    TOOL ON SURFACE- DESPERATE FOR HELP
    19 Posts 5 Posters 2.6k Views 5 Watching
      dolphus
      I re-installed Sketchup on my laptop and the tools on surface had to be re-installed but i cannot get it to work attached is a diagram of my plugins folder
      can anyone please show me what's wrong.....desperate
      http://i458.photobucket.com/albums/qq304/dolphus_006/toolsonsurface-1.jpg
        remus
        Are you getting any errors in the ruby console?
          dolphus
          No Remus the SU starts up just fine but i cannot find any reference to the TOS in any menue
            Have you ticked the box for Tools on Surface in Window>Preferences>Extensions?
              dolphus
              Dave i don't have the option to tick in that menue?
                I'm no expert but my guess is that you've got something wrong in your installation of the plugin.
                From memory, you should have in your Plugins folder a folder called TOS_Dir_15 and two RB files; LibFredo6 and ZLoader_OnSurface.
                Did you install LibFredo6?
                  remus
                  Have you tried removing the whole lot and starting again?
                    The current setup is TOS_15 so you are way behind ?
                    It should be
                    C:\Program Files\Google\Google SketchUp 7\Plugins\TOS_Dir_15\
                    I have most of those files, but mine works though I don't have LibFredo6_ES.lang
                    Additionally I do have Quickcard - ToolsOnSurface - English - v1.5 - 12 Sep 09
                    But neither of these should matter...
                    To load the file you need
                    C:\Program Files\Google\Google SketchUp 7\Plugins\LIBFREDO6_Dir_34\
                    [and all of its contents]
                    and the file that kicks it all off...
                    C:\Program Files\Google\Google SketchUp 7\Plugins\ZLoader__OnSurface.rb
                    Check you have got all of the required files in the right places.
                    You can download all of these things from the topics in these forums...
                    • fredo6F
                      @dolphus said:
                      TIG first off thank you for your reply
                      I have tried to install as i think you suggested looks like this
                      http://i458.photobucket.com/albums/qq304/dolphus_006/toolsonsurfacerev.jpg
                      i still cannot find anything in the view/toolbars or windows/options hope you can spot my mistake
                      Dolphus
                      Can you repost the image. I cannot see it.
                        dolphus
                          dolphus
                          Hope this will add some light to the drama
                          http://i458.photobucket.com/albums/qq304/dolphus_006/PluginsTree.jpg
                          PS i have placed the ZLoader__OnSurface and LibFredo6 files in the TOS_Dir_15 folder
                            Please read my post again.
                            You seem to have the correct folders in ../Plugins/ as I said...
                            EXCEPT that nowhere did I say you should have a folder called ../Plugins/ZLoader__OnSurface/ - The rb file that you've put in there should go directly into ../Plugins/ folder - as I had said...
                            If you move that file [ ZLoader__OnSurface.rb] into ../Plugins/ it will load when SUp starts - as it is nothing loads to kick off the sequence of events, as absolutely everything has been put inside sub-folders ???
                            For the avoidance of doubt - leave the other files in the other folders as they are...
                            Please try again... ❗
                            You do seem to be making something of a jumble ...
                            • fredo6F
                              I still cannot see your picture on the forum.
                              Here is the top level footprint in the Sktechup Plugin Directory.
                                TOS_Dir_15 shouldn't be an empty folder either.
                                  dolphus
                                  Tig sorry i messed up with the Z....folder i did as you said also put the files into TOS_Dir_15
                                  Now i can see the check boxe"S" (2No) for Tools On Surface in the Windows/Preference they are both checked but i cannot find anything under View/toolbars to access the TOS
                                  • fredo6F
                                    Can you check if you have a menu Tools > Fredo6 Collection > Tools On Surface
                                      dolphus
                                      No Negative Fredo6 i dont have anything like that in Tools
                                        dolphus
                                            :rolling_on_the_floor_laughing:
                                        Fredo6 and Dave thank you for your patience and help ....IT IS WORKING I INSTALLED THE LibFredo6 DIR AND PUT THE RUBY IN PLUGINS AND THERE IT WAS IN THE TOOL FLY DOWN MENU
                                        ONCE AGAIN THANKS I WAS REALLY LOST WITHOUT MY FAVOURITE PLUGIN
                                          Glad that worked.
                                          Your next task should be easy. A nuclear fusion powered motorcycle. πŸ˜„ πŸ‘
