Set.insert vs array << x unless array.include?(x)
I was curious of the difference between
Set.insert
vsarray << x unless array.include?(x)
when you want a collection with a unique set of values.So I did some tests:
Test 1
A 10,000,000 times I tried to insert a number between 0-10.t=Time.now;a=[];10000000.times{r=rand(10);a<<r unless a.include?(r)};puts Time.now - t
Result: 12.297t=Time.now;a=Set.new;10000000.times{a.insert(rand(10))};puts Time.now - t
Result: 15.719The array was faster here by three seconds. But that's with ten million iterations!
Test 2
But, when your collection of unique values increases:
t=Time.now;a=[];100000.times{r=rand(10000);a<<r unless a.include?(r)};puts Time.now - t
Result: 45.129t=Time.now;a=Set.new;100000.times{a.insert(rand(10000))};puts Time.now - t
Result: 0.391When your collection include a much higher number of elements - then the Array quickly starts to crumble. In this case, when the possible unique set was up to 100,000 the difference was 44.738 seconds!!!
I tried this in some of my scrips which on occasions require a unique set of entites (like collecting all vertices) and the speed difference was immense on larger models.
It doesn't take too many number of unique elements before
Set
becomes faster thenarray.include?
.Scaling
Just to illustrate how they scale:
Array.include?
t=Time.now;a=[];1000.times{r=rand(100);a<<r unless a.include?(r)};puts Time.now - t
0.0
t=Time.now;a=[];10000.times{r=rand(1000);a<<r unless a.include?(r)};puts Time.now - t
0.485
42.906
t=Time.now;a=[];1000000.times{r=rand(100000);a<<r unless a.include?(r)};puts Time.now - t
Took too long. I guess it'd take ~4000.0sSet.insert
t=Time.now;a=Set.new;1000.times{a.insert(rand(100))};puts Time.now - t
0.0
t=Time.now;a=Set.new;10000.times{a.insert(rand(1000))};puts Time.now - t
0.047
0.422
t=Time.now;a=Set.new;1000000.times{a.insert(rand(100000))};puts Time.now - t
4.937Conclusion (not!)
%(#aaaaaa)[Use theSet
class when you require a unique set of values - unless your set of unique values is very small.
Set
class is the rule -Array.include?
is the exception.]Update
None of the above is the fastest. A better way has appeared. Collect everything into an array and apply [ruby:2yy3xvjs].unique![/ruby:2yy3xvjs] at the end.
http://forums.sketchucation.com/viewtopic.php?f=180&t=23760&p=222231#p222221 -
Also,
Set.include?
is faster thanArray.include?
Tom,
very useful actually.
It really looks that the processsing in C is a lot faster than in Ruby.Thanks
Tom,
Set
class makes more processing in C?
What I'm wondering is, theSet
class in SU Ruby is not the sameSet
class you get in Ruby 1.8.0. TheSet
class in Ruby 1.8.0 includesEnumerable
and the set.rb looks to be a pure ruby class that mixes arrays and hashes. From my Ruby 1.8.0. installation, theSet
class seem to be a pure Ruby implementation. But maybe the Set class that comes with SU is a C implementation...? Maybe that's why they replaced it? -
I thought the speed difference was that the Set class used a more efficient Hash lookup as oppose to the Array functions that has to iterate the array every time... but that's just guesswork...
You're right.
I personally useHash
whenever I want to store lists that have unique elements.
The list itself is obtained viaHash.values
.Maybe, as you are on this, you extend your benchmark to
Hash
and see how it compares withSet
.Fred
Great info Thom! I had played around with sets and arrays before and I was not impressed with sets. But I did not experiment with amount of unique objects, which apparently has an adverse effect on arrays. Thanks,
I'll be damned!
Very interesting Jernej....looks like I need to do some more testing of my script and possibly refactor again.
So while the
Array.include?
is dead slow - the overhead of hash look-up is still faster than just adding everything into one big pile and so a single filtering afterwards... -
looking at the .uniq! source code: http://ruby-doc.org/core/classes/Array.src/M002215.html
/* * call-seq; * array.uniq! -> array or nil * * Removes duplicate elements from _self_. * Returns <code>nil</code> if no changes are made (that is, no * duplicates are found). * * a = [ "a", "a", "b", "b", "c" ] * a.uniq! #=> ["a", "b", "c"] * b = [ "a", "b", "c" ] * b.uniq! #=> nil */ static VALUE rb_ary_uniq_bang(ary) VALUE ary; { VALUE hash, v, vv; long i, j; hash = ary_make_hash(ary, 0); if (RARRAY(ary)->len == RHASH(hash)->tbl->num_entries) { return Qnil; } for (i=j=0; i<RARRAY(ary)->len; i++) { v = vv = rb_ary_elt(ary, i); if (st_delete(RHASH(hash)->tbl, (st_data_t*)&vv, 0)) { rb_ary_store(ary, j++, v); } } RARRAY(ary)->len = j; return ary; }
Jernej: how about larger iterations and higher number of random values?
How about using Array.uniq! method:
Test 1
Result: 12.297
Result: 15.719
t=Time.now;a=[];10000000.times{r=rand(10);a<<r};a.uniq!; puts Time.now - t
Result: 7.753Test 2
t=Time.now;a=[];100000.times{r=rand(10000);a<<r unless a.include?(r)};puts Time.now-t
Result: 40.97
t=Time.now;a=Set.new;100000.times{a.insert(rand(10000))};puts Time.now-t
Result: 0.377
t=Time.now;a=[];100000.times{r=rand(10000);a<<r};a.uniq!;puts Time.now-t
Result: 0.087 -
t=Time.now;a=Set.new;10000000.times{a.insert(rand(10000))};puts Time.now - t
Result: 37.911
t=Time.now;a=[];10000000.times{r=rand(10000);a<<r};a.uniq!; puts Time.now - t
Result: 8.282Still a winner?
It's refactoring time!
Nice find!
That's all great (using .uniq!) until you start dealing with Point3d objects
In that case, always use Set. -
....or make all of your Point3d's into arrays so they will sort!/uniq! etc as arrays...
But is the overhead of converting the Point3d's into arrays and uniq! faster than using a Set?
Who knows ?
Time for you to do another test... -
I probably don't know what I am doing, but I ran the following test, and obtained the
attached results
. I typically usearray.push variable
, and don't understand the situations when the other examples might be used. Btw, when I applied the other forms to my app, it failed in ways that leave me to believe that those forms are data sensitive. Can anyone explaine to a Ruby beginner what's up?t=Time.now a=[] 100000.times do r=rand(10000) a<<r end a.uniq! puts Time.now-t
0.125
t=Time.now a=[] 100000.times do r=rand(10000) a.push r end a.uniq! puts Time.now-t
0.141
t=Time.now a=[] 100000.times do r=rand(10000) a.push r end puts Time.now-t
0.094
t=Time.now a=[] 100000.times do r=rand(10000) a<<r end puts Time.now-t
0.093
