    How to make a recessed window on a curved surface
    16 Posts 5 Posters 1.6k Views 5 Watching
    • Z
      zigfoyer
      I’m trying to make an underwater base with a retro 70’s feel and a lot of curved surfaces, but I ran into the limit of my SketchUp skills pretty fast.
      I made the window in the front by intersecting a big cube with rounded corners and then cutting the window out and shifting it back a bit. But I don’t know how to connect it to the building or add trim or anything to it. There must be a more graceful way to approach this.
      http://farm5.static.flickr.com/4037/4421816345_4e69a15e7d.jpg
      • Z
        zigfoyer
        Apparently I don't know how to use the image tag either.
        ERROR: The request could not be satisfied
        (www.flickr.com)
        • GaieusG
          (www.flickr.com)
          I fixed it for you. You did not include the image URL but the page URL (right click the image > copy image URL or show image or something and paste that in here - with the*.jpg extension).
          As for your window - have you still got the original rounded rectangle and the untouched surface? Could you upload the model in that stage?
          • Z
            zigfoyer
            Sure. Upload to where?
              "upload attachment" (left page bottom corner) of your Text page edit message πŸ˜‰
              so file or image can be ulpoaded or viewed on the screen of the forum πŸ˜‰
              • Z
                zigfoyer
                Aha. Thanks πŸ˜„
                control_room_04.skp
                  select house / intersect with the model
                  move the "cube"
                  Explode the component
                  Select all
                  Intersect selected
                  paint transparent result rounded glasss
                  • Z
                    zigfoyer
                    Hmm, not following you. That seems to get me to where I was before. I still can't figure out how you did the trim around the window.
                    • GaieusG
                      Dedmin - the question was "how to"?
                      πŸ˜„
                      Pilou - I would have sweared you'd come back with TOS - which would be perfect for this job of course. Your description is a bit brief however. I guess it's the same as my (no-plugin) solution, too. πŸ˜‰
                      control_room_04.skp
                        dedmin
                        Tools on surface
                        Offcet
                        Offcet
                        Arc
                        and JPP
                        • david_hD
                          david_h
                          Joint PP and Offset on Surface helps with that problem I believe
                          • GaieusG
                            Certainly - the "plugin way".
                            πŸ˜‰
                            • david_hD
                              david_h
                              What??? Is that bad? Did I violate the No Plugin Code thingy? 😳
                              πŸ’š
                              • Z
                                zigfoyer
                                Ah, I see. Make the trim before I intersect with the building.
                                Awesome, thanks for all the responses.
                                • GaieusG
                                  πŸ’š
                                  No, not at all, David.
                                  Just when we are in the Newbie forum, I like to show people all the ways that native SU can solve. In this case, the plugin way will of course, produce much more regular and nicer geometry however.
                                  @zigfoyer:
                                  Glad if there was any helpful hints here - in either way. With such curvy geometry, you could indeed check out those plugins David mentioned.
                                  πŸ‘
                                  • david_hD
                                    david_h
                                    I knew that. .. just teasin' ya. It's all in good fun. You know me. .. i like to be the class clown! πŸ’š
