    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.3m Views 254 Watching
      Simply incredible! ๐Ÿ˜ฎ
      Thanks for this continuous update,too!
      • DareDevilD Offline
        DareDevil
        I just update the v1.2 to the new 1.3c with the nice new features.
        But...
        I'm french and use SU on a french vista system. In french we use the comma (,) for decimal separation.
        In default setup, all numbers are in french (0,0cm,0,0cm,5,0cm) and of course it read like a 0,0,0 (with an unread 0,5,0 after).
        If I use a period (0.0cm,0.0cm,5.0cm) the plugin dont work ๐Ÿ˜ž
        Why all the world dont use the same way to measure and write numbers ??? ๐Ÿ˜‰
          I just update the v1.2 to the new 1.3c with the nice new features. But...
          I'm French and use SU on a French Vista system. In French we use the comma (,) for decimal separation.
          In default setup, all numbers are in French (0,0cm,0,0cm,5,0cm) and of course it read like a 0,0,0 (with an unread 0,5,0 after).
          If I use a period (0.0cm,0.0cm,5.0cm) the plugin won't work ๐Ÿ˜ž
          Why all the world don't use the same way to measure and write numbers ??? ๐Ÿ˜‰
          Try substituting the comma (,) as the list separator with a semi-colon (;)... so in UK/US 1,2.3,4.5 >> 1;2,3;4,5 in FR.
          Or change you regional settings !
          Why can't everyone use a '.' as a "decimal-point" ? - after all it is not a "decimal-comma" - this would free up the ',' comma to be used as a list separator - it's prime function in grammar - and then we could leave the poor old ";" alone !
          • soloS Offline
            Got no idea, here in the states we still use the imperial system or as we call it 'American standard' and we drive on the wrong side of the road according to y'all. ๐Ÿ’š
            • FrederikF Offline
              Frederik
              @solo said:
              ...and we drive on the wrong side of the road according to y'all. ๐Ÿ’š
              Not true, Pete...
              In most European countries, we drive in the right (in the sense opposite to left) side of the road...
              Only in UK in Europe (and I believe on Cypres too) they drive in the left side... ๐Ÿ˜‰
              Cheers
              Kim Frederik
                @tak2hata: could you keep the filename free from the version number? That way it's easier to update by just dragging the file into the plugins folder overriding the old.
                  That generally just causes troubles elsewhere. I've tried it. Very awkward.
                    I use Norwegian locale, we also use comma as decimal separator. But using period in this plugin works for me.
                    I noted something in what you said though: (0.0cm,0.0cm,5.0cm)
                    Did you enter cm into the direction and force vectors?
                    They should not have length indications. Vectors are just direction indicators.
                      DareDevil
                      I tried, but dont work ๐Ÿ˜ž
                      Nooooooooo, pleeeeaaaaase ๐Ÿ˜‰
                      Can you use the period in the SU standard value input ? I cant ! I must use the comma and the semi-colon as separator (i.e. 10,5;22,4 for a rectangle).
                      No, cm is in the default setting.
                      If it's 0cm it's ok, but if it's 0 cm (with space) it dont work.
                      OK, I know why I have the unit after value, because it's a SU setting in the Model info : "Display units format". Uncheck it, disable the cm.
                      ... And if I set the Precision (in Model info -> Units) to 0 instead 0,0 all it's ok in the Fur setting windows, I have 0,0,5 (but setting 0cm for Precision or mm for Units in it's not ok for my way of work ๐Ÿ˜‰)
                        tak2hata
                        @frederik said:
                        Would it be possible to add an option, where you can select that components don't intersect with each other...??
                        That's very difficult for me.I will challenge future.Please wait without expecting it. ๐Ÿ˜’
                        Indeed,I learnt it for the first time. I will think about some measures for that problem.
                        Thanks.That's right! I will keep the filename. ๐Ÿ˜‰
                        by TAK2HATA
                        • FrederikF Offline
                          Frederik
                          I'll keep my fingers crossed... ๐Ÿ˜„
                          This plug-in is so much fun to work with...
                          You have my deepest respect...
                          http://www.kerkythea.net/users/Frederik/Anim-Icons/praise.gif
                          Cheers
                          Kim Frederik
                            Not in the SU VCB area, no. But this plugin doesn't use this, does it? โ“
                            What I was referring to was the webdialog (metric) for this plugin. The screenshot I showed last time.
                            Are you seeing "cm" in the webdialog for this plugin?
                            I'm confused...
                            Or are you talking about SU in general?
                              tak2hata
                              Hi,All.
                              I update fur plugin.
                              Now it's version 1_3d.
                              this fileName will keep to "fur_en.rb" for future.
                              When you use this version ,you must remove older version fur plugin file from sketchup plugins folder.
                              Thanks.
                              by TAK2HATA
                                Good stuff! ๐Ÿ‘
                                Very nice plugin this. Shaping up good.
                                Another remark: menu names, can you also avoid version number in the menu names? Keep them static? Because when the menu name changes between updates the shortcuts assigned to them doesn't work any more.
                                  hmmm...
                                  I now see the problem daredevil talked about.
                                  tak2hata:
                                  When the user's locale is decimal you can't use the comma to get the various components of the vectors.
                                  "0,400mm,0mm,0mm" is interpreted as x=0, y=400, z=0
                                  The problem is this:
                                    def fur_dialog_ini
                                      @fur_units_metric = false
                                      @fur_units_metric = true if ( 0.to_l.to_s )["m"]
                                      @delim = ","
                                      @delim = ";" if Sketchup.get_locale.upcase == "FR"
                                  This code only checks for FR Sketchup locale. But there are many more that uses , comma as decimal delimiter. Norwegian for instance.
                                  But, Sketchup.get_locale does not return the locale of the system. It returns the language code of Sketchup.
                                  For instance, I use Norwegian locales, but use English SU. Sketchup.get_locale returns en-US
                                  I've been recently struggling with this myself.
                                  And the hack I ended up using to find the user's comma decimal separator was this: @decimal_separator ||= 1.2.to_l.to_s.match(/\d(\D)\d/)[1]
                                  See http://forums.sketchucation.com/viewtopic.php?f=180&t=28346 for more info.
                                  Now, this only gives you what the comma separator is. I've not found a way to find the list separator. Just I think you can catch most cases by assuming locales with comma as decimal separator uses ; as list separator.
                                  So to revise your code:
                                    def fur_dialog_ini
                                      decimal_sep = 1.2.to_l.to_s.match(/\d(\D)\d/)[1]
                                      @delim = ";" if decimal_sep == ','
                                  Then there is the other part of that method:
                                  @fur_units_metric = false @fur_units_metric = true if ( 0.to_l.to_s )["m"]
                                  Use model.options to get the user units.
                                  http://code.google.com/apis/sketchup/docs/ourdoc/model.html#options
                                  It returns an OptionManager that gives you access to some OptionsProvider classes.
                                  http://code.google.com/apis/sketchup/docs/ourdoc/optionsmanager.html
                                  http://code.google.com/apis/sketchup/docs/ourdoc/optionsprovider.html
                                  To inspect the available options, use this snippet:
                                  Sketchup.active_model.options.keys.each {|key| p key; Sketchup.active_model.options[key].each {|k,v| puts "> #{k} - #{v}"} }
                                  Using that you can see that model.options["UnitsOptions"] gives you all the info you need about the model units.
                                  model.options["UnitsOptions"]["LengthUnit"] gives you the unit type.
                                  The unit types are:
                                  // LENGTH_FORMAT: 0 = Decimal, 1 = Arcitectural, 2 = Engineering // LENGTH_UNITS: 0 = Inches, 1 = Feet, 2 = Millimeters 3 = centimeters, 4 = Meters // LENGTH_PRECISION: number of decimal places to show
                                  (Found this in the Google SketchUp 7\Resources\en-US\i18n.dat file)
                                    @frederik said:
                                    ...Only in UK in Europe (and I believe on Cypres too) they drive in the left side... ๐Ÿ˜‰
                                    And Ireland, too.
                                    • W Offline
                                      watkins
                                      Countries that drive on the left
                                      http://en.wikipedia.org/wiki/File:Countries_driving_on_the_left_or_right.svg
                                      Quite a few.
                                      • soloS Offline
                                        Looks like a British commonwealth map. ๐Ÿ˜•
                                          Yeah. Though already a minority of the countries, still "the sun never sets over the countries that drive on the left".
                                          ๐Ÿ˜„
                                            And when French user uses directly FR Locale "." (modified) whith English SU version seems there is no problem? ๐Ÿ˜‰
                                            • 11
                                            • 32
                                            • 33
                                            • 9 / 33
