    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.3m Views 329 Watching
      You must unzipp (uncompress) it before put it in the Plugins folder!
      http://en.wikipedia.org/wiki/ZIP_%28file_format%29
      In general Right click on the file / Extract to a name of folder
        Seems latest version of component Spray is here πŸ˜‰
        • K
          keithver
          Shape bender looks like the answer to a prayer. I've downloaded a "file.php". perhaps I'm being stupid. What do I do now
          Keith
            That is verious because when you unzip the file of the first post "clf_shape_bender_v055.zip" you must obtain one folder and one file rb πŸ˜‰
            Past all in the Plugins folder ❗
            PS Don't forgott the progress bar.rb file from Smustard if you have not yet! : direct link
              @keithver said:
              Keith
              That's the 'link' file - not the zip file you need!
              If you click on the link for the zip file your browser should ask you what you want to do with it - I'd save it to the Desktop.
              Then extract the files from the zip [don't drop-drop etc] - then as Pilou says, there should be a '.rb' file and a folder [which contains some other files]... put the .rb file and that folder into your SUp ../Plugins/ folder and restart SUP... πŸ˜‰
              • H
                huckrorick
                Thanks. Tried it. This version has no conflict with shape bender.
                Huck
                • Chris FullmerC
                  AWESOME!!! A HUGE thanks to Didier for looking into it again and posting the updated version. I will make sure to point everyone to the new version now. Thanks for looking into it,
                    It's the same with almost anything you are 'practiced at'.
                    Professional tennis players don't think about making that winning shot - they just 'do it'.
                    You click this, that and the other and something happens on your PC - you can't remember what you just did...
                    You drive to the shops and later when you think about it you can't remember doing it !
                    Years ago I lived in a suburb, accessed of a junction on an urban motorway. I moved away for over four years, then came back, but I bought a house in the next suburb off the M'way...
                    One day returning from work along the M'way, and deep in thought about the day, I found myself at my old front-door, having turned off one junction too soon and on auto-pilot I just 'drove home' - it happed to be the wrong home when I got outside - years later the hard-wired auto-response was still there !!!
                    We are great at switching on to 'automatic pilot'... πŸ˜’
                      August
                      @tig said:
                      @keithver said:
                      ... I've downloaded a "file.php". ... What do I do now?
                      That's the 'link' file - not the zip file you need! ...
                      Every once in a while I get hit with the reality of how many layers and layers and layers of this stuff are all nested together and we who use it every day jump between levels without thinking.
                      Applying the same thought to cars -- there was a time when it took two people to most easily start a car, one with a strong arm to crank the engine at the front, hoping to not break their arm if the engine kicks back, and one to operate the manual choke to cut back on the air as soon as the engine catches. Fast forward to today and automatic starters, automatic chokes, automatic transmissions, automatic seat adjustments and power mirrors. Now pick up a manual for a gasoline powered lawn mower and read the line, "The choke on the mower operates just like the choke on an automobile." And then pause to wonder who wrote that and how many of their readers ever drove an automobile with a manual choke. Did that line help or confuse?
                      This is just my long-way-around-the-barn way of saying to Keith, don't worry, there's nothing to be embarrassed about. Just ask. You did. Somebody answered. If the answer is not complete enough, ask again.
                      This is all ad-hoc conversation, no formal manuals, no marketing departments writing Getting Started guides. Just folks sharing something they love doing. And generally happy to help newbies find their way around.
                      To push the automobile metaphor, Plugins are like after-market kits. Yeah, they just pop into place, mostly, but it helps to have a clue how to use a wrench, or a buddy who can give advice, and it definitely helps to have an overview of how a car goes together so you have a clue what's what when you're shopping. Sometimes there's two of these add-on kits that you have trouble with because they both want to use the same mounting hole and you or the creators need to make some modifications so that both kits can be used at the same time.
                      For instance, Chris, a certified expert who also tries to stay on top of this forum, did not know that Didier, another expert, had posted a new version of his "kit" nearly two months ago, that fixed that "mounting bolt" conflict between their two kits that has had so many people upset. But it's fixed and folks know now, and word is going to get around, as long as people keep talking.
                      Sometimes the "kit" installation notes are less than perfect, sometimes you have to supply your own bolts and washers. But they are a lot of fun and allow you to do things you never could if you had to do it all from scratch.
                      For what it's worth, I hope it helps, (FWIW, IHIH)
                      August
                      β€œAn idea, like a ghost, must be spoken to a little before it will explain itself.”
                      [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
                        rtgoogler
                        You are probably tired of hearing this question...but I can't get Shape Bender to work on my Mac. Once I select the object to bend, run the script, then I can't select the line. I have redrawn it a couple of times to make sure my line is along the red axis. Help!!! Thanks,
                        shapebendertest.skp
                          Explode all many time for have no groups, no component
                          then group
                          that's works πŸ˜‰
                              rtgoogler
                              Thanks Pilou and TIG. TIG...followed your instructions step by step. Still doesn't work for me. I am unable to select the line or the path. This tool would be perfect for a design idea I am working on, but I can't get it to work. In Library/Application Support/Google Sketchup 7/Sketchup/Plugins I placed these:
                              progressbar.rb
                              clf_shape_bender_loader.rb
                              clf_shape_bender.rb
                              Am I missing something? Anything I need to do in Sketchup to activate these scripts?
                              Thanks in advance.
                              • Chris FullmerC
                                Try opening the Ruby Console and then running the script. Lets see if it is giving any errors. On the PC, it is found in the Window menu. I do not know where it is on the Mac. But look through your menus and look for an option called "Ruby Console" or something approximately similar. Open that window, then select your component, then run th script. And try to select the line. It should either work or it should write some errors to the ruby console. If it gives errors, please copy and paste them all here into this thread. I'll take a look and see if there is something suspicious going on.
                                • K
                                  keithver
                                  keithver wrote:
                                  Keith
                                  Hi Guys
                                  No matter which link on Chris's initial post I use, I get a file named 'file.php' in my download folder. I can't find a .zip file anywhere to download. Please! I'm desperate to try Shape Bender
                                  Keith
                                  • GaieusG
                                    Hi Keith,
                                    This happens sometimes with some browsers/browser settings (although I have most frequently seen it on the Mac).
                                    Anyway, try to rename the php extension to zip and open the archive that way. Let us know if it still doesn't work (or if it does, too).
                                    • K
                                      keithver
                                      thanks Gaieus
                                      No luck. I re-named but winzip doesn't recognize the file format. The .php file is only 6KB big?
                                      keith
                                        progressbar.rb
                                        clf_shape_bender.rb
                                        Thanks in advance.
                                        The files progressbar.rb and clf.shape_bender_loader.rb go directly into the Plugins folder, but the other file(s) must be in a sub-folder called 'clf_shape_bender' that's in 'Plugins' as shown belowCapture.PNG
                                        Remove any 'rogue' .rb files you have in the wrong location...
                                        • X
                                          xrok1
                                          @keithver said:
                                          thanks Gaieus
                                          keith
                                          can you right click the download link and try open with ie, or open in a new window ?
                                          • K
                                            keithver
                                            Hi Tig
                                            I can't even get the ZIP file, let alone un-zip it
                                            Keith
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 63
                                            • 64
                                            • 24 / 64
