    Set.insert vs array << x unless array.include?(x)
    19 Posts 7 Posters 26.3k Views 7 Watching
      Will have a look
      Will have a look at that.
        I'll be damned!
        Very interesting Jernej.
        ...looks like I need to do some more testing of my script and possibly refactor again.
        So while the Array.include? is dead slow - the overhead of hash look-up is still faster than just adding everything into one big pile and so a single filtering afterwards...
          looking at the .uniq! source code: http://ruby-doc.org/core/classes/Array.src/M002215.html
           *  call-seq;
           *     array.uniq! -> array or nil
           *  Removes duplicate elements from _self_.
           *  Returns <code>nil</code> if no changes are made (that is, no
           *  duplicates are found).
           *     a = [ "a", "a", "b", "b", "c" ]
           *     a.uniq!   #=> ["a", "b", "c"]
           *     b = [ "a", "b", "c" ]
           *     b.uniq!   #=> nil
          static VALUE
          rb_ary_uniq_bang(ary)
              VALUE ary;
              VALUE hash, v, vv;
              long i, j;
              hash = ary_make_hash(ary, 0);
              if (RARRAY(ary)->len == RHASH(hash)->tbl->num_entries) {
                  return Qnil;
              for (i=j=0; i<RARRAY(ary)->len; i++) {
                  v = vv = rb_ary_elt(ary, i);
                  if (st_delete(RHASH(hash)->tbl, (st_data_t*)&vv, 0)) {
                      rb_ary_store(ary, j++, v);
              RARRAY(ary)->len = j;
              return ary;
            Jernej: how about larger iterations and higher number of random values?
              Jernej Vidmar
              How about using Array.uniq! method:
              Test 1
              t=Time.now;a=[];10000000.times{r=rand(10);a<<r unless a.include?(r)};puts Time.now - t
              Result: 12.297
              t=Time.now;a=Set.new;10000000.times{a.insert(rand(10))};puts Time.now - t
              Result: 15.719
              t=Time.now;a=[];10000000.times{r=rand(10);a<<r};a.uniq!; puts Time.now - t
              Result: 7.753
              Test 2
              t=Time.now;a=[];100000.times{r=rand(10000);a<<r unless a.include?(r)};puts Time.now-t
              Result: 40.97
              t=Time.now;a=Set.new;100000.times{a.insert(rand(10000))};puts Time.now-t
              Result: 0.377
              t=Time.now;a=[];100000.times{r=rand(10000);a<<r};a.uniq!;puts Time.now-t
              Result: 0.087
                Jernej Vidmar
                t=Time.now;a=Set.new;10000000.times{a.insert(rand(10000))};puts Time.now - t
                Result: 37.911
                t=Time.now;a=[];10000000.times{r=rand(10000);a<<r};a.uniq!; puts Time.now - t
                Result: 8.282
                Still a winner?
                  It's refactoring time!
                  Nice find! πŸ‘
                    RickW
                    That's all great (using .uniq!) until you start dealing with Point3d objects πŸ˜„
                    In that case, always use Set.
                    RickW
                    www.smustard.com
                      ....or make all of your Point3d's into arrays so they will sort!/uniq! etc as arrays...
                        But is the overhead of converting the Point3d's into arrays and uniq! faster than using a Set?
                          Who knows ?
                          Time for you to do another test... πŸ˜‰
                          • honoluludesktopH
                            honoluludesktop
                            I probably don't know what I am doing, but I ran the following test, and obtained the attached results. I typically use array.push variable, and don't understand the situations when the other examples might be used. Btw, when I applied the other forms to my app, it failed in ways that leave me to believe that those forms are data sensitive. Can anyone explaine to a Ruby beginner what's up?
                            t=Time.now
                            a=[]
                            100000.times do r=rand(10000)
                              a<<r
                            a.uniq!
                            puts Time.now-t
                            0.125
                            t=Time.now
                            a=[]
                              a.push r
                            a.uniq!
                            puts Time.now-t
                            0.141
                            t=Time.now
                            a=[]
                              a.push r
                            puts Time.now-t
                            0.094
                            t=Time.now
                            a=[]
                              a<<r
                            puts Time.now-t
                            0.093
