    How to make a recessed window on a curved surface
    16 Posts 5 Posters 1.6k Views 5 Watching
    • GaieusG
      @zigfoyer said:
      Apparently I don't know how to use the image tag either.
      ERROR: The request could not be satisfied
      (www.flickr.com)
      I fixed it for you. You did not include the image URL but the page URL (right click the image > copy image URL or show image or something and paste that in here - with the*.jpg extension).
      As for your window - have you still got the original rounded rectangle and the untouched surface? Could you upload the model in that stage?
      • Z
        zigfoyer
        Sure. Upload to where?
          "upload attachment" (left page bottom corner) of your Text page edit message πŸ˜‰
          so file or image can be ulpoaded or viewed on the screen of the forum πŸ˜‰
          • Z
            zigfoyer
            Aha. Thanks πŸ˜„
            control_room_04.skp
              select house / intersect with the model
              move the "cube"
              Explode the component
              Select all
              Intersect selected
              paint transparent result rounded glasss
              • Z
                zigfoyer
                Hmm, not following you. That seems to get me to where I was before. I still can't figure out how you did the trim around the window.
                • GaieusG
                  Dedmin - the question was "how to"?
                  πŸ˜„
                  Pilou - I would have sweared you'd come back with TOS - which would be perfect for this job of course. Your description is a bit brief however. I guess it's the same as my (no-plugin) solution, too. πŸ˜‰
                  control_room_04.skp
                    dedmin
                    Tools on surface
                    Offcet
                    Offcet
                    Arc
                    and JPP
                    • david_hD
                      david_h
                      Joint PP and Offset on Surface helps with that problem I believe
                      • GaieusG
                        Certainly - the "plugin way".
                        πŸ˜‰
                        • david_hD
                          david_h
                          What??? Is that bad? Did I violate the No Plugin Code thingy? 😳
                          πŸ’š
                          • Z
                            zigfoyer
                            Ah, I see. Make the trim before I intersect with the building.
                            Awesome, thanks for all the responses.
                            • GaieusG
                              πŸ’š
                              No, not at all, David.
                              Just when we are in the Newbie forum, I like to show people all the ways that native SU can solve. In this case, the plugin way will of course, produce much more regular and nicer geometry however.
                              @zigfoyer:
                              Glad if there was any helpful hints here - in either way. With such curvy geometry, you could indeed check out those plugins David mentioned.
                              πŸ‘
                              • david_hD
                                david_h
                                I knew that. .. just teasin' ya. It's all in good fun. You know me. .. i like to be the class clown! πŸ’š
