    Rendering workshop - Whisky Glass
    71 Posts 19 Posters 17.1k Views 19 Watching
    • W Offline
      Whaat
      This has been running for 38 hours.
      Hey modelhead. Some things to keep in mind with Indigo:
      Indigo uses physically based parameters. One of the keys for a render like this is that you have to tell Indigo what medium 'displaces' another. This is done with the 'precedence' settings. For example, we want the ice to displace the whiskey so make sure that the precedence setting for the ice is a higher number than the whiskey.
      Also, when modeling a liquid in a glass, it is important that the surface of the liquid is actually 'inside' the glass. Then, you need to ensure that the glass precedence setting is higher than the whiskey so that the glass will 'displace' the whiskey.
      I would lower the absorption of the whiskey using the SketchUp opacity setting as well.
      Hope this makes sense. 😄
      • david_hD Offline
        david_h
        This would help a lot of people I would expect. 💚
        I am not sure what is meant by that.
        Sorry I am so thick. 😳
          d12dozr
          Pretty sure that is just an Indigo setting
          http://goo.gl/f7ooYh
          • david_hD Offline
            david_h
            Things get a little mixed up around this here forum
              museummaker
              Win! 🤣
                d12dozr
                😆 nice David...render looks good too
                  tomer1981
                  Hey guys.
                  For those of you who don't remember - I was the one who modeled the whiskey glass & ice cubes, and I'm quite honored that you all use it for your renders.
                  I'm not quite familiar with the rendering program/plugin you're using, but in the I rendered it with FryRender (found at: http://www.randomcontrol.com/). I saw you were discussing the lighting methods for the rendering, and I must tell you (what you probably already know) - LIGHTING IS EVERYTHING. In my render I didn't use any light fixtures. Instead, I used an HDRI, for IBL (Image based lighting). Meaning - a 32 bit image (.hdr format), which is "wrapped" around an imaginary sphere around the model, and is applying light to the entire model. This method is extremely efficient, and gives awesome results, in less time.
                  About the materials - Fryrender uses it's own materials, and it doesn't rely on the ones from sketchup. So, it doesn't matter what material you specify in sketchup (color, transparency, etc.) - the one you pick in Fryrender can be different.
                  I don't know your rendering program, and I don't know if it supports IBL, but from what I see - it gives pretty nice renderings.
                  You can check out more renderings i did with fryrender, and observe the lighting methods:
                  http://www.flickr.com/photos/41836385@N07/sets/72157622515799491/
                  • Al HartA Offline
                    Al Hart
                    @tomer1981 said:
                    Hey guys.
                    I'm not quite familiar with the rendering program/plugin you're using, but in the I rendered it with FryRender.
                    Thanks for creating the model for us, and the initial rendering. I'm sure you noticed that I added a comment to the model that it was being used for this Rendering Workshop.
                    No particular rendering engine is featured in these workshops, but rather users of all rendering products are encouraged to demonstrate and improve their rendering skills through interaction with other users.
                    Thank you for your comments on how you produced your renderings.
                    For the record, here is tomer1981 rendering of the whiskey glass:
                    http://farm5.static.flickr.com/4015/4318646787_0dafc71abe.jpg
                    Al Hart
                    IRender nXt from Render Plus
                      Sheik
                      One more for the road.
                      A small note on the model; you need to cut holes in the surface of the whiskey where the icecubes are, if you are using an physically accurate engine.
                      On the other hand this is actually a situation that render engines(atleast Maxwell) can´t get physically right. When light first enters from air to ice and then into whiskey, that ray of light will think it is in air, as it passed thru the backface of ice (not thru the frontface of whiskey). Still, the difference is probably very hard to see...
                      http://i832.photobucket.com/albums/zz242/Sheiken/whiskey4.jpg
                      • Al HartA Offline
                        Al Hart
                        I started a new Workshop on Wood Cabinets.
                        These aren't as much fun as a Whiskey glass. But it might be worth honing your wood surfaces skills a bit...
                        http://forums.sketchucation.com/viewtopic.php?f=15&t=26005
                        Al Hart
                          richcat
                          Late as always - only just finished the bottle
                          My recent attempt
                          http://nxt.accurender.com/photos/sketchup/images/17514/800x600.aspx
                            richcat
                            Another late one this time with octane, just as I open another bottle 😉
                            I know - Wood texture probably not large enough, glass appears to be floating, and ice appears too silver? - but I'm looking through rose tinted specs, and I like it
                            • david_hD Offline
                              david_h
                              Like I said. . .i am no judge of distilled beverages, but those look nice.
                              • soloS Offline
                                Richard, I like the first one (above the Octane one), what render app did you use?
                                  richcat
                                  Hi Pete
                                  IRender nXt, just honing my skills for the rendering competition, don't get much chance to render or model this time of year as most of my projects open in the next couple of weeks
                                    FYI to you lot rendering these ice cubes: if you render with VfSU you could submit it to the current ASGVis Render competition. The topic is ice: http://forum.asgvis.com/index.php?topic=7520.0
                                    • charly2008C Offline
                                      charly2008
                                      With Fryrender can even beginners achieve respectable results.
                                      • 4 / 4
