    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.5m Views 329 Watching
    • GaieusG
      Hi Keith,
      This happens sometimes with some browsers/browser settings (although I have most frequently seen it on the Mac).
      Anyway, try to rename the php extension to zip and open the archive that way. Let us know if it still doesn't work (or if it does, too).
      • K
        keithver
        thanks Gaieus
        No luck. I re-named but winzip doesn't recognize the file format. The .php file is only 6KB big?
        keith
          @rtgoogler said:
          Thanks Pilou and TIG. TIG...followed your instructions step by step. Still doesn't work for me. I am unable to select the line or the path. This tool would be perfect for a design idea I am working on, but I can't get it to work. In Library/Application Support/Google Sketchup 7/Sketchup/Plugins I placed these:
          progressbar.rb
          clf_shape_bender_loader.rb
          clf_shape_bender.rb
          Am I missing something? Anything I need to do in Sketchup to activate these scripts?
          Thanks in advance.
          The files progressbar.rb and clf.shape_bender_loader.rb go directly into the Plugins folder, but the other file(s) must be in a sub-folder called 'clf_shape_bender' that's in 'Plugins' as shown belowCapture.PNG
          Remove any 'rogue' .rb files you have in the wrong location...
          • X
            xrok1
            @keithver said:
            thanks Gaieus
            keith
            can you right click the download link and try open with ie, or open in a new window ?
            • K
              keithver
              Hi Tig
              I can't even get the ZIP file, let alone un-zip it
              Keith
              • Chris FullmerC
                Thanks Jeff! And Keith, I think TIG was replying to someone else who is having difficulties with where they put their files.
                Good luck to everyone, and a big thanks to everyone who keeps chiming in to help!
                • K
                  keithver
                  Thanks everyone, especially Jeff for that link. I'M NOW A SHAPE BENDER!
                  • jeff hammondJ
                    keith.
                    download here:
                    [link removed]
                    reply here when you get it so i can remove it from my iDisk.
                    • B
                      bouzzer
                      Hi how do I instal the plug in?
                      • B
                        bouzzer
                        Hi for some reason I cant select the line of the Red axis, can someone help me please?
                          As with almost all plugins...
                          Unzip the folder extracting everything as it is in the zip.
                          There should be a single .rb file and a folder with some other files inside it.
                          Move the single .rb and the foldert into your SUp..Plugins folder and restart SUp.
                          Activate the toolbar from Views or access it from the Plugins Menu [CLF sub-menu]...
                          • Chris FullmerC
                            If you feel the plugin is installed correctly, and still can not select the red line, you might need to reset the model axis. The script only recognizes the original red axis. So try activating the select tool, then right click on the red axis and choose "Reset Axis". Then realign your items to be bent to that axis. If the option to reset axis is greyed out, then that means the axis already is correct, and the problem is something else. Good luck,
                            • T
                              tom1169
                              Chris,
                              I just downloaded "Component stringer" to my 7.1 Free Version and I put it in my plugins folder..
                              Inside sketchup it shows under "Plugins" menu but when I highlight the component..it doesnt do anything...?
                              Please help, does that only work on PRO...? Thank You ..
                              • Chris FullmerC
                                --COMPONENT STRINGER ANSWER--
                                Hi, make sure to select the component(s) AND the lines they will be strung onto. Then run the plugin. Please see the video in the component stringer thread. I'll try to move these two posts over to the component stringer thread later too so they do not interfere with the shape bender thread.
                                http://forums.sketchucation.com/viewtopic.php?f=323&t=23616
                                Thanks,
                                • V
                                  valence87
                                  Chris, any chance of a version that lets you bend around closed loops? That would make a great plugin even better 😄
                                  Cheers,
                                  Valence
                                  • Chris FullmerC
                                    I agree it would definitely make it even better. Unfortunately I just did not have the skillz to make it do that when I wrote it. When I do re-write it, that will be one of the main things to fix for sure. That and about a dozen other things. I am currently working slowly on about 5 scripts. If I could just knock them out of the way, I might finally be able to undertake re-writing this beast.
                                    • T
                                      TeKnoel
                                      Great update to one of my favorite plugins! Thanks Chris
                                        Judy Nielsen
                                        I also am having a problem selecting the red line. The plug in is there and seems to be activated. I tried resetting the red axis and the option was grayed out. I tried opening a new document created a rectangle, grouped it, created a parallel line on the red axis, created a curved line parallel to the rectangle. I then selected the rectangle but can not go any further. I am working on a mac. Any ideas? I would really like to use the Shape Bender plug in. I have to create multi curved tubing.
                                        Thanks for any help.
                                        Judy
                                          August
                                          @judy nielsen said:
                                          [... I then selected the rectangle but can not go any further. ...
                                          Just to be redundant, just in case:
                                          Select the group containing the rectangle, then select the Shape Bender tool.
                                          Then select the Guide Line, then the Target Line.
                                          I hope this helps.
                                          “An idea, like a ghost, must be spoken to a little before it will explain itself.”
                                          [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
                                          • Chris FullmerC
                                            Also you can upload your test model to the forum here and we can look at it and see if there is anything wrong with the set up. Once we determine if the model is correct, we can troubleshoot the rest of the script 😄
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 63
                                            • 64
                                            • 25 / 64
