    [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26
    2.2k Posts 573 Posters 4.2m Views 575 Watching
      Did you get the latest version of the Lib and software rubies and keep them in their respective folders as you extracted them from their zip files...
        Sir
        ok, now it seems none of the toolbars are loading but no error messages popup
        interestingly in the preferences > extensions absolutly nothing is showing
          Sounds like you have some files in the wrong places - is this on PC or Mac ?
          Copy/Paste this line into the Ruby Console + <enter>
          Sketchup.find_support_file("Plugins")
          It returns the path that all of the .rb files OR sub-folders should go into - they should be in the same relationship as they are in the zip file - i.e. usually a 'loader' .rb and then a related sub-folder full of other files - that folder goes into Plugins with its contents unchanged.
            Sir
            yeah its mac, and they're in the correct place. i guess ill wipe the folder and reinstall them all.
              rogueparker
              Im getting the same error message as above, but on a vista pc, I've tried the install 3 times. any ideas?
                Are the files installed as described in the first post?
                  prismcnd
                  Well I would really like to thank you Tom and Tig, after a couple of days i found the culprit, apparently i had a couple of older versions of the LibFredo6 filefolder in my plugins directory and after removing them everything is back to normal. Stupid mistake and thank you for your help.
                  โ€œWhatever the mind of man can conceive and believe, it can achieve.โ€ -W.Clement Stone (American best selling Author and Founder of Combined Insurance Co (now a part of Aon Corp.), 1902-2002)
                    thmnka84
                    Could someone please give me more detailed info about how to install lebfredo6 34 c?
                    Can get it running...
                    all the best
                    AA
                      all the best
                      AA
                      Did you look at the screenshot of the first post? Are your files located like that?
                        chouaibcl65
                        thank youu
                          thebestvip84
                          thks alot ,u r my hero ๐Ÿ˜„
                          • W Offline
                            wyatt
                            I figured out what was happening regarding the errors I was getting last week. The problem was organizer.rb. For the LibFredo6 plugins to work, both LIBFREDO6_Dir_34 and FREDOSCALE_Dir_20 must be added to the SmustardOrganizerExcludeFolders.txt file. As far as I can tell that does not effect the functionality of Fredo's scripts. Not sure if anyone else uses Organizer, but now you know.
                            Wyatt
                              bobbybobbob
                              @exodiaangel said:
                              do i need to be a special type of member or something to download the roundcorners thing? coz i am SO confused ๐Ÿ˜• โ“
                              HELP PLEASE!!
                              its not you, its this site... if there was just a "DOWNLOADS" section....
                              I'm trying as well. still haven't found it....i registered, but now the spot that previously said that files are only for members is nowhere to be found.
                              also confusing which topic is the "top" topic. fear not, just keep searching this site, and hopefully i'll find it before i loose interest in rounding my corners...funny thing is, i had this plugin last year, but lost it some how...so i guess i went through all this before! sheesh.
                              but at least i'm begininning to see that Fredo6 is "the one".
                                Hi guys,
                                The plugins are regularly posted in (attached to) the first post in their respective topic when the author first "published" his plugin. I cannot really say it more clear. To search for a certain plugin, best is to start here:
                                http://forums.sketchucation.com/viewtopic.php?f=323&t=23989
                                (This is a "sticky" post at the top of this subforum).
                                  agamemnus
                                  Hi Fredo,
                                  Thanks a lot for fixing the greying-out issue!
                                    Mia
                                    NEW VERSION 3.1c
                                    Needed for for FreeScale 2.0c
                                    see http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=144178#p144178
                                    Hi!
                                    I've just doanloaded the 3.4 and extracted the zip to the Plugins folder as advised, but the settings do not show up in the Window menu. Should this extracting to folder be the "installation" or do I miss something?
                                    • fredo6F Offline
                                      @mia said:
                                      Hi!
                                      Can you check if you have the correct footprint, with just 2 elements in the Sketchup Plugins directory:
                                      • LibFredo6.rb
                                      • LIBFREDO6_Dir_34 folder
                                      PS: you also need to install at least one of my plugins (FredoScale, RoundCorner, ...) to see something in the menus (LibFredo6 does not load otherwise)
                                        maruthi
                                        i am not able download ...please help me out... ๐Ÿ˜ž
                                          What happens when you want to download? Can you see the link at all?
                                          • N Offline
                                            nirve08
                                            ei guys, im still a new at using sketch-up, i search out for plugins, and i find this one interesting, i downloaded it, followed the instructions, but it didnt work, i have installed also the freescale 2.0..how do you install this one? i need a detail instruction like what folder or which folder to paste or install...many thanks
                                            • 100
                                            • 101
                                            • 102
                                            • 103
                                            • 104
                                            • 109
                                            • 110
                                            • 102 / 110
