    How to make a recessed window on a curved surface
    16 Posts 5 Posters 1.4k Views 5 Watching
      "upload attachment" (left page bottom corner) of your Text page edit message πŸ˜‰
      so file or image can be ulpoaded or viewed on the screen of the forum πŸ˜‰
      • Z Offline
        zigfoyer
        Aha. Thanks πŸ˜„
        control_room_04.skp
          select house / intersect with the model
          move the "cube"
          Explode the component
          Select all
          Intersect selected
          paint transparent result rounded glasss
          • Z Offline
            zigfoyer
            Hmm, not following you. That seems to get me to where I was before. I still can't figure out how you did the trim around the window.
              Dedmin - the question was "how to"?
              πŸ˜„
              Pilou - I would have sweared you'd come back with TOS - which would be perfect for this job of course. Your description is a bit brief however. I guess it's the same as my (no-plugin) solution, too. πŸ˜‰
              control_room_04.skp
                dedmin
                Tools on surface
                Offcet
                Offcet
                Arc
                and JPP
                • david_hD Offline
                  david_h
                  Joint PP and Offset on Surface helps with that problem I believe
                    Certainly - the "plugin way".
                    πŸ˜‰
                    • david_hD Offline
                      david_h
                      What??? Is that bad? Did I violate the No Plugin Code thingy? 😳
                      πŸ’š
                      • Z Offline
                        zigfoyer
                        Ah, I see. Make the trim before I intersect with the building.
                        Awesome, thanks for all the responses.
                          πŸ’š
                          No, not at all, David.
                          Just when we are in the Newbie forum, I like to show people all the ways that native SU can solve. In this case, the plugin way will of course, produce much more regular and nicer geometry however.
                          @zigfoyer:
                          Glad if there was any helpful hints here - in either way. With such curvy geometry, you could indeed check out those plugins David mentioned.
                          πŸ‘
                          • david_hD Offline
                            david_h
                            I knew that. .. just teasin' ya. It's all in good fun. You know me. .. i like to be the class clown! πŸ’š
