    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
    • EscapeArtistE Offline
      EscapeArtist
      Just keeps getting better!
        Daniel S
        Thank you for the update tak2hata!
        Perhaps in next versions you can put all the options in a submenu? Something like the attachment.
        Daniel S
          Why metric and imperial? Why not just deal with the units in the way that the model is?
            tak2hata
            Hi,Daniel.
            I Changed menu items into sub menu named "Fur_v1_3".
            Hi,Thomas.
            Because I think it easy to test both imperial and metric.
            I am not accustomed to the imperial.
            I will corrects it in future version.
            Thanks for your advice.
            by TAK2HATA
              The Numeric, Float and String class has some nice methods that let you deal with units in the user's locale and in the current model's units.
                tak2hata
                Hi, Thomas.
                Thanks ! I'm searching for that method.
                by TAK2HATA
                  Basically:
                  Ensure the units you use are Length objects. Length.to_s will output a unit in the user's locale and model settings. This is useful when presenting units in the UI, like for inputboxes etc.
                  Then you have String.to_l, which is useful to convert user input into Length. If a user types "100mm" it then .to_l will convert that into the appropriate Length. (Length is always in SU's internal units: inches)
                  "100m".to_l
                  becomes:
                  3937.00787401575
                  If the user has mm set as the model units, then "100" (without any unit indication) is assumed to be in mm and the result is:
                  "100".to_l 3.93700787401575
                  same thing as if the user had typed "100mm"
                  "100mm".to_l 3.93700787401575
                    portenart.emile
                    Hello every body,
                    I found this plugin today. It look amazing. Ihave made the grass but i don't know why it isn't render in Vray ? I'm sure it's a specific option i have to check but i don't found it.
                    I use Skectchup pro 7.1.6, Vray for sketchup 01.05.30, and Fur Plugin 1.3.
                    I can send you a screenshot or a file if you need.
                    Thanks you for your help ๐Ÿ˜„
                    Emile
                    • mariochaM Offline
                      mariocha
                      Hum .... Although the title says V1.3b
                      the download still says v1.3a ๐Ÿ˜•
                      %(#008000)[Mario C.
                        This is due to a Sketchup bug and groups. The groups will render when you reopen the model.
                        The latest VfSU does not suffer from this SU bug.
                          jbrown
                          Very handy.
                          Am I missing something in the settings, though? It appears to be growing from the opposite side of the selected face and I can't figure out how to change that. Not too big a deal to select the opposite side from where it needs to go, but maybe there's an easier way?
                            Hi Justin,
                            Don't you have back faces where you want to grow the fur? Try to right click > Reverse faces and grow it again.
                              tak2hata
                              Hi,all.
                              I upadte fur plugin v1_3c(test version).
                              Mario..
                              Sorry,I made a mistake in writing title. ๐Ÿ˜ฒ
                              So Current version up to 1_3c.
                              Thanks.
                              by TAK2HATA
                                portenart.emile
                                Thanks you so much thomthom, it works.
                                I'll post you my render once done.
                                Emile
                                • FrederikF Offline
                                  Frederik
                                  Like so many others, I'm having a blast with this new toy...
                                  @ tak2hata:
                                  Would it be possible to add an option, where you can select that components don't intersect with each other...??
                                  Cheers
                                  Kim Frederik
                                    Simply incredible! ๐Ÿ˜ฎ
                                    Thanks for this continuous update,too!
                                    • DareDevilD Offline
                                      DareDevil
                                      I just update the v1.2 to the new 1.3c with the nice new features.
                                      But...
                                      I'm french and use SU on a french vista system. In french we use the comma (,) for decimal separation.
                                      In default setup, all numbers are in french (0,0cm,0,0cm,5,0cm) and of course it read like a 0,0,0 (with an unread 0,5,0 after).
                                      If I use a period (0.0cm,0.0cm,5.0cm) the plugin dont work ๐Ÿ˜ž
                                      Why all the world dont use the same way to measure and write numbers ??? ๐Ÿ˜‰
                                      • TIGT Online
                                        I just update the v1.2 to the new 1.3c with the nice new features. But...
                                        I'm French and use SU on a French Vista system. In French we use the comma (,) for decimal separation.
                                        In default setup, all numbers are in French (0,0cm,0,0cm,5,0cm) and of course it read like a 0,0,0 (with an unread 0,5,0 after).
                                        If I use a period (0.0cm,0.0cm,5.0cm) the plugin won't work ๐Ÿ˜ž
                                        Why all the world don't use the same way to measure and write numbers ??? ๐Ÿ˜‰
                                        Try substituting the comma (,) as the list separator with a semi-colon (;)... so in UK/US 1,2.3,4.5 >> 1;2,3;4,5 in FR.
                                        Or change you regional settings !
                                        Why can't everyone use a '.' as a "decimal-point" ? - after all it is not a "decimal-comma" - this would free up the ',' comma to be used as a list separator - it's prime function in grammar - and then we could leave the poor old ";" alone !
                                        • soloS Offline
                                          Got no idea, here in the states we still use the imperial system or as we call it 'American standard' and we drive on the wrong side of the road according to y'all. ๐Ÿ’š
                                          • FrederikF Offline
                                            Frederik
                                            @solo said:
                                            ...and we drive on the wrong side of the road according to y'all. ๐Ÿ’š
                                            Not true, Pete...
                                            In most European countries, we drive in the right (in the sense opposite to left) side of the road...
                                            Only in UK in Europe (and I believe on Cypres too) they drive in the left side... ๐Ÿ˜‰
                                            Cheers
                                            Kim Frederik
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 32
                                            • 33
                                            • 18 / 33
