I've just doanloaded the 3.4 and extracted the zip to the Plugins folder as advised, but the settings do not show up in the Window menu. Should this extracting to folder be the "installation" or do I miss something?
                        • fredo6F Offline
                          @mia said:
                          Hi!
                          Can you check if you have the correct footprint, with just 2 elements in the Sketchup Plugins directory:
                          • LibFredo6.rb
                          • LIBFREDO6_Dir_34 folder
                          PS: you also need to install at least one of my plugins (FredoScale, RoundCorner, ...) to see something in the menus (LibFredo6 does not load otherwise)
                            maruthi
                            i am not able download ...please help me out... 😞
                              What happens when you want to download? Can you see the link at all?
                              • N Offline
                                nirve08
                                ei guys, im still a new at using sketch-up, i search out for plugins, and i find this one interesting, i downloaded it, followed the instructions, but it didnt work, i have installed also the freescale 2.0..how do you install this one? i need a detail instruction like what folder or which folder to paste or install...many thanks
                                  http://forums.sketchucation.com/viewtopic.php?p=144180#p144180 is the download page for the tool it has quite clear instructions ?
                                  What is the exact problem ? πŸ˜•
                                    jboyza
                                    Glad to hear its working
                                      baldaman
                                      I upgraded my OS to WINDOWS 7 ultimate 64 and now I have constant crash each time I try to use FREDOSCALE.
                                      Am I the only one on earth?
                                      Best regards to all Sketchup users.
                                        Dali_
                                        Eventually got roundCorner to work... You have to register first, to be able to download LibFredo6 3.4c...
                                        But, now it works, it's good – c'est bon – bravo!
                                        Merci
                                          tonywilton
                                          This has got to be the most frustrating site I have been on in a long time,
                                          I see all you guys talking about plugins but can never find where to download the damn things. There should be an obvoius download link through the discussion. I just wasted an hour looking, Bloody useless and certainly not up to the usual google clarity and intuitive standard.
                                            At the end of the first post there is a ZIP file. Download that (or click on the image below).
                                            Every site (forum) needs to get used to. This is such a forum, too. And this is not a Google site - that is here. The only difference (in functions) I guess is that you cannot attach anything there.
                                            And bloody welcome to SCF by the way.
                                            πŸ˜‰
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 109
                                            • 110
                                            • 20 / 110
