    How to make a recessed window on a curved surface
    16 Posts 5 Posters 1.5k Views 5 Watching
      select house / intersect with the model
      move the "cube"
      Explode the component
      Select all
      Intersect selected
      paint transparent result rounded glasss
      • Z
        zigfoyer
        Hmm, not following you. That seems to get me to where I was before. I still can't figure out how you did the trim around the window.
        • GaieusG
          Dedmin - the question was "how to"?
          πŸ˜„
          Pilou - I would have sweared you'd come back with TOS - which would be perfect for this job of course. Your description is a bit brief however. I guess it's the same as my (no-plugin) solution, too. πŸ˜‰
          control_room_04.skp
            dedmin
            Tools on surface
            Offcet
            Offcet
            Arc
            and JPP
            • david_hD
              david_h
              Joint PP and Offset on Surface helps with that problem I believe
              • GaieusG
                Certainly - the "plugin way".
                πŸ˜‰
                • david_hD
                  david_h
                  What??? Is that bad? Did I violate the No Plugin Code thingy? 😳
                  πŸ’š
                  • Z
                    zigfoyer
                    Ah, I see. Make the trim before I intersect with the building.
                    Awesome, thanks for all the responses.
                    • GaieusG
                      πŸ’š
                      No, not at all, David.
                      Just when we are in the Newbie forum, I like to show people all the ways that native SU can solve. In this case, the plugin way will of course, produce much more regular and nicer geometry however.
                      @zigfoyer:
                      Glad if there was any helpful hints here - in either way. With such curvy geometry, you could indeed check out those plugins David mentioned.
                      πŸ‘
                      • david_hD
                        david_h
                        I knew that. .. just teasin' ya. It's all in good fun. You know me. .. i like to be the class clown! πŸ’š
