    [Plugin] 2D Tools
    791 Posts 178 Posters 690.3k Views 177 Watching
      Here's v4.6 http://forums.sketchucation.com/viewtopic.php?p=185760#p185760
      Didier Bur has reworked the FR lingvo file and a glitch with the Toolbar/Menu translation not db/deBabelizing has been fixed etc 🤓
        It is a 2D tool set - flat in 2D.
        Draw group and rotate if you need 2D in a vertical plane ?
        • brookefoxB Offline
          brookefox
          Thanks, TIG. Ideally, for me, one could specify which 2Ds the 2DTools operate in, but I suspect that you would have implemented such were it feasible.
          ~ Brooke
            brookefox
            Back to thomthom's earlier inquiry, and some others perhaps: it is not possible to set Z on any axis other than the default world blue (?), so one cannot, for instance, set the 2D Z in order to draw flat on a vertical section plane (which has not been copy-rotated flat)? I tried changing the blue axis (Z, vertical) to the original red as would allow me to do what I want here but the 2D Z did not follow.
            ~ Brooke
              Try 'Tools on Faces' [by Fredo] - it does have several similar tools to my 2D ones, you could use them on a single vertical face ?
              Note that some of my '2D' tools like Fillet, Text, Hatching, Line-Style etc do work in any plane in 3D, although they were initial implemented for 2D...
                brookefox
                Well, I can't get the 2DT text or hatch, for instance, to work on any other that the orig x-y (even on a tilted plane), though I can get SU to 'material' hatch or text a tilted plane. Indeed, once one has the non-standard flat plane created by whatever means, usually antithetical to strict model based-work (e.g., by making an vertical plane intersection with a model to produce a section), then SUf can handle drawing, texting etc., on it (even if the text is of the floating variety), and 3d text may be used for flat text. The charm of a 2D text able to be placed without the plane having been explicitly drawn, via the Z set, is the grail in my eyes.
                ~ Brooke
                  The very last option is on the 2D text dialog is Z-Plane OR All-Faces.
                  They do what they say.
                  The second one snaps to any face including sloping and vertical ones...
                    brookefox
                    OK, thanks. Sorry I missed that.
                    ~ Brooke
                      caronte01
                      Hi Tig, I´ve taken the liberty of updating the icon images so that they have transparency. I did this because when placed on osx´s toolbar, they didn´t look right.
                      If anyone wants to, all you need to do is replace the images in /plugins/2dtools/Icons with the ones in the attached zip file.
                      Cheers, and again, thanks
                      Santiago
                      Archive.zip
                      • EdsonE Offline
                        Edson
                        hi tig,
                        soon after you released this great plugin you mentioned that there would be a guide for mac users in pdf and doc format. however, i could not find any of those files in any of the zip files for the several versions of 2DTools. would it be possible for you to post them?
                        regards.
                        http://www.mahfuz.arq.br
                          Edsom
                          Doesn't the html 'help' file work on MAC ?
                          You can open it from the ../Plugins/2Dtools/ folder if it doesn't open from th toolbar or menu [if it doesn't open what error messages do you get in the Ruby Console ?]
                          • EdsonE Offline
                            Edson
                            hi tig,
                            yes, the html works fine. it is just that since you mentioned those two other files I thought i was missing something...
                              The pdf/doc were being considered because MAC users couldn't access the .mht Help file format I originally used - I subsequently changed it to an .html format so it should work for all OSs...
                              If you want a pdf here it is 2D Tools Guide.pdf The donations link doesn't work in pdf, so please use the html one if required...
                              • W Offline
                                wardbros
                                I am a Mac user with the free version of SU...will your plug-in work for me? I ask because I don't see a "Plug-ins" folder in the "SU" folder in my "Applications" folder.
                                Thanks in advance,
                                John
                                  My 2Dtools are cross-OS and will work on Mac as well as on PC - most rubies do.
                                  The correct path for a Mac's Plugins folder is
                                  Macintosh HD/Library/Application Support/Google SketchUp NNN/SketchUp/Plugins/
                                  Where NNN is the version of SUp, e.g. currently 6 or 7 ...
                                  There are good SUp help files for Mac and PC that explain issues like this...
                                  With 2Dtools the files come inside a compressed zip file - like any other zipped toolset, you must extract these files from the zip in exactly the same relative arrangement as they are inside the zip itself - i.e. there's a loader file 2d#.rb and a language translator file deBabelizer.rb that go directly into ../Plugins/ Capture.PNGbut the majority of files remain within the /2Dtools/ folder, and that folder you must place into ../Plugins/ [there are even subfolders (e.g. /Icons/) within 2Dtools itself that must also remain in the same relative positions within it]Capture2.PNG
                                  • W Offline
                                    wardbros
                                    Thank you TIG!!! The more I learn the more I don't know 😃 Great stuff!!
                                      stefx
                                      Tig,
                                      I have copied the files in the folder you indicated (I am mac user), but I can't see anything...
                                      any tips guys?
                                        stefx
                                        Tig,
                                        please don't blame me and mainly don't ask me how but I deleted and replaced the file (in the same way I did before) and it works.
                                        sorry for the trouble.
                                        Stefx.
                                          tulacong
                                          thank
                                            amjhds
                                            Hello, I can't get these plugins to work.
                                            I already put the 2Dtools_4.6 into the Plugins folder.
                                            Please help.
                                            Thanks,
                                            • 11
                                            • 12
                                            • 13
                                            • 39
                                            • 40
                                            • 11 / 40
