    Stretch a roof
    13 Posts 8 Posters 927 Views 8 Watching
    • F Offline
      fbo_bern
      hi all
      who can stretch me a roof over this stand?
      thanks for help.
      the file
        Not perfect but at least quick with the Soap Skin Bubble plugin.
        sonnendach.skp
        • F Offline
          fbo_bern
          yes, not bad. thank you....
            rickgraham
            Here's my attempt. I simply used the from contours from the Sandbox tools. Probably not what you envisioned tho...
            Rick
            sonnendach-rg.skp
              rickgraham
              Rick
              DEFINATLEY not as Gai's looks SO much better. ๐Ÿ˜’
              Rick
              • brookefoxB Offline
                brookefox
                Trying to do it myself produces nil.
                Weld to make a continuous curve is inconsistent but works on parts, either quarter, half, or whole without the crossing ribs, but soap timeouts (Timelimit finished!)!
                ~ Brooke
                  brookefox
                  You work cheap, and fast, and well, Gai...
                  Thanks for being here.
                  ~ Brooke
                    chrisjk
                    Here is my attempt using TIG's Extrude edges by Rails. I have only done half as a demonstration. I think it works better for the corner with the straight edge although the other quadrant could be a bit smoother - perhaps by altering the number of line segments?
                    sonnendach.skp
                      dylan
                      I did it also with TIGs EEBR and it worked very well. I have not posted it because it left a slight valley down the centre when I mirrored the half and I guess that is not required.
                      Edit: Thought I may as well post the skp!
                      sonnendach.skp
                      http://dmdarchitecture.co.uk/
                      • massimoM Offline
                        massimo Moderator
                        ...but soap timeouts (Timelimit finished!)
                        You can download a new version that works until 10. October 2010. ๐Ÿ˜„
                          brookefox
                          Thank you. I needed a translation!
                          ~ Brooke
                            Making the profiles [and rails], each with the same number of segments gives best results in EEbyRails - to weld complex sets of arcs/edges into one curve first select all and explode back to plain edges - they stay selected then use 'weld' to join them...
                              brookefox
                              Thanks, I'll try to remember these tips.
                              ~ Brooke
