    Twilight Render Glass Conservatory + External
    37 Posts 13 Posters 12.2k Views 13 Watching
    • soloS
      Oli, looks good, I may tone down the bump a little on the furniture.
      As far as the IBL/hdri goes, can you adjust the intensity? if yes then about 25% less would give a great result.
      • olisheaO
        olishea
        thanks pete.
        I'll give it a go when I render some more tomorrow.
        I updated original post with a warmer version, is it better?
        oli
        • olisheaO
          olishea
          here is a tester, gonna leave it rendering over weekend.
          http://i654.photobucket.com/albums/uu269/olishea/scene2.jpg
          geometry:
          http://i654.photobucket.com/albums/uu269/olishea/hiddenline1.jpg
          geometry+ render =
          http://i654.photobucket.com/albums/uu269/olishea/lineover.jpg
          THNAKS TO SOLO FOR THE PLANTS, THEY LOOK GREAT! AND VERY SKETCHUP FRIENDLY!
          oli
          • N
            nomeradona
            wow! excellent space and very nice render oli.
              D-space
              Awesome render, looks pretty cleaned! ๐Ÿ‘
              Btw...does it shows caustics? ๐Ÿ˜‰
              http://blibestmentalt.no/54981
              • michaliszissiouM
                michaliszissiou
                These are great renders oli. ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                A so peaceful feeling, that really good. Not greenish (well just a bit). Some, just a little, magenta on highlights maybe..... ๐Ÿ˜†
                • olisheaO
                  olishea
                  thank you very much for all your kind words, your critical eyes keep me trying harder with each new project!! ๐Ÿ‘
                  oli
                    sepo
                    The last one looks very convincing. How about night render to use all that lighting you have in there and maybe some from outside.
                    • olisheaO
                      olishea
                      Thank you Sid and good idea!! Not done many night renders so it'll be a challenge!! Will look great all lit up....
                      More images to come, got another cooking overnight ๐Ÿ˜„
                      oli
                        steelers05
                        These are very good images and I think progress is really showing.
                        A few crits though...the foreground plant is too close to the camera. It could certainly work in the scene, but it is not detailed enough to be that close to the camera. I think the bump levels on some of your materials are a bit high and that combined with the noise on some of the images creates a graineness that is a bit distracting. The only other thing is the glass....morely the joints..it seems like there should be some sort of frame. I could be wrong but that system seems like you would need some sort of frame or connector pieces for it to work and I think that would help add to the realism. But you also may have a system that is as your illustrating.?
                        Anyways, keep up the good work and id like to see a night scene as well.
                        • massimoM
                          massimo Moderator
                          This last one has an amazing "airy breath". I like it very much! ๐Ÿ‘ Only those pillars and roof beams made of glass ( โ“ ๐Ÿ˜ฎ โ“ ) worry me a bit. ๐Ÿ˜„
                          • olisheaO
                            olishea
                            thanks steelers. im not going into all the structure im just the monkey. there is a frame can you not see it. the only part of the structure I didn't show is the joints between the structural members, they are not continuous as ive shown it.
                            the foreground plant should be blurred but not got round to it yet.
                            new one, bump reduced
                            http://i654.photobucket.com/albums/uu269/olishea/SCENE3_3_medium.jpg
                            oli
                            • olisheaO
                              olishea
                              i know i know, but like i say im just the monkey!!
                              airy breath!! nice! cheers
                              I updated previous image with DOF blur to foreground foliage....
                              oli
                              • olisheaO
                                olishea
                                left this one to cook a bit longer....
                                I normally don't like lens flares but I think it works in this image.
                                higher res version here:http://twilightrender.com/phpBB3/viewtopic.php?f=16&t=1351&p=11117#p11117
                                http://i654.photobucket.com/albums/uu269/olishea/scene2_medium.jpg
                                oli
                                • massimoM
                                  massimo Moderator
                                  Perhaps you can put in your glass conservatory this all glass table by Renzo Piano... ๐Ÿ˜† The legs are pre-stretched with a steel cable in order to resist to the compression. It's called TESO (italian word that means stretched) made by FontanaArte. Added also a PDF.
                                  teso.pdf
                                  • olisheaO
                                    olishea
                                    sweet! cheers for your interest massimo...renzo is a legend!
                                    i must admit i love all-glass furniture. how practical it is I don't know!!
                                    single piece glass table, bit common but impressive nonetheless:
                                    404 Not Found
                                    (www.diamondliving.ie)
                                    oli
                                    • olisheaO
                                      olishea
                                      external, for practice really:
                                      comments appreciated, cheers.
                                      hidden geometry:
                                      http://i654.photobucket.com/albums/uu269/olishea/revision2_lines.jpg
                                      sketchup view:
                                      http://i654.photobucket.com/albums/uu269/olishea/revision2.jpg
                                      final render:
                                      http://i654.photobucket.com/albums/uu269/olishea/scene4_medium.jpg
                                      oli
                                        D-space
                                        Hi Oli, I guess you're cruising when exterior shots are concern. Great renders as always. ๐Ÿ‘
                                        • massimoM
                                          massimo Moderator
                                          Veeery niiice!!! I can feel the warmth of the sun. โ˜€
                                          • olisheaO
                                            olishea
                                            thanks dspace and massimo!!
                                            I wish I could feel the warmth I'm bloody freezin!!
                                            higher res version and settings here: http://twilightrender.com/phpBB3/viewtopic.php?f=16&t=1351&start=40
                                            oli
