    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 592 Posters 13.7m Views 594 Watching
    • fredo6F
      @gogle sketchup said:
      Hi, Fredo.
      Thanks for all your stuff. I have to tell you about a problem from my computer. I extracted all folders as you tell but Sketchup gives an arror like this:
      """Cannot load plugin FredoScale because the script cannot create DEFRAPAM_Dir folder in:
      "C:/Program Files/Google/Google Sketchup 7/Plugins"
      Please create it manually, respecting the case"""
      It gives the same error for all your plugins. I didn't understand the problem.
      Sorry for disturbing, and thank you...
      It is a problem of Access Right to your C:\Program Files drive with Vista. The plugin creates this folder to store default parameters. Try to create it manually. You may also want to disable high protection level for the Plugin folder C:/Program Files/Google/Google Sketchup 7/Plugins.
        stoop-it
        hi,
        I can't seem to get this plug in to work..... it has been downloaded as instructed but i cant seem to find the ruby in sketchup... did i miss something.... sometimes my name explains my problems
        thank you
          stoop-it
          Hey Fredo,
          thank you very much!!!!! you are dead on!!!!!!!! this works Awesome.... 👍 😍 🤣 😆
          • mitcorbM
            mitcorb
            If I can offer some insight:
            LibFredo3.4b is a helper file for many of Fredo's tools. It does not perform any magic on stage. It operates behind the curtains.
            Which tool do you wish to download?
            There is FredoScale, Tools on Surface, Bezierspline and others.
              monmonred
              Hey there! i extracted both the FredoScale.0h and LibFredo6 3.4b rar files to the plugins folder of sketchup but i cant seem to figure out how to make it work. i tried reinstalling sketchup, and even tried both version 7.0 and version 7.1 but it still doens't work. i even removed all the other plugins then re-extract the files but still it wont work. i really need help here man.
              the following just pops-up whenever i load sketchup:
              Error Loading File D:/Karlo's Folder/Programs & Softwares/Google SketchupPro7/Plugins/FREDOSCALE_Dir_20/__loader.rb
              (eval):1:in module_eval': compile error (eval):1: syntax error module Traductor ;Traductor::T6Mod.enable(self, 'D:/Karlo's Folder/Programs & Softwares/Google SketchupPro7/Plugins/LIBFREDO6_Dir_34', 'LibFredo6') ; MYDEFPARAM = MYPLUGIN.create_def_param(self) ; SU_MAJOR_VERSION = (Sketchup.version[0..0]).to_i ; PC_OR_MAC = (RUBY_PLATFORM =~ /darwin/i) ? 'MAC' : 'PC' ;end ^ (eval):1: syntax error module Traductor ;Traductor::T6Mod.enable(self, 'D:/Karlo's Folder/Programs & Softwares/Google SketchupPro7/Plugins/LIBFREDO6_Dir_34', 'LibFredo6') ; MYDEFPARAM = MYPLUGIN.create_def_param(self) ; SU_MAJOR_VERSION = (Sketchup.version[0..0]).to_i ; PC_OR_MAC = (RUBY_PLATFORM =~ /darwin/i) ? 'MAC' : 'PC' ;end ^ (eval):1: syntax error module Traductor ;Traductor::T6Mod.enable(self, 'D:/Karlo's Folder/Programs & Softwares/Google SketchupPro7/Plugins/LIBFREDO6_Dir_34', 'LibFredo6') ; MYDEFPARAM = MYPLUGIN.create_def_param(self) ; SU_MAJOR_VERSION = (Sketchup.version[0..0]).to_i ; PC_OR_MAC = (RUBY_PLATFORM =~ /darwin/i) ? 'MAC' : 'PC' ;end ^ (eval):1: syntax error module Traductor ;Traductor::T6Mod.enable(self, 'D:/Karlo's Folder/Programs & Softwares/Google SketchupPro7/Plugins/LIBFREDO6_Dir_34', 'LibFredo6') ; MYDEFPARAM = MYPLUGIN.create_def_param(self) ; SU_MAJOR_VERSION = (Sketchup.version[0..0]).to_i ; PC_OR_MAC = (RUBY_PLATFORM =~ /darwin/i) ? 'MAC' : 'PC' ;end ^ (eval):1: syntax error module Traductor ;Traductor::T6Mod.enable(self, 'D:/Karlo's Folder/Programs & Softwares/Google SketchupPro7/Plugins/LIBFREDO6_Dir_34', 'LibFredo6') ; MYDEFPARAM = MYPLUGIN.create_def_param(self) ; SU_MAJOR_VERSION = (Sketchup.version[0..0]).to_i ; PC_OR_MAC = (RUBY_PLATFORM =~ /darwin/i) ? 'MAC' : 'PC' ;end ^ (eval):1: syntax error module Traductor ;Traductor::T6Mod.enable(self, 'D:/Karlo's Folder/Programs & Softwares/Google SketchupPro7/Plugins/LIBFREDO6_Dir_34', 'LibFredo6') ; MYDEFPARAM = MYPLUGIN.create_def_param(self) ; SU_MAJOR_VERSION = (Sketchup.version[0..0]).to_i ; PC_OR_MAC = (RUBY_PLATFORM =~ /darwin/i) ? 'MAC' : 'PC' ;end ^ (eval):1: unterminated string meets end of file (eval):1: syntax error module Traductor ;Traductor::T6Mod.enable(self, 'D:/Karlo's Folder/Programs & Softwares/Google SketchupPro7/Plugins/LIBFREDO6_Dir_34', 'LibFredo6') ; MYDEFPARAM = MYPLUGIN.create_def_param(self) ; SU_MAJOR_VERSION = (Sketchup.version[0..0]).to_i ; PC_OR_MAC = (RUBY_PLATFORM =~ /darwin/i) ? 'MAC' : 'PC' ;end ^Error Loading File ZLoader__FredoScale.rb (eval):1:in module_eval': compile error
              THANKS SO MUCH!!!
              +Greatness may be measured on how much we have lost for the betterment of mankind+
              • fredo6F
                It seems to be a wrong installation. Please check the file and folder footprint, as indicated in the main posts and in the doc.
                By the way, you refer to .rar archive. I only publish my plugins as .zip archives. Did you get them from another source than Sketchucation?
                  agamemnus
                  Ok, I don't know exactly what's wrong but I am guessing it has to do with memory (undo/redo interference?) and/or interference with other functions. As I posted before, when I have this library active (the loader is in plugins), my flip, rotate, and group tools gradually become greyed out. The "greying-out" happens a lot faster on bigger models.
                  This can happen when I don't use any library functions, either.
                  • fredo6F
                    I think the greying out of menus may happen anyway. I have seen a bug report about this issue in SU7 and 7.1
                    To all users : is this something you experience as well, and is it in relation with LibFredo6?
                    • E
                      emperorgus
                      i've read all the posts of this thread...
                      i'm on a macbook pro
                      mac osX 10.6.2
                      I've put all the right things in their right place
                      libfredo6.rb --> plugins folder
                      lib6*.rb --> in plugins folder
                      and when i open sketchup 7 i get this :
                      Error Loading File Lib6Tool.rb
                      uninitialized constant Traductor::T6
                      someone have an idea of what is going on ??
                      and while im here is there a description of what all the script included in the version 3.4 of your library do??
                      thx to fredo who is really patient and helpfull to all!!
                      • fredo6F
                        mac osX 10.6.2
                        This is a wrong installation. Please read the the post and PDF documentation where you have the footprint of the plugin. basically, you should never copy or rename files manually. Just unzip the provided archive into the Sketchup Plugins folder. It should create ONE folder (FREDOSCALE_DIR_20 and ONE small file ZLoader_Fredoscale.rb. same for LibFredo6 (LIBFREDO6_Dir_34 and LibFredo6.rb)
                        • B
                          ByKAz
                          Hi I'm a Mac osx Leopard user and I proceed with the download and the installation following the manual and after done I can't see the LibFredo settings on the SU Windows menu.
                          Anybody have experienced the same, have some different trick for Mac users installation?
                          Thanks.
                          I found what I'm doing wrong, first of all after install the LibFredo i was trying to open on SU windows menu, no way... You must need install another Fredo plugin to work the LibFredo, After I realize that I go ahead and install FredoScale, after download both you have to copy/paste in both cases the folders (LibFredo6_Dir_34 and Fredoscale_Dir_20) and the (LibFredo6.rb and Zloader_Fredoscale.rb) inside the MacHD/Library,Application Support/GoogleSketchup7/plugins/
                          But the trick is that both file.rb need to be inside its respective folders.
                          After I did it, I open the SU and there it is, both working properly...
                          The FredoScale is really good, Thanks Fredo!
                            shant1987
                            guys i've tried installing it a thousand times and no use! i'm moving the folder LIBFREDO6_Dir_34 & file LibFredo6.rb to /Library/Application Support/Google SketchUp 7/SketchUp/plugins
                            when i open sketchup the plugin is nowhere to be found..what am i doing wrong!? I'm on a Mac 10.6.3 and sketchup version 7 (7.0.8656) ❓
                            • C
                              chrisdell
                              mac osX 10.6.2
                              emperorgus,
                              If you figure it out let me know how you did, I've been trying on and off for weeks and I can't figure out what file goes where or what file to install first, or what pdf has the bit of needed information you need to get this plugin to work.
                              This may be the best plugin ever, but it's also the worst set of install instructions ever.
                              • fredo6F
                                Chris and emperorgus
                                You did not do the right unzip operation. And Anyway, you do not have to move individual files manually.
                                In the Sketchup Plugins folder you should only have
                                • LibFredo6.rb
                                • LIBFREDO6_Dir_34 folder
                                • ZLoader__FredoScale.rb
                                • FREDOSCALE_Dir_20 folder
                                This may have to do with your unzip program or your web browser.
                                I would suggest that you unzip in a neutral place, check that you reconstruct the files and folders with the correct hierarchy and then copy the 2 files and 2 folders manually to the Sketchup Directory.
                                Also, have a look at the PDF documentation where the installation is described in more details than in the post.
                                • K
                                  kienho
                                  I have done every steps in the tutorial pdf file but It still doesn't work. I'm using Google sketchup pro 7.0.
                                  • E
                                    emperorgus
                                    I've tried what you proposed two times (once using safari and the other time using firefox)
                                    and i only have these two file/folder :
                                    LibFredo6.rb
                                    i don't see these two anywhere :
                                    Thx for the answer!! maybe i'm just too dumb to make it work...
                                    I will try again...
                                    Thx for ur work i'm sure it's great...
                                    • massimoM
                                      massimo Moderator
                                      Sorry emperorgus, but have you read the first post of this thread and the PDF manual ❓
                                      This plugin do nothing by itself, it works in association with Fredo's plugins like Fredoscale, Round corner etc. So your two file/folder download of LibFredo is correct, BUT you need to download also the plugin you're interested in.
                                      As Fredo wrote in this thread:
                                      LibFredo6 is shared between several of my plugins. It provides a lot of basic functions (for instance the button palette management, the translation, and a large part of the interactive tools).
                                      But for the user, it does not do anything by itself, unless used by the real plugins.
                                      • L
                                        louisr57
                                        Greetings Fredo,
                                        I can't wait to try these great new tools (TOS, etc.) ... the buttons and menu items are there ... but they are all GREYED-OUT (caps for emphasis only ... not yelling!) ... I've reviewed the pdf's and the posts for clues ... all the required folders are there in the right place (under Sketchup plugins folder) ... I've shut-down and restarted Sketchup multiple times ... to no avail. Will try stripping the plugins folder of everything except your stuff and see what happens. Please advise when you have a moment.
                                        Thanks very much,
                                        Louis Radakir
                                        Ottawa, ON, Canada
                                        • fredo6F
                                          Are you referring to the main toolbar and the main menus? If so this would be very strange, because there is no mechanism to gray them out in my plugins.
                                          If you have a picture, it would help understand.
                                          Fred
                                            Fred
                                            The issue of loosing some right-click context-menu items [i.e. they get "greyed-out"] is a known bug with more recent versions of SketchUp - Google are being pressed to fix it...
                                            Its cause is not wholly established, although having lots of plugins that make context-menu items and repeated clicking on objects seem to both trigger it - separately or together !
                                            All of a context-menu's items still appear correctly under the last item in the main Edit Menu - so you can access them this way if the worst happens...
                                            The only 'fix' is to save and restart SUp - then you should get back the context-menu, albeit momentarily.
                                            Don't load plugins you aren't ever going to use - they increase the load and might just be the 'last-straw...' - move them out of the Plugins folder or rename them from .rb to .txt - that way you can always load them during a session by typing in the Ruby Console load"the_script_name.txt" ...
                                            • 115
                                            • 116
                                            • 7 / 116
