    [Plugin] Extrude Edges by Rails
    381 Posts 71 Posters 366.4k Views 71 Watching
      @cmoreink said:
      I give up, it's a no go 😒
      I also installed EEbR v2.4 but no show 😒
      Don't give up !
      Any v6 users out there getting goodresults ?
      πŸ˜•
        Maybe a problem of video card?
        Or conflict with another plug?
        Where is the file for test it?
        I have no problem with the V6 πŸ˜‰
          cmoreink
          I'm running some tests with free v7.1 and I'll have an answer soon
          I do believe that there is a conflict with another plug.
          Which file test? TIGs or mine?
          Mr. TIG
          I just finished testing EEbR v2.4 on SU v7.1 (free) and it worked πŸ˜„ so I strongly believe that there is a conflict between plugins (now I just have to find which ones)
          I'm also attaching my plugins list, do you see a plug that it could conflict with your EEbR?
          my portfolio
            Yours πŸ˜‰
            But as seems it works now in the V7 seems that is not your file πŸ˜„
            I have 10* yours plugs in the V6 and no problem πŸ˜‰
              I've looked at your list and Vray.. is the only one I'm unsure of - try renaming it with .txt at the end temporarily so it doesn't load and retry EEbyR.
              I can't see what might be the problem with a clash πŸ˜•
              • kenK Offline
                ken
                Thanks for these very useful plugins and the toolbars. I am sending a 3d PDF attached file of a rubber check valve. The rubber top section, I don't know how I could have made it without your plugins.
                Open the file with Adobe Reader 9.2 and you should see the model in the 3d viewer mod.
                Again TIG thanks
                Ken
                ToTig.pdf
                  Ken
                  Thanks for the praise - glad my tools are useful...
                  Good to see some different types of use - looks quite technical...
                  Here are a couple of 'stills' for others to see... hope you don't mind...ToTigEEby--Illus.pngToTigEEby--.png
                  • JClementsJ Offline
                    JClements
                    Ken, nice one.
                    I did this four years ago. Wish I would have had the script then.
                    What application did you use to create the 3D PDF?
                    • kenK Offline
                      ken
                      @jclements said:
                      Ken, nice one.
                      [attachment=0:29uq011g]<!-- ia0 -->Floatable_Control_-_Netbag_Retrofit -_2004.jpg<!-- ia0 -->[/attachment:29uq011g]
                      I used the following program.
                      http://www.simlab-soft.com/3d-plugins/3D-PDF-from-sketchup-main.aspx
                      I saw it here at this forum and thought it would be nice to send my office updates without them having to send SketchUp files. So far it has preformed exactly as I had hoped. A little on the expensive side, but I can keep the office informed in my progress without them having a big mess of SketchUp files to sort though. I am quite pleased.
                      Like your illustration.
                      I find it amazing all the different illustrations my company ask me to do. Every day a different challenge.
                      Ken
                        @Tig
                        Does it normal than profile don't touch to the created surface?
                        pasting.skp
                          @Tig
                          No, it's not normal. The profiles and rails should always be coincident with the mesh's edges IF they have common end vertices. The rials always touch - the profiles might not if they don't join onto the rails ??? ... πŸ˜•
                            So this is a valid or not choice of curves?
                            Yes BUT because the Profile is take from a Rail end to a Rail end it will look like this, as if you had drawn the arch-profile across the ends...Untitled.png
                                How do make for have "shadow" under the Profile line? 😲
                                • jeff hammondJ Offline
                                    THX! The Duhduh of the day! Never used! πŸ˜† 😳
                                      balloon
                                      Fantastic plugin! Thank you very much!! πŸ‘
                                      • DareDevilD Offline
                                        DareDevil
                                        Hello...
                                        First of all, is the first time I post here, so I want to thanks TIG and all for these fabulous SU plugs that expend SU possibilities !!!
                                        So, I use EEbyrails and other EE (and other plugs) for non standard architectural modeling. I use some other soft (MoI, Rhino, C4D, Revit...) but I want to use SU cause is the simply free way to teach 3D modeling to my students.
                                        But, when I try to make a free profile helix EEbyrails have some problems :
                                        http://d2design.free.fr/perso/helix.jpg
                                        http://d2design.free.fr/perso/helix.skp
                                        If I to with helix as rails, some profiles are 180Β° rotated (I can manualy rotate to have the good result), an if I use the NURBS as rails, the profile is not the same along the helix.
                                        Is it a bug or a problem with my model ?
                                          I will say your curves but don't know why! 😳 πŸ˜‰
                                          Ps Post also on the French forum πŸ˜‰
                                          Go to your tab Private messages then Tab Users group then enable that you want πŸ˜‰
                                          helix.skp
                                            DareDevil
                                            I tried with your file Pilou, and no problem πŸ˜’
                                            I dont know how you made your helix. Mine was made with dynamic componant with a single point inside, copied with some sin and cos formula in the X an Y value, and manualy joined with line finaly welded. This way to draw the helix perhaps cause the bug ?
                                            I also tried with odd number of point in the helix, so no point at 180Β° to the start position, and all it's ok. πŸ‘
                                            So I know how manualy fix the problem πŸ˜‰
                                            PS@Pilou : Damned ! you know I'm french ! πŸ˜„
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 19
                                            • 20
                                            • 14 / 20
