    Twilight Render Glass Conservatory + External
    37 Posts 13 Posters 11.9k Views 13 Watching
    • olisheaO Offline
      olishea
      thanks pete.
      I'll give it a go when I render some more tomorrow.
      I updated original post with a warmer version, is it better?
      oli
      • olisheaO Offline
        olishea
        here is a tester, gonna leave it rendering over weekend.
        http://i654.photobucket.com/albums/uu269/olishea/scene2.jpg
        geometry:
        http://i654.photobucket.com/albums/uu269/olishea/hiddenline1.jpg
        geometry+ render =
        http://i654.photobucket.com/albums/uu269/olishea/lineover.jpg
        THNAKS TO SOLO FOR THE PLANTS, THEY LOOK GREAT! AND VERY SKETCHUP FRIENDLY!
        oli
        • N Offline
          nomeradona
          wow! excellent space and very nice render oli.
            D-space
            Awesome render, looks pretty cleaned! ๐Ÿ‘
            Btw...does it shows caustics? ๐Ÿ˜‰
            http://blibestmentalt.no/54981
            • michaliszissiouM Offline
              michaliszissiou
              These are great renders oli. ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
              A so peaceful feeling, that really good. Not greenish (well just a bit). Some, just a little, magenta on highlights maybe..... ๐Ÿ˜†
              • olisheaO Offline
                olishea
                thank you very much for all your kind words, your critical eyes keep me trying harder with each new project!! ๐Ÿ‘
                oli
                  sepo
                  The last one looks very convincing. How about night render to use all that lighting you have in there and maybe some from outside.
                  • olisheaO Offline
                    olishea
                    Thank you Sid and good idea!! Not done many night renders so it'll be a challenge!! Will look great all lit up....
                    More images to come, got another cooking overnight ๐Ÿ˜„
                    oli
                      steelers05
                      These are very good images and I think progress is really showing.
                      A few crits though...the foreground plant is too close to the camera. It could certainly work in the scene, but it is not detailed enough to be that close to the camera. I think the bump levels on some of your materials are a bit high and that combined with the noise on some of the images creates a graineness that is a bit distracting. The only other thing is the glass....morely the joints..it seems like there should be some sort of frame. I could be wrong but that system seems like you would need some sort of frame or connector pieces for it to work and I think that would help add to the realism. But you also may have a system that is as your illustrating.?
                      Anyways, keep up the good work and id like to see a night scene as well.
                      • massimoM Offline
                        massimo Moderator
                        This last one has an amazing "airy breath". I like it very much! ๐Ÿ‘ Only those pillars and roof beams made of glass ( โ“ ๐Ÿ˜ฎ โ“ ) worry me a bit. ๐Ÿ˜„
                        • olisheaO Offline
                          olishea
                          thanks steelers. im not going into all the structure im just the monkey. there is a frame can you not see it. the only part of the structure I didn't show is the joints between the structural members, they are not continuous as ive shown it.
                          the foreground plant should be blurred but not got round to it yet.
                          new one, bump reduced
                          http://i654.photobucket.com/albums/uu269/olishea/SCENE3_3_medium.jpg
                          oli
                          • olisheaO Offline
                            olishea
                            i know i know, but like i say im just the monkey!!
                            airy breath!! nice! cheers
                            I updated previous image with DOF blur to foreground foliage....
                            oli
                            • olisheaO Offline
                              olishea
                              left this one to cook a bit longer....
                              I normally don't like lens flares but I think it works in this image.
                              higher res version here:http://twilightrender.com/phpBB3/viewtopic.php?f=16&t=1351&p=11117#p11117
                              http://i654.photobucket.com/albums/uu269/olishea/scene2_medium.jpg
                              oli
                              • massimoM Offline
                                massimo Moderator
                                Perhaps you can put in your glass conservatory this all glass table by Renzo Piano... ๐Ÿ˜† The legs are pre-stretched with a steel cable in order to resist to the compression. It's called TESO (italian word that means stretched) made by FontanaArte. Added also a PDF.
                                teso.pdf
                                • olisheaO Offline
                                  olishea
                                  sweet! cheers for your interest massimo...renzo is a legend!
                                  i must admit i love all-glass furniture. how practical it is I don't know!!
                                  single piece glass table, bit common but impressive nonetheless:
                                  404 Not Found
                                  (www.diamondliving.ie)
                                  oli
                                  • olisheaO Offline
                                    olishea
                                    external, for practice really:
                                    comments appreciated, cheers.
                                    hidden geometry:
                                    http://i654.photobucket.com/albums/uu269/olishea/revision2_lines.jpg
                                    sketchup view:
                                    http://i654.photobucket.com/albums/uu269/olishea/revision2.jpg
                                    final render:
                                    http://i654.photobucket.com/albums/uu269/olishea/scene4_medium.jpg
                                    oli
                                      D-space
                                      Hi Oli, I guess you're cruising when exterior shots are concern. Great renders as always. ๐Ÿ‘
                                      • massimoM Offline
                                        massimo Moderator
                                        Veeery niiice!!! I can feel the warmth of the sun. โ˜€
                                        • olisheaO Offline
                                          olishea
                                          thanks dspace and massimo!!
                                          I wish I could feel the warmth I'm bloody freezin!!
                                          higher res version and settings here: http://twilightrender.com/phpBB3/viewtopic.php?f=16&t=1351&start=40
                                          oli
                                            michaliszissiou
                                            I told you before, some more magenta lights can really makes you feel some warmth. ๐Ÿ˜†
