    How to make a recessed window on a curved surface
    16 Posts 5 Posters 1.6k Views 5 Watching
    • Z
      zigfoyer
      Apparently I don't know how to use the image tag either.
      ERROR: The request could not be satisfied
      (www.flickr.com)
      • GaieusG
        (www.flickr.com)
        I fixed it for you. You did not include the image URL but the page URL (right click the image > copy image URL or show image or something and paste that in here - with the*.jpg extension).
        As for your window - have you still got the original rounded rectangle and the untouched surface? Could you upload the model in that stage?
        • Z
          zigfoyer
          Sure. Upload to where?
            "upload attachment" (left page bottom corner) of your Text page edit message πŸ˜‰
            so file or image can be ulpoaded or viewed on the screen of the forum πŸ˜‰
            • Z
              zigfoyer
              Aha. Thanks πŸ˜„
              control_room_04.skp
                select house / intersect with the model
                move the "cube"
                Explode the component
                Select all
                Intersect selected
                paint transparent result rounded glasss
                • Z
                  zigfoyer
                  Hmm, not following you. That seems to get me to where I was before. I still can't figure out how you did the trim around the window.
                  • GaieusG
                    Dedmin - the question was "how to"?
                    πŸ˜„
                    Pilou - I would have sweared you'd come back with TOS - which would be perfect for this job of course. Your description is a bit brief however. I guess it's the same as my (no-plugin) solution, too. πŸ˜‰
                    control_room_04.skp
                      dedmin
                      Tools on surface
                      Offcet
                      Offcet
                      Arc
                      and JPP
                      • david_hD
                        david_h
                        Joint PP and Offset on Surface helps with that problem I believe
                        • GaieusG
                          Certainly - the "plugin way".
                          πŸ˜‰
                          • david_hD
                            david_h
                            What??? Is that bad? Did I violate the No Plugin Code thingy? 😳
                            πŸ’š
                            • Z
                              zigfoyer
                              Ah, I see. Make the trim before I intersect with the building.
                              Awesome, thanks for all the responses.
                              • GaieusG
                                πŸ’š
                                No, not at all, David.
                                Just when we are in the Newbie forum, I like to show people all the ways that native SU can solve. In this case, the plugin way will of course, produce much more regular and nicer geometry however.
                                @zigfoyer:
                                Glad if there was any helpful hints here - in either way. With such curvy geometry, you could indeed check out those plugins David mentioned.
                                πŸ‘
                                • david_hD
                                  david_h
                                  I knew that. .. just teasin' ya. It's all in good fun. You know me. .. i like to be the class clown! πŸ’š
