    [Plugin] Extrude Edges by Rails to Lattice
    73 Posts 25 Posters 103.4k Views 25 Watching
    • olisheaO
      olishea
      this looks really really tasty!
      thanks infinitely! gonna have a play now. man ive been waiting for something like this for quite a while!
      oli
        The new paracloud modeler by TIG ๐Ÿ˜‰
          I'll write that before dinner ?
          ๐Ÿคฃ
          • Chris FullmerC
            Hehe, TIG, I also used it to make that same shape last night. It was very easy to do. But I noticed a few things. The extrude by face by rails that I tried first did not ever allow me to have the triangulation. It just cleaned it up automatically, or else never even put it in place - I'm not sure which.
            But this lattice one did add the triangulation, but only if I chose to use a 3d shape. If I just did a line, then it never add the triangulation.
            I wouldn't mind ALWAYS having the option to keep the triangulation.
            Seriously awesome stuff TIG, keep it up!
              To get a full mesh that's triangulated use plain 'EEbyRails'.
              When the mesh done don't smooth it etc.
              Then you edit the mesh-group and select all, then deselect the edges [there are various tools to do this - I have my own but thomthom's selection-toys works well...].
              Delete the faces - now you have the full mesh with triangles make from lines only...
              The tool 'EEbyRailsToLattice' was written to do a 3D lattice or the profiles/rails rib-lines as simple separated curves - so you can use them for other things - like 'EEbyFace' using different profiles for different parts...
              ๐Ÿค“
                DIEGO-RODRIGUEZ
                Tig, plugins excellent. Thank you very much for their continued contributions and new ideas.
                The plugin works perfect.
                I use latest version of sketchup in Spanish and windows XP sp3 in Spanish
                Only I make two suggestions
                **a - You can place the panels and the Mesh into separate layer or different groups?
                b - could change the names of the . lingvo, add a number.
                It is easier to delete files that are not used
                example:
                01 - extrudeEdgesByLoftEN-US.lingvo
                02 - extrudeEdgesByLoftES.lingvo
                03 - extrudeEdgesByLoftFA.lingvo
                04 - extrudeEdgesByLoftFR.lingvo
                05 - extrudeEdgesByLoftZH-CN.lingvo
                01 - extrudeEdgesByRailsEN-US.lingvo
                02 - extrudeEdgesByRailsES.lingvo
                03 - extrudeEdgesByRailsFA.lingvo
                04 - extrudeEdgesByRailsFR.lingvo
                05 - extrudeEdgesByRailsZH-CN.lingvo
                • Didier BurD
                  Didier Bur
                  Hi TIG,
                  Here is the french lingvo file.
                  You're making great progress in french, just several typos were remaining ๐Ÿ˜‰
                  Best regards,
                  extrudeEdgesByRailsToLatticeFR.zip
                  DB
                    Thanks Didier, Pilou also just did one - I'll make a compilation of both... ๐Ÿ˜„
                      New zipped set is now available [ http://forums.sketchucation.com/viewtopic.php?p=242239#p242239 ], with minor tweaks to text for lingvo files. New ES=Defisto and FR=DidierBur + Pilou. Flat faces at z=0 are now auto-reversed.
                      ๐Ÿค“
                        The script in the zipped set has been updated...
                        'Face.offset' is now reworked to be more robust and 'in class'
                        [i.e. now offset.rb is not needed].
                        Panes now get the 'back_material'.
                          Tip
                          You are prompted to erase coplanar edges if the faces can survive without triangulation divisions.
                          To ensure that you get 'flat' quad faces make sure that the profiles and rails are identical [perhaps copy them].
                          Here is one with the coplanar triangulation left in...Capture.PNG This one had them erased before the lattice was made...Capture1.PNG
                            That rules now ๐Ÿ‘ ๐Ÿ˜Ž
                                  ๐Ÿ˜‰
                                  http://forums.sketchucation.com/download/file.php?id=47505
                                    saturne45
                                    • olisheaO
                                      olishea
                                      this is seriously amazing! been playing with it for hours now! just a question TIG: is there a way to group separately the "glass panes" from the frame? so the frame is one group and the panes are another...... ๐Ÿ˜•
                                      oli
                                      • N
                                        notareal
                                        Wow, you did it again!
                                          Give the frames and panes different colors - say 'red' and 'glass'.
                                          Edit the group and select a pane.
                                          Right-click Context-menu > Select > All with same Material...
                                          All the panes are selected, Right-click Context-menu > Group.
                                          Repeat for the frames.
                                          You now have the original lattice group that contains two sub-groups - one for the panes the other for the frames.
                                          Re-color them as desired.
                                          One of the reasons I gave a limited 'rainbow' of colors+glass was to avoid long material lists in the dialog which always causes grief when the color you want is off the screen... and as explained above you can always select everything by a material and apply any color/material onto them that you like later on... ๐Ÿค“
                                          • simon le bonS
                                            simon le bon
                                            playing:
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_011_th.jpg
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_012_th.jpg
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_013_th.jpg
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_014_th.jpg
                                            I don't see how I could do the same with else tools โ“
                                            *s
                                            • 1 / 4
