    [Plugin] Component Spray Tool 1.3.
    92 Posts 44 Posters 102.2k Views 44 Watching
      denna003
      THAnk you very much!!!! ๐Ÿ˜‰
        AcesHigh
        Didier, is this the last version of your tool?
        Can I make a suggestion? It seems the altitude option is too "hard". I mean, I think you could add some dialogue to add a % of chance that components will spray below and above the maximum altitude. That way, they will concentrate on the set altitude, but some of them will spread casually beyond (unless you set the chance of that happening to 0%)
          tomislavm
          Thank You!
          Where in Croatia?
            madhav
            Thanks a lot
            • Didier BurD Offline
              Didier Bur
              Where in Croatia?
              Pisak, that's 40kms South of Split and 20kms North of Makarska.
              DB
                tomislavm
                Nice place for vacation!
                  alsenhawk
                  Thank you,that's what i m looking~
                    arjunmax09
                    @rv1974 said:
                    Didier thanks for your efforts!
                    One can get interesting things with new vertice mode.
                    http://img212.imageshack.us/img212/6828/screenshot060qi3.jpg
                    [URL=http://g.imageshack.us/g.php?h=212&i=screenshot060qi3.jpg][IMG]http://img212.imag
                    But there's bug in vertex+no to keep vertical . It's not working (see lonely cylinder over mesh, in all other cases components stay vertical)
                    To "keep vertical" unchecked will result the component to be placed vertical to mesh, it'll work this way, right?
                    P.S. I'm not programmer (my wife is- it's enough for one family) but you're one step from "spray along vertices of curve" ? ๐Ÿ˜‰
                    P.P.S. Do you shine in ruby field only or there are some lisp routins of yours?
                    hey!!! how did you create the cool DNA model man???!!!... i mean the perfect spiral thing... which plugin did you use???
                    when you fail at something....you haven't really failed...you've found one way the thing will not work out
                      Didier Bur
                      I was used to code in Autolisp years ago, and now I'm learning Javascript along with Unity3D. ๐Ÿ˜›
                      Regards
                      DB
                        arjunmax09
                        didier... your compo spray is interfering with the progressbar script.. any improvements you've made to compo spray so that it doesn't do the progressbar thing??
                          Didier Bur
                          I though I had done this several monthes ago, but just in case see page 1 of this thread and download the latest version. The spray uses its own progress bar class named "sprayprogressbar", so there should not be any conflict with other plugin(s).
                          If the problem persists, not my fault anymore ๐Ÿ˜‰
                          Regards,
                          DB
                            arjunmax09
                            um.. didier ... there's no ruby file in the latest update... there's one rbs file and one pdf file... where did the plugin go man...??? ๐Ÿ˜’ The rbs file is in the following folder.....
                            Utilisateurs\Bur\Exercices\Ruby\Component_airbrush
                            checked both the english and french versions.. both the archives contain the same files....please help... ๐Ÿ˜ž
                            • Chris FullmerC Offline
                              .rbs is a plugin. It is the extension put on encrypted plugins.
                              Didier, we are running into problems where it appears that this script is breaking progressbar again. I know you fixed it up perfectly quite a while ago. did it revert back somehow to a version that no longer works? Or do you think that it should still be working correctly and that perhaps it is something else messing up progressbar? Any thoughts?
                                maymay
                                I get an error when SketchUp starts:
                                Error Loading File compo_spray.rb
                                C;/Program Files/Google/Google SketchUp 6/Plugins/compo_spray.rb;1; no .<digit> floating literal anymore; put 0 before dot
                                RBS1.0
                                C;/Program Files/Google/Google SketchUp 6/Plugins/compo_spray.rb;1; syntax error
                                RBS1.0
                                C;/Program Files/Google/Google SketchUp 6/Plugins/compo_spray.rb;1; Invalid char `\030' in expression
                                Any ideas? I'd really like to try this out.
                                  Didier Bur
                                  Hem, hem, it seems we have some problems with the scrambler now...
                                  I've uploaded the latest RB version, in which there's NO progressbar class. I suppose there's a conflict with another plugin than this one.
                                  Sorry for the inconvenience with the RBS.
                                  Regards,
                                  DB
                                    rangrstudio
                                    Hi I'm trying to install this on Mac with Sketchup 7.
                                    The compo_spray.rb is in the Plugins folder, but I'm not seeing it in the plugins menu. Have reinstalled SKP 7 from scratch, then unzipped the zip file in the plug-ins folder per instructions but nothing.
                                    Is it not mac compatible?
                                    EDIT: I tried it on a windows machine (XP with SKP 7) and I couldn't get it to work there either. The zip contains "compo_spray.rb" and the pdf file. Is there something missing? Thanks for any help.
                                      If you read the PDF help file you'd see that Component Spray Tool is accessed from a pop-out menu in Draw Menu NOT the Plugins Menu !CStool.png
                                        rangrstudio
                                        @tig said:
                                        If you read the PDF help file you'd see that Component Spray Tool is accessed from a pop-out menu in Draw Menu NOT the Plugins Menu ![attachment=0:2qfvuyqu]<!-- ia0 -->CStool.png<!-- ia0 -->[/attachment:2qfvuyqu]
                                        Thank you! I guess I should read the whole manual...
                                        This is an amazing tool.
                                        • FrederikF Offline
                                          Frederik
                                          This is a GREAT tool...
                                          Would it be possible to make an option, where components sprayed don't intersect with each other...??
                                          It's possible to prevent stacking, but I miss an option, where components don't intersect also...
                                          Perhaps even an option, where I can define how close components can be to each other...
                                          Could have both positive and negative entries...
                                          Any ideas...??
                                          Cheers
                                          Kim Frederik
                                          • soloS Offline
                                            Yes please, I have the same issue where I need to mass some proxies but the boxes I'm using are all stacked and intersecting, maybe a collision checkbox?
                                            • 3 / 5
