    Redefine the Delete key?
    19 Posts 5 Posters 3.9k Views 5 Watching
      Aah !
      How about something like shift+E, ctrl+E or alt+E[rase] to erase individual ones ?
      However, I think that Backspace is a good compromise with Delete being unavailable to you...
      πŸ˜•
      • Chris FullmerC
        Backspace works well I think.
        In 3dsmax, delete and backspae server different purposes, but both delete things. I think people with max background will have no problems getting used to it.
          I just realised that using the Backspace would interfere with the VCB input - as users can use Backspace to erase input they've entered...
            How about Ctrl+Backspace or Ctrl+Delete ?
              I'm thinking that I might leave this for the user to configure.
              • X
                xrok1
                just a thought, can you not remove it from SU shortcut list when your script starts so you have access then return it to SU when your script exits?
                  No - You can't even redefine it from the SU UI. It won't let you.
                  • X
                    xrok1
                    πŸ˜† i removed it from the edit/delete shortcut and i couldn't even reassign it. had to open another copy of SU. πŸ˜†
                      So one can remove the shortcut? But not reassign it? Nor even restore it to the SU default? πŸ˜• ❓
                      • X
                        xrok1
                        you can remove it through preferences>shortcuts, by highlighting it and hiiting the - button. but no i couldn't reassign to edit>delete after πŸ˜•
                        • X
                          xrok1
                          i tried to fool it with ascii, no luck.
                          btw, how is your script coming along? πŸŽ‰
                            Starting to shape up. I'll be making a post about it this week.
                            • C
                              caronte01
                              Hi Thom
                              Have you tested for compatibility on the mac. Remember that the default key in the mac to erase stuff is backspace, not delete.
                                No - not yet tested OSX.
