    Crazy problem with Right Click
    53 Posts 14 Posters 13.4k Views 14 Watching
      At work I've been forced to diable most of my plugins - as that improve the situation. But the folder fill up as I need to re-add plugins as I need them.
        lapx
        This and the nomadic toolbar is amateur and should be fixed immediately 😑
        While im on my horse there needs to be better transition form cad circles to sketchup!
        What are these guy's at google doing all this time, playing ping pong!
        • soloS Offline
          Planning base camp 2011 Hawaii maybe? πŸ’š
            jhauswirth
            The problem is Ruby scripts are calling-
            UI::Command.new
            and not attaching the new command to a menu item.
            If you want to verify this run-
            for i in 0..1000 do
            cmd = UI::Command.new("Tester") { UI.messagebox("Hello World") }
            I can see Ruby scripts creating new commands on each right mouse click.
            Every new command creates a unique command ID in SU and there are only 1000
            command IDs available. Normally a command is attached to a menu and when
            the menu goes away the IDs are recycled, but since these commands are not
            attached to a menu, they don't get recycled.
            I'm going to try and figure out how to dump the list of commands (they have
            menu item text) so that people can see who's causing the problem.
              Ah! This is great news! πŸ‘ πŸ‘
              The Mighty Bug Hunt of 2010 is now officially open!
                ObjectSpace.each_object(UI::Command) {|x| p x }
                Gives you access to each UI::Command object. But the class has only setter methods defined. And instance_variables on an instance of UI::Command returns empty.
                  What is the command is used in both menus and toolbars? or just toolbars?
                  I often create an instance of a Command when both a menu and a toolbar is executing the same command.
                    jpalm32
                    [quote="thomthom":287u3y55]
                    Yeh! What ThomThom said.
                    Really! You guys scare me sometimes.
                    • jeff hammondJ Offline
                      interesting turn of events..
                      i've read a lot of these right-click posts and thought they were something to do with windows because i've never experienced the problem or heard of another mac user with the problem.
                      sounds like it should affect mac users as well then.. maybe none of the mac users here have the trouble ruby installed?
                      must be one of those windows specific exporters or something?
                      [edit] hmm.. well, except for the fact that it's been reproducible without using plugins at all ❓
                        By right clicking repeatedly on geometry without cancelling the menu. But the menus then usually returns ones you cancel it.
                          i shit you not, i just tried rightclicking on a square at least 800 times πŸ’š .. no glitches
                            Did you right click
                            and then while the menu was still open right click again?
                            (on the same entity)
                              Here's a little hack I made. It intercepts all the setter methods and prints the arguments to the console. Named "_0.rb" to make it load first. (or does underscore make it load last...?)
                              For some reason it is not overriding the initialize method.
                              But I do intercept the setter methods. On my home machine I get some output every time I right click:
                              tooltip: Scaling with orientation of scaling box tooltip: Tapering with orientation of scaling box tooltip: Planar Shearing with orientation of scaling box tooltip: Planar Shearing by selection of plane and angle tooltip: Stretching with orientation of scaling box tooltip: Twisting with orientation of scaling box tooltip: Rotation with orientation of scaling box tooltip: Rotation by selection of plane and angle tooltip: Radial Bending by selection of plane and angle tooltip: Make Groups and Components Unique
                              And when I do this line for every right click:
                              c=[]; ObjectSpace.each_object(UI::Command) {|x| c << x }
                              the count goes up by 10 - one for each tooptip.
                              So in my case, even though I'm not catching the new method, it does appear that I've accounted for every leak. There might be other plugins that does not set any other methods when it creates a new Command object, so I'm not sure how to catch that since I can't hook into initialize.
                              As for the tooltips, they are from FredoScale, right?
                              _0.rb
                                yes..
                                drew a rectangle then started right-clicking repeatedly on its face.. (didn't do anything else other than those two steps.. no left-clicking,selecting, or moving the mouse pointer etc.)
                                  yes..
                                  drew a rectangle then started right-clicking repeatedly on its face.. (didn't do anything else other than those two steps.. no left-clicking,selecting, or moving the mouse pointer)
                                  You must be charmed.
                                    ha..
                                    but like i said earlier, i've never seen a mac user state this problem.. maybe this is one area where windows and osx are different with SU?
                                      Ah, you're on an apple. So you said. And so it says in your profile.
                                      It's late. G'night! πŸ˜‰
                                      • EarthMoverE Offline
                                        EarthMover
                                        I've been able to reproduce my right click issues with consistency. I've narrowed down the problem to exploding groups and it seems to occur when I use my keyboard shortcut specifically.
                                        If someone could try and reproduce my results -
                                        1. Open new sketchup
                                        2. Make a Box
                                        3. Use keyboard shortcut to make the box a group
                                        4. Use keyboard shortcut to explode box
                                        5. Repeat step 3 & 4 - 15 times
                                        6. Check the right click menu during 5 more group & explodes
                                        I've tested the above 5 times in new SU sessions and everytime I get the same results. Right click menu goes gray between 15-20 group & explodes via keyboard shortcut.
                                        Interestingly I also tested doing 20 right click group and explodes and the menu didn't gray out, however after doing just one group and explode with the keyboard shortcut, my menu immediately went gray.
                                        Test with Shortcuts - http://www.screencast.com/t/MTVkNDBi
                                        Test with Right click Group & Explode - http://www.screencast.com/t/ZDFiMDRmM
                                        Content Creator at Skapeup
                                          Jim
                                          UI::Command.new
                                          Correct, we are not typically attaching Commands to menus because Menu.add_item will accept a block of code as well as a Command. So unless a Toolbar is also being created, it is typical to just pass the name of a method to Menu.add_item:
                                          def method_name
                                            # do sometrhing
                                          menu = UI.menu.add_item("Menu Text") { method_name }
                                          When a Toolbar is being used, we are required to create a Command becuase Toolbar.add_item only accepts a Command. So when there is a Toolbar already being used, it is easy to add the same Command to a menu since it is already created.
                                          I think it is also not typical to create a new Command when adding a context menu. Are we sure SketchUp (Ruby) is not promoting code blocks into Commands? (Is that even possible? πŸ˜• )
                                            jhauswirth
                                            There was another bug regarding recycling menu IDs. This was caused by the app not being able to execute OnIdle because the context menu was constantly being popped up. I didn't mention this issue because once OnIdle got a chance to do its business all the menu items came back to life. All the issues I've seen would be Windows only.
                                            • 1 / 3
