    [Plugin] Extrude Edges by Rails to Lattice
    73 Posts 25 Posters 100.9k Views 25 Watching
    • Chris FullmerC Offline
      Hehe, TIG, I also used it to make that same shape last night. It was very easy to do. But I noticed a few things. The extrude by face by rails that I tried first did not ever allow me to have the triangulation. It just cleaned it up automatically, or else never even put it in place - I'm not sure which.
      But this lattice one did add the triangulation, but only if I chose to use a 3d shape. If I just did a line, then it never add the triangulation.
      I wouldn't mind ALWAYS having the option to keep the triangulation.
      Seriously awesome stuff TIG, keep it up!
        To get a full mesh that's triangulated use plain 'EEbyRails'.
        When the mesh done don't smooth it etc.
        Then you edit the mesh-group and select all, then deselect the edges [there are various tools to do this - I have my own but thomthom's selection-toys works well...].
        Delete the faces - now you have the full mesh with triangles make from lines only...
        The tool 'EEbyRailsToLattice' was written to do a 3D lattice or the profiles/rails rib-lines as simple separated curves - so you can use them for other things - like 'EEbyFace' using different profiles for different parts...
          DIEGO-RODRIGUEZ
          Tig, plugins excellent. Thank you very much for their continued contributions and new ideas.
          The plugin works perfect.
          I use latest version of sketchup in Spanish and windows XP sp3 in Spanish
          Only I make two suggestions
          **a - You can place the panels and the Mesh into separate layer or different groups?
          b - could change the names of the . lingvo, add a number.
          It is easier to delete files that are not used
          example:
          01 - extrudeEdgesByLoftEN-US.lingvo
          02 - extrudeEdgesByLoftES.lingvo
          03 - extrudeEdgesByLoftFA.lingvo
          04 - extrudeEdgesByLoftFR.lingvo
          05 - extrudeEdgesByLoftZH-CN.lingvo
          01 - extrudeEdgesByRailsEN-US.lingvo
          02 - extrudeEdgesByRailsES.lingvo
          03 - extrudeEdgesByRailsFA.lingvo
          04 - extrudeEdgesByRailsFR.lingvo
          05 - extrudeEdgesByRailsZH-CN.lingvo
          • Didier BurD Offline
            Didier Bur
            Hi TIG,
            Here is the french lingvo file.
            You're making great progress in french, just several typos were remaining 😉
            Best regards,
            extrudeEdgesByRailsToLatticeFR.zip
            DB
              Thanks Didier, Pilou also just did one - I'll make a compilation of both... 😄
                New zipped set is now available [ http://forums.sketchucation.com/viewtopic.php?p=242239#p242239 ], with minor tweaks to text for lingvo files. New ES=Defisto and FR=DidierBur + Pilou. Flat faces at z=0 are now auto-reversed.
                  The script in the zipped set has been updated...
                  'Face.offset' is now reworked to be more robust and 'in class'
                  [i.e. now offset.rb is not needed].
                  Panes now get the 'back_material'.
                    Tip
                    You are prompted to erase coplanar edges if the faces can survive without triangulation divisions.
                    To ensure that you get 'flat' quad faces make sure that the profiles and rails are identical [perhaps copy them].
                    Here is one with the coplanar triangulation left in...Capture.PNG This one had them erased before the lattice was made...Capture1.PNG
                      That rules now 👍 😎
                            http://forums.sketchucation.com/download/file.php?id=47505
                              saturne45
                              • olisheaO Offline
                                olishea
                                this is seriously amazing! been playing with it for hours now! just a question TIG: is there a way to group separately the "glass panes" from the frame? so the frame is one group and the panes are another...... 😕
                                oli
                                • N Offline
                                  notareal
                                  Wow, you did it again!
                                  Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                                    Give the frames and panes different colors - say 'red' and 'glass'.
                                    Edit the group and select a pane.
                                    Right-click Context-menu > Select > All with same Material...
                                    All the panes are selected, Right-click Context-menu > Group.
                                    Repeat for the frames.
                                    You now have the original lattice group that contains two sub-groups - one for the panes the other for the frames.
                                    Re-color them as desired.
                                    One of the reasons I gave a limited 'rainbow' of colors+glass was to avoid long material lists in the dialog which always causes grief when the color you want is off the screen... and as explained above you can always select everything by a material and apply any color/material onto them that you like later on... 🤓
                                    • simon le bonS Offline
                                      simon le bon
                                      playing:
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_011_th.jpg
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_012_th.jpg
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_013_th.jpg
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_014_th.jpg
                                      I don't see how I could do the same with else tools ❓
                                      *s
                                        Maybe 2 faces + path + FFD(or fredoscale) 😉
                                          simon le bon
                                          Thank you so much Dear Tig for this new amazing tool. 👍 👍
                                          @tig said:
                                          Tip
                                          Pretty good tip!
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_001_th.jpg
                                          I wanted to tell this one, but I'm outstripped by TIG 😄
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_002_th.jpg
                                          another interesting result is to adjust the depth to 0 in order to get a flat frame
                                          (and use soften & smooth for a simple aspect)
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_003_th.jpg
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_004_th.jpg
                                          Extrude Edges by Rails to Lattice + ExtrudeEdgesBy2Faces
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_005_th.jpg
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_006_th.jpg
                                          Extrude Edges by Rails to Lattice + ExtrudeEdgesByEdges
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_007_th.jpg
                                          Extrude Edges by Rails to Lattice + ExtrudeEdgesByEdges + ExtrudeEdgesByRailsByFace
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_008_th.jpg
                                          Extrude Edges by Rails to Lattice + Chris Fullmer tools
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_009_th.jpg
                                          Extrude Edges by Rails to Lattice + Didier Bur "lines to tubes" (with and without EEbRtL)
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_010_th.jpg
                                          etc.. etc..
                                          Vast possibilities 👍 👍
                                          %(#0000BF)[Dear TIG, may I comment ? 😕
                                          -Extrude Edges by Rails to Lattice uses only ExtrudeEdgesByEdges. I would be really cool if we would be able to pick curves the same starting from ExtrudeEdgesByLoft and also from ExtrudeEdgesBy2Faces or from ExtrudeEdgesByLathe !
                                          -Do you think it would be possible to select also the diagonal curves family?]
                                          with my friendly respect, simon.
                                            Here's an update http://forums.sketchucation.com/viewtopic.php?p=242239#p242239
                                            It now has 'Diagonals' as an option.
                                            Reversing the order of picking the Rails swaps the direction of the diagonals.
                                            The lingvo files have been updated to match.
                                            • 2 / 4
