    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 1.0m Views 175 Watching
    • Y
      yuelai
      somebody can help me please?
      • Y
        yuelai
        is this plugin for Skechtup6 or 7 vision?
          What are you trying to do exactly ?
          Simply click on the zip file link [ extrudeTools_yyyymmdd.zip- the file's suffix varies with the date of the last upload currently 20100219 ?], you can find it at the end of the first post in this thread, and then your browser should ask you what to do [varies with browser make]... download the zip file to your desktop, then follow the 'extraction' instructions etc...
          You MUST extract the files as directed - that is in their sub-folders as supplied in the zip - DON'T try to drag/drop them out of the zip's window it'll go wrong. Use 'extract[_all]' option in you zip application and they should keep their folders intact. The .rb files go directly into the Plugins folder BUT the rest of them go into a TIGtools folder inside Plugins and even sub-folders within that...
          πŸ€“
          PS: These plugins works with SUp v6 and v7.
            dylan
            Just to let you know TIG and I'm not sure if anyone else has had this problem on a Mac, but I have an icon image missing.
            I installed the ruby and opened SU. The toolbar shows ok, but after closing down then re-opening, the first icon is blank.
            I can live with it, just thought I would report it.
            http://dmdarchitecture.co.uk/
              This was reported once before [that was on a Mac too when there were fewer tools http://forums.sketchucation.com/viewtopic.php?p=218480#p218480 think it was resolved by removing everything and reinstalling the whole set from scratch...].
              Are you sure you have all of the rb's and png's in the right folders ?
              There are currently only 7 tools - you show 8 - the extra [first] button is a 'false' one...
              What EEby.. tool does it open?
              It suggests to me that you have a duplicate rb loading from perhaps one of those Mac's dreaded extra 'personal' Plugins folders [scripts should all be in 'root' level Plugins folder ?].
              Use the Finder and search for any .rb files starting with ExtrudeEdgesBy... there should only be the 7 in the proper Plugins folder.
              There's also a toolbar loader called #extrusionToolbar.rb - that should also only be found in Plugins folder - that file just makes the toolbar for the other tools to add on too as they each load in turn...
                Here's an update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                There are a few minor tweaks to some db text and newly rephrased FR lingvo files by Didier Bur [sorry Pilou - he is a 'Professor' πŸ˜‰ ]
                πŸ€“
                  driven
                  Hi TIG, just for info, I still have the extra button, unless I close the toolbar and reopen after a SU restart, each time.
                  it's there even when TIGTools folder + rubies are the only items added to fresh instal of SU
                  doesn't hurt anything..
                    This extra button is a mystery as it only affects a few Mac users ???
                    Any Mac-users got any ideas ???
                    πŸ˜•
                      TIG,
                      This tool set has been a blessing. Have followed it closely since you first posted them as individual plugins. Must say it's a tremendous example scripting prowess that have moved the goal posts in terms of SU capabilities. Congrats!
                      Do you think it us possible to implement a coloured highlight feature which indicates rail selection from profile selection? Along the lines of Whaats SDS Crease tool. It would mimic what's seen in each icon. It's not really an issue more a graphical aid.
                      • C
                        chrisjk
                        TIG, in addition to your toolbar showing a blank button, I also get a blank button on my Mac with Jim Folz's MakeOrthoViews.rb I have no idea what causes it though. Maybe if you look at Jim's script it will give you a clue?
                        Edit - just realised Jim's script is encrypted!
                          TIG,
                          Thanks for the praise 😳
                          It would be possible to color profiles and rails differently rather than select them with the normal highlighting - but what colors would you like ? I could get it to trace over them with the 'draw' command while the tool is active with any standard colors you like ? I tend to avoid RGB as they are axial how about profile=cyan, rail1=magenta, rail2=dark_cyan and profile2=dark_magenta - it'll vary across tools as some have different selection needs etc - also the last item picked doesn't always highlight well - but that's the challenge ! πŸ€“
                            Thanks for the reply. I think your suggestion of colours is the way to go. And will compliment the tool quite well. I see how it can't be applied to certain tools but still think it'll be well received
                              Here's another update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                              The picked curves/faces etc are now highlighted and 'color-coded' [this depends on the tool***]
                              Typically they are:
                              Profile[Face] =Cyan
                              Rail/Rail1 = Magenta
                              Rail2 = DarkVioletRed
                              MeldingProfile[Face] = DarkCyan
                              OtherFace = Orange
                              ***See each Tools notes...
                              πŸ€“
                                EEbyRailsByFace has been fixed - glitches with curve selection and color-coding locations.
                                πŸ€“
                                  Here's the latest update - http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                  The Tooltips etc are now properly deBabelized into other languages...
                                  • U
                                    unclex
                                    Update Again……
                                    Wonderful things
                                    • H
                                      hsjzyangbin
                                      Thank you
                                        dedmin
                                        Is there a way to organize plugins into sub-menus?
                                          A bit off topic, but yes.
                                          See 'organizer' available on Smustard and also my earlier ideas drifting around where you could create your sub-menus in an early loading ruby [#.rb] and add your scripts to any one by giving them one of its global variables e.g. $submenu1 for the menu rather than "Plugins"...
                                          I use it to group my plugins as
                                          Construction[Guide] Tools
                                          2D Tools
                                          3D Shape Tools - Simple
                                          3D Shape Tools - Complex
                                          2D Manipulation Tools
                                          3D Manipulation Tools
                                          Camera/Image Tools
                                          Text/Dims Tools
                                          Terrain Tools
                                          Other Tools
                                          $submenu0 to $submenu9...
                                            dedmin
                                            πŸ‘ πŸ‘
                                            • 31
                                            • 32
                                            • 4 / 32
