    Rendering workshop - Whisky Glass
    71 Posts 19 Posters 18.4k Views 19 Watching
      d12dozr
      glass precedence setting is higher
      I am not sure what is meant by that.
      Pretty sure that is just an Indigo setting
      http://goo.gl/f7ooYh
      • david_hD
        david_h
        Things get a little mixed up around this here forum
          museummaker
          Win! 🤣
            d12dozr
            😆 nice David...render looks good too
            • T
              tomer1981
              Hey guys.
              For those of you who don't remember - I was the one who modeled the whiskey glass & ice cubes, and I'm quite honored that you all use it for your renders.
              I'm not quite familiar with the rendering program/plugin you're using, but in the I rendered it with FryRender (found at: http://www.randomcontrol.com/). I saw you were discussing the lighting methods for the rendering, and I must tell you (what you probably already know) - LIGHTING IS EVERYTHING. In my render I didn't use any light fixtures. Instead, I used an HDRI, for IBL (Image based lighting). Meaning - a 32 bit image (.hdr format), which is "wrapped" around an imaginary sphere around the model, and is applying light to the entire model. This method is extremely efficient, and gives awesome results, in less time.
              About the materials - Fryrender uses it's own materials, and it doesn't rely on the ones from sketchup. So, it doesn't matter what material you specify in sketchup (color, transparency, etc.) - the one you pick in Fryrender can be different.
              I don't know your rendering program, and I don't know if it supports IBL, but from what I see - it gives pretty nice renderings.
              You can check out more renderings i did with fryrender, and observe the lighting methods:
              http://www.flickr.com/photos/41836385@N07/sets/72157622515799491/
              • Al HartA
                Al Hart
                @tomer1981 said:
                Hey guys.
                I'm not quite familiar with the rendering program/plugin you're using, but in the I rendered it with FryRender.
                Thanks for creating the model for us, and the initial rendering. I'm sure you noticed that I added a comment to the model that it was being used for this Rendering Workshop.
                No particular rendering engine is featured in these workshops, but rather users of all rendering products are encouraged to demonstrate and improve their rendering skills through interaction with other users.
                Thank you for your comments on how you produced your renderings.
                For the record, here is tomer1981 rendering of the whiskey glass:
                http://farm5.static.flickr.com/4015/4318646787_0dafc71abe.jpg
                Al Hart
                IRender nXt from Render Plus
                  Sheik
                  One more for the road.
                  A small note on the model; you need to cut holes in the surface of the whiskey where the icecubes are, if you are using an physically accurate engine.
                  On the other hand this is actually a situation that render engines(atleast Maxwell) can´t get physically right. When light first enters from air to ice and then into whiskey, that ray of light will think it is in air, as it passed thru the backface of ice (not thru the frontface of whiskey). Still, the difference is probably very hard to see...
                  http://i832.photobucket.com/albums/zz242/Sheiken/whiskey4.jpg
                  • Al HartA
                    Al Hart
                    I started a new Workshop on Wood Cabinets.
                    These aren't as much fun as a Whiskey glass. But it might be worth honing your wood surfaces skills a bit...
                    404 Not Found
                    (forums.sketchucation.com)
                    Al Hart
                      richcat
                      Late as always - only just finished the bottle
                      My recent attempt
                      http://nxt.accurender.com/photos/sketchup/images/17514/800x600.aspx
                        richcat
                        Another late one this time with octane, just as I open another bottle 😉
                        I know - Wood texture probably not large enough, glass appears to be floating, and ice appears too silver? - but I'm looking through rose tinted specs, and I like it
                        • david_hD
                          david_h
                          Like I said. . .i am no judge of distilled beverages, but those look nice.
                          • soloS
                            Richard, I like the first one (above the Octane one), what render app did you use?
                              richcat
                              Hi Pete
                              IRender nXt, just honing my skills for the rendering competition, don't get much chance to render or model this time of year as most of my projects open in the next couple of weeks
                                FYI to you lot rendering these ice cubes: if you render with VfSU you could submit it to the current ASGVis Render competition. The topic is ice: http://forum.asgvis.com/index.php?topic=7520.0
                                • charly2008C
                                  charly2008
                                  With Fryrender can even beginners achieve respectable results.
                                  • 4 / 4
