    [Plugin] Component/group tools
    30 Posts 16 Posters 48.2k Views 16 Watching
      Matt666
      Sorry for the delay!
      Aille... I tested it more deeper, and yes, SU crashes... Sorry. I don't know why.I will investigate.
      Thank you for the feedback!
      Frenglish at its best !
      My scripts
        su30
        Hi Matt,
        Your script make sense!
        and it reminds me an idea,
        I wish there will be a plugin:
        First we draw single lines, then we select a component,
        I hope the plugin can make each single straight line into a component, the length of the line will define the scale of the component.
        I don't know if it is possible, but I know it will also make big sense!
        Su30
        su30
        • CadFatherC Offline
          CadFather
          Hi Matt - i think this script is great - hope you can find the crash fix sometime
          Cheers..
            Try this
            http://www.sketchucation.com/forums/scf/viewtopic.php?p=145009#p145009
            componentInstance.add_entities(entities,copy,unique)
            it might help you avoid the BugSplatting...
              CadFather
              Hi Matt, hope you are so bored one of these days that you will pick this script up again!
              cheers
                Matt666
                Hi CadFather!
                The problem is that working on components generates lots of problems... It's very hard for me.
                I try sometimes, but slowly!
                My scripts
                  CadFather
                  ..take all the time you see fit Matt, i might post a request as well..cheers!
                    Matt666
                    πŸ˜‰
                    My scripts
                      mac1
                      @matt666 said:
                      Hi all!
                      Here is a set of tools to play with components and groups.
                      It can :
                      • Make a group of just one entity (right click or menu plugins/Make group)
                      • Make a component instance of just one entity (right click or menu plugins/Make component)
                      • Convert each entity in the selection in a single group (right click or menu plugins/Convert on single groups)
                      • Convert each entity in the selection in a single component (right click or menu plugins/Convert on single components)
                      • Convert the selected component into a group (right click or menu plugins/Make group)
                        SU has a native tool to convert a group into a component.
                      That's all!
                      πŸ˜‰
                      * Edit post
                      * Report this post
                      * Reply with quote
                      Make_Comonents.rb Version 1.1 Does Not Run All the Time
                      Postby mac1 on Tue May 18, 2010 10:30 am
                      System Windows xp sp3
                      SU as noted below
                      P4 3.2GHz Intel 865 PERL Mother Board, 4 GB Memory
                      I have been attempting to convert the file ref in this link http://www.google.com/support/forum/p/sketchup/thread?tid=50e8ceb670ed94ef&hl=en ( file: http://sketchup.google.com/3dwarehouse/details?mid=5841263f36529eef9f30f02514717f00 )to components but the script usually converts the first group and quits but, some times it will convert correctly. Ii have not been able to find the initial conditions to repeat the success case. When the failure occurs the ruby console reports this:
                      Error: #<NoMethodError: undefined method definition' for #<Deleted Entity:0x60ad9f0>> F:/PROGRA~1/Google/GOOGLE~1/Plugins/Make_Components.rb:140:in make_components'
                      F:/PROGRA~1/Google/GOOGLE~1/Plugins/Make_Components.rb:135:in each' F:/PROGRA~1/Google/GOOGLE~1/Plugins/Make_Components.rb:135:in make_components'
                      F:/PROGRA~1/Google/GOOGLE~1/Plugins/Make_Components.rb:48
                      F:/PROGRA~1/Google/GOOGLE~1/Plugins/Make_Components.rb:48:in `call'
                      I have uninstalled all ruby scripts except the ones loaded with the basic SU installation also removed SU 6. the failure repeats with both SU 7.0+ and SU 7.1 both with clean installs. I have tried a repair install with both SU 7's but cannot because of a missing msi file
                      Any Suggestions??
                        mac1
                        Update
                        Noted during my post the ruby console error report is different ( in the ref. help forum) that what was obtained in the last attempt to covert the groups. Line number ref are different by one and the entity octal number is different. Removed script, download from Matt's link above and reloaded with same result. 😞
                        • Chris FullmerC Offline
                          I looked over his code and there seems to be an error that pops up when you only have groups selected. Try running the script with always a non-group in the selection - like just draw a line and then select it along with the groups, then run the script. I think that will by pass the problems.
                            mac1
                            @chris fullmer said:
                            I looked over his code and there seems to be an error that pops up whn you only have groups selected. Try running the script wil always a non-group in the selection - like just draw a line and then select it along with the groups, then run the script. I think that will by pass the problems.
                            Thanks, nothing to it when you know what you are doing β˜€
                            BTW the line gets converted to component also ❓
                            • brookefoxB Offline
                              brookefox
                              The utility of this script is beyond me. I will keep my head down in hopes that someone will post some uses.
                              ~ Brooke
                                mac1
                                Very simple at least for me. A post in the Sketchup help forum having problems with file size had numerous groups with the same geo.( An example is shown in the ref test file I included with my post.) has a file size of ~930KB. If one converts to components, then uses the browser "replace selected" capability that goes down to around ~70KB. A significant reduction in my mind. If one looks at the model info stats report the edges and faces don't change that much. It was my feeble attempt to understand the imapct of max use of components which is often stated but not quantified. ❓ BTW I will on occasion place a very simple component in my model(s), have even used a line ( not a good idea), then recognizing a components definition is invariant under move, scale and rotation one can latter replace with a complex model which gets added to the model at the scale, location and rotation of the simple model( need to pay attention to your component axis)
                                  brookefox
                                  Thanks for yor response. This use I get but for it I don't need this plugin:
                                  One can make components out of groups and instances of groups this with native SU.
                                  It's the making of components out of lines that I don't get much of.
                                  So for your 'simple' best use you would have a lot of lines in your models which are not parts of components, and making them components with this would reduce your file size. OK. I do have a lot of groups which are not components, but next to no lines which are not parts of groups or components. For me the crux is when and what groups to componetize, just because it take time, even if it saves file space. Certainly if I have many of said group or I want component behavior from a group it would be best componentized, I don't need a plugin to do that. Rereading the thread I see the use implied of maybe wanting to populate a model with lines, componetize them and then subsequently edit the component which would then be in place wherever the lines were. If I can do this now with two lines instead of one, that is sufficient for me.
                                  ~ Brooke
                                    mac1
                                    Glad you are happy with what you have that is what is important. The plugin is just another wrench in the tool box.
                                    You are correct SU has that native capability but what are you going to do if you have say a 100 groups and identical. The native tool will make a component out of all of them but the reduction of file size doing that will be nil.
                                    My test case was not suppose to be a global analysis of a model having a mix of various entities and was meant to show what poor modeling practice can cost one. The model has 33 groups and nested in each of those is three groups( all identical) and some other simple entities a really a simple model. If you examine one of those and expolde the component the change in file size is nil so the the message is use components but having a bunch of nested groups in the components does not help much
                                    Gday
                                    • artmusicstudioA Offline
                                      artmusicstudio
                                      hello,
                                      i went thru all topics dealing with component naming,
                                      but i cannot find a solution.
                                      i would like to give a name to a created component by this code:
                                      ######## start code
                                      model = Sketchup.active_model
                                      entities = model.active_entities
                                      rl1 = [0, y1, 0]
                                      rl2 = [0, y2, z]
                                      group = entities.add_group
                                      entities2 = group.entities
                                      new_line = entities2.add_line rl1, rl2
                                      length = new_line.length
                                             centerpoint = rl1
        # Create a circle perpendicular to the normal or Z axis
                                             vector = rl2
                                             vector2 = vector.normalize!
                                             edges = entities2.add_circle centerpoint, vector2, $thradius
                                             kreis = entities2.add_face edges
                                             kreis.pushpull -(5/$faktor)/100
                                         $masterrailingtms = group.to_component
                                         # HERE I WOULD LIKE TO DEFINE A NAME FOR THIS NEW COMPONENT, WHICH I CAN SEE IN IN SKP ENTITY-INORMATION-WINDOW. this name also hopefully appears in the copied instances of this component, but most important is the name for component [0]
                                      ######## end code
                                      can somebody help me?
                                      thanx
                                      stan
                                        Your
                                        xxxx = group.to_component
                                        refers to an component-instance NOT a component-definition: so to find the instance's definition use:
                                        defn = xxx.definition
                                        then rename it thus:
                                        defn.name = "foo_fighter"
                                        Be aware if there is already a 'foo_fighter' definition it'll become 'foo_fighter#1' etc
                                        PS: don't use global $var variables which will potentially clash with others tools - wrap your code in your own module and use @var instead.
                                          artmusicstudio
                                          hi tig, thanx,
                                          this work well, one step further for me, now i can identify the "children" of the masters exactly. that's perfect.
                                          just to understand exactly:
                                          a name of component instance defined by this method appears in the field "description"
                                          a group named by group.name = "xxx" appears in the filed "name"
                                          is there also a way to NAME a component or its instance besides a description?
                                          thanx
                                          stan
                                            Both components and groups [and also images for that matter] that you see placed inside a model are instances of their 'definition'.
                                            Every 'definition' has a unique definition.name - this can be reset provided it is unique - if 'xxx' is already used SketchUp auto-increments the name as 'xxx#1' etc.
                                            For a component that is the 'Definition Name' displayed in Entity Info, the Component-Browser's top-most field, and in the Outliner as <defname>.
                                            A component-instance can also have a instance.name this the 'Name' displayed in Entity Info, and in the Outliner as name<defname>. This need not be assigned and it does not need to be unique.
                                            You can find defn = instance.definition etc.
                                            A group also has a unique definition.name that is usually hidden from the user - something like ' Group#99'. You can change this through the API to another unique definition.name - but for what purpose?
                                            There is also group.name - akin to the instance.name. This need not be assigned and it does not need to be unique. This is the 'Name' displayed in Entity Info and in the Outliner [if the Name=='' then the Outliner says 'Group']
                                            You cannot directly find a group.definition in the API, BUT defn = group.entities.parent should return its definition.
                                            The definition.description can be assigned and for a component appears this in the second-from-top field in the Component-Browser.
                                            Although you can assign a definition.description to a group it is not seen anywhere by a user - it is only accessible through the API.
                                            When you convert a group to a component the name of the component definition is taken as the group's definition.name [e.g. ' Group#666'] NOT the group.name.
                                            What is returned by the group's conversion to a component is an instance NOT a definition, so to find the definition itself use the code given in the earlier reply. Then you can use defn.name='xxxx' as desired...
