    Set.insert vs array << x unless array.include?(x)
    19 Posts 7 Posters 26.3k Views 7 Watching
      I thought the speed difference was that the Set class used a more efficient Hash lookup as oppose to the Array functions that has to iterate the array every time... but that's just guesswork...
      • fredo6F
        You're right.
        I personally use Hash whenever I want to store lists that have unique elements.
        The list itself is obtained via Hash.values.
        Maybe, as you are on this, you extend your benchmark to Hash and see how it compares with Set.
        Fred
        • Chris FullmerC
          Great info Thom! I had played around with sets and arrays before and I was not impressed with sets. But I did not experiment with amount of unique objects, which apparently has an adverse effect on arrays. Thanks,
            Will have a look
            Will have a look at that.
              I'll be damned!
              Very interesting Jernej.
              ...looks like I need to do some more testing of my script and possibly refactor again.
              So while the Array.include? is dead slow - the overhead of hash look-up is still faster than just adding everything into one big pile and so a single filtering afterwards...
                looking at the .uniq! source code: http://ruby-doc.org/core/classes/Array.src/M002215.html
                 *  call-seq;
                 *     array.uniq! -> array or nil
                 *  Removes duplicate elements from _self_.
                 *  Returns <code>nil</code> if no changes are made (that is, no
                 *  duplicates are found).
                 *     a = [ "a", "a", "b", "b", "c" ]
                 *     a.uniq!   #=> ["a", "b", "c"]
                 *     b = [ "a", "b", "c" ]
                 *     b.uniq!   #=> nil
                static VALUE
                rb_ary_uniq_bang(ary)
                    VALUE ary;
                    VALUE hash, v, vv;
                    long i, j;
                    hash = ary_make_hash(ary, 0);
                    if (RARRAY(ary)->len == RHASH(hash)->tbl->num_entries) {
                        return Qnil;
                    for (i=j=0; i<RARRAY(ary)->len; i++) {
                        v = vv = rb_ary_elt(ary, i);
                        if (st_delete(RHASH(hash)->tbl, (st_data_t*)&vv, 0)) {
                            rb_ary_store(ary, j++, v);
                    RARRAY(ary)->len = j;
                    return ary;
                  Jernej: how about larger iterations and higher number of random values?
                    Jernej Vidmar
                    How about using Array.uniq! method:
                    Test 1
                    t=Time.now;a=[];10000000.times{r=rand(10);a<<r unless a.include?(r)};puts Time.now - t
                    Result: 12.297
                    t=Time.now;a=Set.new;10000000.times{a.insert(rand(10))};puts Time.now - t
                    Result: 15.719
                    t=Time.now;a=[];10000000.times{r=rand(10);a<<r};a.uniq!; puts Time.now - t
                    Result: 7.753
                    Test 2
                    t=Time.now;a=[];100000.times{r=rand(10000);a<<r unless a.include?(r)};puts Time.now-t
                    Result: 40.97
                    t=Time.now;a=Set.new;100000.times{a.insert(rand(10000))};puts Time.now-t
                    Result: 0.377
                    t=Time.now;a=[];100000.times{r=rand(10000);a<<r};a.uniq!;puts Time.now-t
                    Result: 0.087
                      Jernej Vidmar
                      t=Time.now;a=Set.new;10000000.times{a.insert(rand(10000))};puts Time.now - t
                      Result: 37.911
                      t=Time.now;a=[];10000000.times{r=rand(10000);a<<r};a.uniq!; puts Time.now - t
                      Result: 8.282
                      Still a winner?
                        It's refactoring time!
                        Nice find! 👍
                          RickW
                          That's all great (using .uniq!) until you start dealing with Point3d objects 😄
                          In that case, always use Set.
                          RickW
                          www.smustard.com
                            ....or make all of your Point3d's into arrays so they will sort!/uniq! etc as arrays...
                              But is the overhead of converting the Point3d's into arrays and uniq! faster than using a Set?
                                Who knows ?
                                Time for you to do another test... 😉
                                • honoluludesktopH
                                  honoluludesktop
                                  I probably don't know what I am doing, but I ran the following test, and obtained the attached results. I typically use array.push variable, and don't understand the situations when the other examples might be used. Btw, when I applied the other forms to my app, it failed in ways that leave me to believe that those forms are data sensitive. Can anyone explaine to a Ruby beginner what's up?
                                  t=Time.now
                                  a=[]
                                  100000.times do r=rand(10000)
                                    a<<r
                                  a.uniq!
                                  puts Time.now-t
                                  0.125
                                  t=Time.now
                                  a=[]
                                    a.push r
                                  a.uniq!
                                  puts Time.now-t
                                  0.141
                                  t=Time.now
                                  a=[]
                                    a.push r
                                  puts Time.now-t
                                  0.094
                                  t=Time.now
                                  a=[]
                                    a<<r
                                  puts Time.now-t
                                  0.093
