    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
    • mariochaM Offline
      mariocha
      Hum .... Although the title says V1.3b
      the download still says v1.3a ๐Ÿ˜•
      %(#008000)[Mario C.
        @portenart.emile said:
        I found this plugin today. It look amazing. Ihave made the grass but i don't know why it isn't render in Vray ? I'm sure it's a specific option i have to check but i don't found it.
        I use Skectchup pro 7.1.6, Vray for sketchup 01.05.30, and Fur Plugin 1.3.
        This is due to a Sketchup bug and groups. The groups will render when you reopen the model.
        The latest VfSU does not suffer from this SU bug.
          jbrown
          Very handy.
          Am I missing something in the settings, though? It appears to be growing from the opposite side of the selected face and I can't figure out how to change that. Not too big a deal to select the opposite side from where it needs to go, but maybe there's an easier way?
            Hi Justin,
            Don't you have back faces where you want to grow the fur? Try to right click > Reverse faces and grow it again.
              tak2hata
              Hi,all.
              I upadte fur plugin v1_3c(test version).
              Mario..
              Sorry,I made a mistake in writing title. ๐Ÿ˜ฒ
              So Current version up to 1_3c.
              Thanks.
              by TAK2HATA
                portenart.emile
                Thanks you so much thomthom, it works.
                I'll post you my render once done.
                Emile
                • FrederikF Offline
                  Frederik
                  Like so many others, I'm having a blast with this new toy...
                  @ tak2hata:
                  Would it be possible to add an option, where you can select that components don't intersect with each other...??
                  Cheers
                  Kim Frederik
                    Simply incredible! ๐Ÿ˜ฎ
                    Thanks for this continuous update,too!
                    • DareDevilD Offline
                      DareDevil
                      I just update the v1.2 to the new 1.3c with the nice new features.
                      But...
                      I'm french and use SU on a french vista system. In french we use the comma (,) for decimal separation.
                      In default setup, all numbers are in french (0,0cm,0,0cm,5,0cm) and of course it read like a 0,0,0 (with an unread 0,5,0 after).
                      If I use a period (0.0cm,0.0cm,5.0cm) the plugin dont work ๐Ÿ˜ž
                      Why all the world dont use the same way to measure and write numbers ??? ๐Ÿ˜‰
                        I just update the v1.2 to the new 1.3c with the nice new features. But...
                        I'm French and use SU on a French Vista system. In French we use the comma (,) for decimal separation.
                        In default setup, all numbers are in French (0,0cm,0,0cm,5,0cm) and of course it read like a 0,0,0 (with an unread 0,5,0 after).
                        If I use a period (0.0cm,0.0cm,5.0cm) the plugin won't work ๐Ÿ˜ž
                        Why all the world don't use the same way to measure and write numbers ??? ๐Ÿ˜‰
                        Try substituting the comma (,) as the list separator with a semi-colon (;)... so in UK/US 1,2.3,4.5 >> 1;2,3;4,5 in FR.
                        Or change you regional settings !
                        Why can't everyone use a '.' as a "decimal-point" ? - after all it is not a "decimal-comma" - this would free up the ',' comma to be used as a list separator - it's prime function in grammar - and then we could leave the poor old ";" alone !
                        • soloS Offline
                          Got no idea, here in the states we still use the imperial system or as we call it 'American standard' and we drive on the wrong side of the road according to y'all. ๐Ÿ’š
                          • FrederikF Offline
                            Frederik
                            @solo said:
                            ...and we drive on the wrong side of the road according to y'all. ๐Ÿ’š
                            Not true, Pete...
                            In most European countries, we drive in the right (in the sense opposite to left) side of the road...
                            Only in UK in Europe (and I believe on Cypres too) they drive in the left side... ๐Ÿ˜‰
                            Cheers
                            Kim Frederik
                              @tak2hata: could you keep the filename free from the version number? That way it's easier to update by just dragging the file into the plugins folder overriding the old.
                                That generally just causes troubles elsewhere. I've tried it. Very awkward.
                                  I use Norwegian locale, we also use comma as decimal separator. But using period in this plugin works for me.
                                  I noted something in what you said though: (0.0cm,0.0cm,5.0cm)
                                  Did you enter cm into the direction and force vectors?
                                  They should not have length indications. Vectors are just direction indicators.
                                    DareDevil
                                    I tried, but dont work ๐Ÿ˜ž
                                    Nooooooooo, pleeeeaaaaase ๐Ÿ˜‰
                                    Can you use the period in the SU standard value input ? I cant ! I must use the comma and the semi-colon as separator (i.e. 10,5;22,4 for a rectangle).
                                    No, cm is in the default setting.
                                    If it's 0cm it's ok, but if it's 0 cm (with space) it dont work.
                                    OK, I know why I have the unit after value, because it's a SU setting in the Model info : "Display units format". Uncheck it, disable the cm.
                                    ... And if I set the Precision (in Model info -> Units) to 0 instead 0,0 all it's ok in the Fur setting windows, I have 0,0,5 (but setting 0cm for Precision or mm for Units in it's not ok for my way of work ๐Ÿ˜‰)
                                      tak2hata
                                      That's very difficult for me.I will challenge future.Please wait without expecting it. ๐Ÿ˜’
                                      Indeed,I learnt it for the first time. I will think about some measures for that problem.
                                      Thanks.That's right! I will keep the filename. ๐Ÿ˜‰
                                      by TAK2HATA
                                      • FrederikF Offline
                                        Frederik
                                        I'll keep my fingers crossed... ๐Ÿ˜„
                                        This plug-in is so much fun to work with...
                                        You have my deepest respect...
                                        http://www.kerkythea.net/users/Frederik/Anim-Icons/praise.gif
                                        Cheers
                                        Kim Frederik
                                          Not in the SU VCB area, no. But this plugin doesn't use this, does it? โ“
                                          What I was referring to was the webdialog (metric) for this plugin. The screenshot I showed last time.
                                          Are you seeing "cm" in the webdialog for this plugin?
                                          I'm confused...
                                          Or are you talking about SU in general?
                                            tak2hata
                                            Hi,All.
                                            I update fur plugin.
                                            Now it's version 1_3d.
                                            this fileName will keep to "fur_en.rb" for future.
                                            When you use this version ,you must remove older version fur plugin file from sketchup plugins folder.
                                            Thanks.
                                            by TAK2HATA
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 32
                                            • 33
                                            • 23 / 33
