    [Plugin] 2D Tools
    791 Posts 178 Posters 807.5k Views 177 Watching
      These were primarily made as 2D tools...
      But if you want it to be a faceme component d a Styled-Line then simply wrap its group in a component and make that faceme. That way the group inside the component's entities can be edited later - making the group directly into a faceme component probably would lose the attribute and it's edit-ability ?
        Here's v4.6 http://forums.sketchucation.com/viewtopic.php?p=185760#p185760
        Didier Bur has reworked the FR lingvo file and a glitch with the Toolbar/Menu translation not db/deBabelizing has been fixed etc 🤓
          It is a 2D tool set - flat in 2D.
          Draw group and rotate if you need 2D in a vertical plane ?
          • brookefoxB
            brookefox
            Thanks, TIG. Ideally, for me, one could specify which 2Ds the 2DTools operate in, but I suspect that you would have implemented such were it feasible.
            ~ Brooke
            • brookefoxB
              brookefox
              Back to thomthom's earlier inquiry, and some others perhaps: it is not possible to set Z on any axis other than the default world blue (?), so one cannot, for instance, set the 2D Z in order to draw flat on a vertical section plane (which has not been copy-rotated flat)? I tried changing the blue axis (Z, vertical) to the original red as would allow me to do what I want here but the 2D Z did not follow.
              ~ Brooke
                Try 'Tools on Faces' [by Fredo] - it does have several similar tools to my 2D ones, you could use them on a single vertical face ?
                Note that some of my '2D' tools like Fillet, Text, Hatching, Line-Style etc do work in any plane in 3D, although they were initial implemented for 2D...
                • brookefoxB
                  brookefox
                  Well, I can't get the 2DT text or hatch, for instance, to work on any other that the orig x-y (even on a tilted plane), though I can get SU to 'material' hatch or text a tilted plane. Indeed, once one has the non-standard flat plane created by whatever means, usually antithetical to strict model based-work (e.g., by making an vertical plane intersection with a model to produce a section), then SUf can handle drawing, texting etc., on it (even if the text is of the floating variety), and 3d text may be used for flat text. The charm of a 2D text able to be placed without the plane having been explicitly drawn, via the Z set, is the grail in my eyes.
                  ~ Brooke
                    The very last option is on the 2D text dialog is Z-Plane OR All-Faces.
                    They do what they say.
                    The second one snaps to any face including sloping and vertical ones...
                    • brookefoxB
                      brookefox
                      OK, thanks. Sorry I missed that.
                      ~ Brooke
                      • C
                        caronte01
                        Hi Tig, I´ve taken the liberty of updating the icon images so that they have transparency. I did this because when placed on osx´s toolbar, they didn´t look right.
                        If anyone wants to, all you need to do is replace the images in /plugins/2dtools/Icons with the ones in the attached zip file.
                        Cheers, and again, thanks
                        Santiago
                        Archive.zip
                        • EdsonE
                          Edson
                          hi tig,
                          soon after you released this great plugin you mentioned that there would be a guide for mac users in pdf and doc format. however, i could not find any of those files in any of the zip files for the several versions of 2DTools. would it be possible for you to post them?
                          regards.
                          http://www.mahfuz.arq.br
                            Edsom
                            Doesn't the html 'help' file work on MAC ?
                            You can open it from the ../Plugins/2Dtools/ folder if it doesn't open from th toolbar or menu [if it doesn't open what error messages do you get in the Ruby Console ?]
                            • EdsonE
                              Edson
                              hi tig,
                              yes, the html works fine. it is just that since you mentioned those two other files I thought i was missing something...
                                The pdf/doc were being considered because MAC users couldn't access the .mht Help file format I originally used - I subsequently changed it to an .html format so it should work for all OSs...
                                If you want a pdf here it is 2D Tools Guide.pdf The donations link doesn't work in pdf, so please use the html one if required...
                                • W
                                  wardbros
                                  I am a Mac user with the free version of SU...will your plug-in work for me? I ask because I don't see a "Plug-ins" folder in the "SU" folder in my "Applications" folder.
                                  Thanks in advance,
                                  John
                                    My 2Dtools are cross-OS and will work on Mac as well as on PC - most rubies do.
                                    The correct path for a Mac's Plugins folder is
                                    Macintosh HD/Library/Application Support/Google SketchUp NNN/SketchUp/Plugins/
                                    Where NNN is the version of SUp, e.g. currently 6 or 7 ...
                                    There are good SUp help files for Mac and PC that explain issues like this...
                                    With 2Dtools the files come inside a compressed zip file - like any other zipped toolset, you must extract these files from the zip in exactly the same relative arrangement as they are inside the zip itself - i.e. there's a loader file 2d#.rb and a language translator file deBabelizer.rb that go directly into ../Plugins/ Capture.PNGbut the majority of files remain within the /2Dtools/ folder, and that folder you must place into ../Plugins/ [there are even subfolders (e.g. /Icons/) within 2Dtools itself that must also remain in the same relative positions within it]Capture2.PNG
                                    • W
                                      wardbros
                                      Thank you TIG!!! The more I learn the more I don't know 😃 Great stuff!!
                                        stefx
                                        Tig,
                                        I have copied the files in the folder you indicated (I am mac user), but I can't see anything...
                                        any tips guys?
                                          stefx
                                          Tig,
                                          please don't blame me and mainly don't ask me how but I deleted and replaced the file (in the same way I did before) and it works.
                                          sorry for the trouble.
                                          Stefx.
                                          • T
                                            tulacong
                                            thank
                                            • 11
                                            • 12
                                            • 13
                                            • 39
                                            • 40
                                            • 11 / 40
