    Redefine the Delete key?
    19 Posts 5 Posters 3.7k Views 5 Watching
      Why not use E[rase] as the 'erase key' - it matches M[ove], S[cale] etc ?
        Because I'm also making an Eraser tool - similar to SU's native Eraser tool.
          Aah !
          How about something like shift+E, ctrl+E or alt+E[rase] to erase individual ones ?
          However, I think that Backspace is a good compromise with Delete being unavailable to you...
          πŸ˜•
          • Chris FullmerC Offline
            Backspace works well I think.
            In 3dsmax, delete and backspae server different purposes, but both delete things. I think people with max background will have no problems getting used to it.
              I just realised that using the Backspace would interfere with the VCB input - as users can use Backspace to erase input they've entered...
                How about Ctrl+Backspace or Ctrl+Delete ?
                  I'm thinking that I might leave this for the user to configure.
                  • X Offline
                    xrok1
                    just a thought, can you not remove it from SU shortcut list when your script starts so you have access then return it to SU when your script exits?
                      No - You can't even redefine it from the SU UI. It won't let you.
                      • X Offline
                        xrok1
                        πŸ˜† i removed it from the edit/delete shortcut and i couldn't even reassign it. had to open another copy of SU. πŸ˜†
                          So one can remove the shortcut? But not reassign it? Nor even restore it to the SU default? πŸ˜• ❓
                          • X Offline
                            xrok1
                            you can remove it through preferences>shortcuts, by highlighting it and hiiting the - button. but no i couldn't reassign to edit>delete after πŸ˜•
                            • X Offline
                              xrok1
                              i tried to fool it with ascii, no luck.
                              btw, how is your script coming along? πŸŽ‰
                                Starting to shape up. I'll be making a post about it this week.
                                  caronte01
                                  Hi Thom
                                  Have you tested for compatibility on the mac. Remember that the default key in the mac to erase stuff is backspace, not delete.
                                    No - not yet tested OSX.
