    TOOL ON SURFACE- DESPERATE FOR HELP
    19 Posts 5 Posters 2.6k Views 5 Watching
      remus
      Have you tried removing the whole lot and starting again?
        The current setup is TOS_15 so you are way behind ?
        It should be
        C:\Program Files\Google\Google SketchUp 7\Plugins\TOS_Dir_15\
        I have most of those files, but mine works though I don't have LibFredo6_ES.lang
        Additionally I do have Quickcard - ToolsOnSurface - English - v1.5 - 12 Sep 09
        But neither of these should matter...
        To load the file you need
        C:\Program Files\Google\Google SketchUp 7\Plugins\LIBFREDO6_Dir_34\
        [and all of its contents]
        and the file that kicks it all off...
        C:\Program Files\Google\Google SketchUp 7\Plugins\ZLoader__OnSurface.rb
        Check you have got all of the required files in the right places.
        You can download all of these things from the topics in these forums...
        • fredo6F
          @dolphus said:
          TIG first off thank you for your reply
          I have tried to install as i think you suggested looks like this
          http://i458.photobucket.com/albums/qq304/dolphus_006/toolsonsurfacerev.jpg
          i still cannot find anything in the view/toolbars or windows/options hope you can spot my mistake
          Dolphus
          Can you repost the image. I cannot see it.
            dolphus
              dolphus
              Hope this will add some light to the drama
              http://i458.photobucket.com/albums/qq304/dolphus_006/PluginsTree.jpg
              PS i have placed the ZLoader__OnSurface and LibFredo6 files in the TOS_Dir_15 folder
                Please read my post again.
                You seem to have the correct folders in ../Plugins/ as I said...
                EXCEPT that nowhere did I say you should have a folder called ../Plugins/ZLoader__OnSurface/ - The rb file that you've put in there should go directly into ../Plugins/ folder - as I had said...
                If you move that file [ ZLoader__OnSurface.rb] into ../Plugins/ it will load when SUp starts - as it is nothing loads to kick off the sequence of events, as absolutely everything has been put inside sub-folders ???
                For the avoidance of doubt - leave the other files in the other folders as they are...
                Please try again... ❗
                You do seem to be making something of a jumble ...
                • fredo6F
                  I still cannot see your picture on the forum.
                  Here is the top level footprint in the Sktechup Plugin Directory.
                    TOS_Dir_15 shouldn't be an empty folder either.
                      dolphus
                      Tig sorry i messed up with the Z....folder i did as you said also put the files into TOS_Dir_15
                      Now i can see the check boxe"S" (2No) for Tools On Surface in the Windows/Preference they are both checked but i cannot find anything under View/toolbars to access the TOS
                      • fredo6F
                        Can you check if you have a menu Tools > Fredo6 Collection > Tools On Surface
                          dolphus
                          No Negative Fredo6 i dont have anything like that in Tools
                            dolphus
                                :rolling_on_the_floor_laughing:
                            Fredo6 and Dave thank you for your patience and help ....IT IS WORKING I INSTALLED THE LibFredo6 DIR AND PUT THE RUBY IN PLUGINS AND THERE IT WAS IN THE TOOL FLY DOWN MENU
                            ONCE AGAIN THANKS I WAS REALLY LOST WITHOUT MY FAVOURITE PLUGIN
                              Glad that worked.
                              Your next task should be easy. A nuclear fusion powered motorcycle. πŸ˜„ πŸ‘
