    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 1.8m Views 329 Watching
      rtgoogler
      You are probably tired of hearing this question...but I can't get Shape Bender to work on my Mac. Once I select the object to bend, run the script, then I can't select the line. I have redrawn it a couple of times to make sure my line is along the red axis. Help!!! Thanks,
      shapebendertest.skp
        Explode all many time for have no groups, no component
        then group
        that's works πŸ˜‰
        • TIGT Online
            rtgoogler
            Thanks Pilou and TIG. TIG...followed your instructions step by step. Still doesn't work for me. I am unable to select the line or the path. This tool would be perfect for a design idea I am working on, but I can't get it to work. In Library/Application Support/Google Sketchup 7/Sketchup/Plugins I placed these:
            progressbar.rb
            clf_shape_bender_loader.rb
            clf_shape_bender.rb
            Am I missing something? Anything I need to do in Sketchup to activate these scripts?
            Thanks in advance.
            • Chris FullmerC Offline
              Try opening the Ruby Console and then running the script. Lets see if it is giving any errors. On the PC, it is found in the Window menu. I do not know where it is on the Mac. But look through your menus and look for an option called "Ruby Console" or something approximately similar. Open that window, then select your component, then run th script. And try to select the line. It should either work or it should write some errors to the ruby console. If it gives errors, please copy and paste them all here into this thread. I'll take a look and see if there is something suspicious going on.
                keithver
                keithver wrote:
                Shape bender looks like the answer to a prayer. I've downloaded a "file.php". perhaps I'm being stupid. What do I do now
                Keith
                Hi Guys
                No matter which link on Chris's initial post I use, I get a file named 'file.php' in my download folder. I can't find a .zip file anywhere to download. Please! I'm desperate to try Shape Bender
                Keith
                  Hi Keith,
                  This happens sometimes with some browsers/browser settings (although I have most frequently seen it on the Mac).
                  Anyway, try to rename the php extension to zip and open the archive that way. Let us know if it still doesn't work (or if it does, too).
                    keithver
                    thanks Gaieus
                    No luck. I re-named but winzip doesn't recognize the file format. The .php file is only 6KB big?
                    keith
                    • TIGT Online
                      progressbar.rb
                      clf_shape_bender.rb
                      Thanks in advance.
                      The files progressbar.rb and clf.shape_bender_loader.rb go directly into the Plugins folder, but the other file(s) must be in a sub-folder called 'clf_shape_bender' that's in 'Plugins' as shown belowCapture.PNG
                      Remove any 'rogue' .rb files you have in the wrong location...
                      • X Offline
                        xrok1
                        @keithver said:
                        thanks Gaieus
                        keith
                        can you right click the download link and try open with ie, or open in a new window ?
                          keithver
                          Hi Tig
                          I can't even get the ZIP file, let alone un-zip it
                          Keith
                            Thanks Jeff! And Keith, I think TIG was replying to someone else who is having difficulties with where they put their files.
                            Good luck to everyone, and a big thanks to everyone who keeps chiming in to help!
                              keithver
                              Thanks everyone, especially Jeff for that link. I'M NOW A SHAPE BENDER!
                              • jeff hammondJ Offline
                                keith.
                                download here:
                                [link removed]
                                reply here when you get it so i can remove it from my iDisk.
                                  bouzzer
                                  Hi how do I instal the plug in?
                                    bouzzer
                                    Hi for some reason I cant select the line of the Red axis, can someone help me please?
                                    • TIGT Online
                                      As with almost all plugins...
                                      Unzip the folder extracting everything as it is in the zip.
                                      There should be a single .rb file and a folder with some other files inside it.
                                      Move the single .rb and the foldert into your SUp..Plugins folder and restart SUp.
                                      Activate the toolbar from Views or access it from the Plugins Menu [CLF sub-menu]...
                                        If you feel the plugin is installed correctly, and still can not select the red line, you might need to reset the model axis. The script only recognizes the original red axis. So try activating the select tool, then right click on the red axis and choose "Reset Axis". Then realign your items to be bent to that axis. If the option to reset axis is greyed out, then that means the axis already is correct, and the problem is something else. Good luck,
                                          tom1169
                                          Chris,
                                          I just downloaded "Component stringer" to my 7.1 Free Version and I put it in my plugins folder..
                                          Inside sketchup it shows under "Plugins" menu but when I highlight the component..it doesnt do anything...?
                                          Please help, does that only work on PRO...? Thank You ..
                                            --COMPONENT STRINGER ANSWER--
                                            Hi, make sure to select the component(s) AND the lines they will be strung onto. Then run the plugin. Please see the video in the component stringer thread. I'll try to move these two posts over to the component stringer thread later too so they do not interfere with the shape bender thread.
                                            http://forums.sketchucation.com/viewtopic.php?f=323&t=23616
                                            Thanks,
                                            • 48
                                            • 49
                                            • 50
                                            • 51
                                            • 52
                                            • 63
                                            • 64
                                            • 50 / 64
