    [Plugin] Extrude Edges by Rails to Lattice
    73 Posts 25 Posters 100.9k Views 25 Watching
      d12dozr
      @utiler said:
      I wish I could express in words what your efforts and generousity to this community means, TIG......
      +1
      Well said...thanks TIG!
      http://goo.gl/f7ooYh
        • olisheaO Offline
          olishea
          this looks really really tasty!
          thanks infinitely! gonna have a play now. man ive been waiting for something like this for quite a while!
          oli
            The new paracloud modeler by TIG πŸ˜‰
              I'll write that before dinner ?
              • Chris FullmerC Offline
                Hehe, TIG, I also used it to make that same shape last night. It was very easy to do. But I noticed a few things. The extrude by face by rails that I tried first did not ever allow me to have the triangulation. It just cleaned it up automatically, or else never even put it in place - I'm not sure which.
                But this lattice one did add the triangulation, but only if I chose to use a 3d shape. If I just did a line, then it never add the triangulation.
                I wouldn't mind ALWAYS having the option to keep the triangulation.
                Seriously awesome stuff TIG, keep it up!
                  To get a full mesh that's triangulated use plain 'EEbyRails'.
                  When the mesh done don't smooth it etc.
                  Then you edit the mesh-group and select all, then deselect the edges [there are various tools to do this - I have my own but thomthom's selection-toys works well...].
                  Delete the faces - now you have the full mesh with triangles make from lines only...
                  The tool 'EEbyRailsToLattice' was written to do a 3D lattice or the profiles/rails rib-lines as simple separated curves - so you can use them for other things - like 'EEbyFace' using different profiles for different parts...
                  πŸ€“
                    DIEGO-RODRIGUEZ
                    Tig, plugins excellent. Thank you very much for their continued contributions and new ideas.
                    The plugin works perfect.
                    I use latest version of sketchup in Spanish and windows XP sp3 in Spanish
                    Only I make two suggestions
                    **a - You can place the panels and the Mesh into separate layer or different groups?
                    b - could change the names of the . lingvo, add a number.
                    It is easier to delete files that are not used
                    example:
                    01 - extrudeEdgesByLoftEN-US.lingvo
                    02 - extrudeEdgesByLoftES.lingvo
                    03 - extrudeEdgesByLoftFA.lingvo
                    04 - extrudeEdgesByLoftFR.lingvo
                    05 - extrudeEdgesByLoftZH-CN.lingvo
                    01 - extrudeEdgesByRailsEN-US.lingvo
                    02 - extrudeEdgesByRailsES.lingvo
                    03 - extrudeEdgesByRailsFA.lingvo
                    04 - extrudeEdgesByRailsFR.lingvo
                    05 - extrudeEdgesByRailsZH-CN.lingvo
                    • Didier BurD Offline
                      Didier Bur
                      Hi TIG,
                      Here is the french lingvo file.
                      You're making great progress in french, just several typos were remaining πŸ˜‰
                      Best regards,
                      extrudeEdgesByRailsToLatticeFR.zip
                      DB
                        Thanks Didier, Pilou also just did one - I'll make a compilation of both... πŸ˜„
                          New zipped set is now available [ http://forums.sketchucation.com/viewtopic.php?p=242239#p242239 ], with minor tweaks to text for lingvo files. New ES=Defisto and FR=DidierBur + Pilou. Flat faces at z=0 are now auto-reversed.
                          πŸ€“
                            The script in the zipped set has been updated...
                            'Face.offset' is now reworked to be more robust and 'in class'
                            [i.e. now offset.rb is not needed].
                            Panes now get the 'back_material'.
                              Tip
                              You are prompted to erase coplanar edges if the faces can survive without triangulation divisions.
                              To ensure that you get 'flat' quad faces make sure that the profiles and rails are identical [perhaps copy them].
                              Here is one with the coplanar triangulation left in...Capture.PNG This one had them erased before the lattice was made...Capture1.PNG
                                That rules now πŸ‘ 😎
                                      πŸ˜‰
                                      http://forums.sketchucation.com/download/file.php?id=47505
                                        saturne45
                                        • olisheaO Offline
                                          olishea
                                          this is seriously amazing! been playing with it for hours now! just a question TIG: is there a way to group separately the "glass panes" from the frame? so the frame is one group and the panes are another...... πŸ˜•
                                          oli
                                          • N Offline
                                            notareal
                                            Wow, you did it again!
                                            Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                                            • 1 / 4
