    Ghost Files
    16 Posts 7 Posters 1.2k Views 7 Watching
    • Bryan KB
      Thanks to all. I didn't quite figure what the problem was, but I managed to do what I had set out to do in the first place (move my models to another folder) and everything is resolved.
      • honoluludesktopH
        honoluludesktop
        Good to see you found a solution. Don't know vista, but on a WinXP, if you right click any file or folder and select properties, you are given the option to change its attribute by "Read-only and Hidden" check boxes.
          Vista has this weird thing where it looks like you moved some files into a folder, BUT then because of permissions etc it puts them into a parallel 'compatibility files' folder - maybe that's where they went ?
          When you go back they are not there - they exist but in this other folder - there should be an indication of this on you window top-bar.
          • Dan RathbunD
            Dan Rathbun
            Did they keep this nutty thing for Windows 7 ??
            Sometimes a solution is to put files in the Shared Documents folder (sometimes called "All Users".)
            I'm not here much anymore.
            • B
              Builder Boy
              I know this picture is in Windows 7, but does it help?
              All my plugins
                I belive so. But I've never experienced it myself. Maybe because I run as an administrator with UAC off.
                • Chris FullmerC
                  Compatibility files is something that made so many tech-geeks so happy, about finally having a safe place for windows to put files it did not authorize. I believe it is similar to a system that Mac employs.
                  Everything I've ever seen of it just sucks. It has caused me much pain with my script writing (until I finally figured out how to force it to not make a Compatibility folder for my SketchUp installtion folder). But it still creeps up and causes compatibilty problems for people who try to install a script, not realizing they already had an odler version installed, "safely" tucked away in the compatibilty folder, where its completely out of sight. And yes, the two files can co-exist with the same name even though the system sort of considers them to be in the same location.
                  Anyhow, I dis-like the silly thing.
                  • Dan RathbunD
                    Dan Rathbun
                    I consider myself a tech-geek, and it sounds like a nightmare!
                    I hate having 2 files of different versions around.
                    • honoluludesktopH
                      honoluludesktop
                      Here is an explanation, and "partial" solution.
                      Thomas, When UAC off and as administrator, have you ever experienced a program having problems saving files?
                      • Dan RathbunD
                        Dan Rathbun
                        Reading about this, it makes me want (when I do get Win7,) to install Sketchup in C:\Google instead of the Programs folder. I wonder if that would work?
                          Nope.
