    [Plugin] Extrude Edges by Rails
    381 Posts 71 Posters 378.0k Views 71 Watching
      So this is a valid or not choice of curves?
      Yes BUT because the Profile is take from a Rail end to a Rail end it will look like this, as if you had drawn the arch-profile across the ends...Untitled.png
          How do make for have "shadow" under the Profile line? ๐Ÿ˜ฒ
          • jeff hammondJ Offline
              THX! The Duhduh of the day! Never used! ๐Ÿ˜† ๐Ÿ˜ณ
                balloon
                Fantastic plugin! Thank you very much!! ๐Ÿ‘
                • DareDevilD Offline
                  DareDevil
                  Hello...
                  First of all, is the first time I post here, so I want to thanks TIG and all for these fabulous SU plugs that expend SU possibilities !!!
                  So, I use EEbyrails and other EE (and other plugs) for non standard architectural modeling. I use some other soft (MoI, Rhino, C4D, Revit...) but I want to use SU cause is the simply free way to teach 3D modeling to my students.
                  But, when I try to make a free profile helix EEbyrails have some problems :
                  http://d2design.free.fr/perso/helix.jpg
                  http://d2design.free.fr/perso/helix.skp
                  If I to with helix as rails, some profiles are 180ยฐ rotated (I can manualy rotate to have the good result), an if I use the NURBS as rails, the profile is not the same along the helix.
                  Is it a bug or a problem with my model ?
                    I will say your curves but don't know why! ๐Ÿ˜ณ ๐Ÿ˜‰
                    Ps Post also on the French forum ๐Ÿ˜‰
                    Go to your tab Private messages then Tab Users group then enable that you want ๐Ÿ˜‰
                    helix.skp
                      DareDevil
                      I tried with your file Pilou, and no problem ๐Ÿ˜’
                      I dont know how you made your helix. Mine was made with dynamic componant with a single point inside, copied with some sin and cos formula in the X an Y value, and manualy joined with line finaly welded. This way to draw the helix perhaps cause the bug ?
                      I also tried with odd number of point in the helix, so no point at 180ยฐ to the start position, and all it's ok. ๐Ÿ‘
                      So I know how manualy fix the problem ๐Ÿ˜‰
                      PS@Pilou : Damned ! you know I'm french ! ๐Ÿ˜„
                        Sometimes curves are 'muddled' in the database and then exploding and remaking them, or cutting and paste_in_place or grouping and exploding them fixes this type of bug.
                        However, I tried exploding the curves and remade them with little improvement - same or very similar problems.
                        It seems to be a shortcoming of the script.
                        At least you know how to work around it - just pick different pairs of profiles and rails to get what you want.
                        I can't immediately see what's causing the problem - the algorithm for working out which end is next to which is quite convoluted as there are many permutations...
                        BUT it's puzzling as seems to work initially whichever order you pick in, but falls apart in some case at some points along the curve ???
                        The spiraling helix must make a few of the points rotated by 180 degrees too much/little in certain locations around the rails - It's probably fixable, but so rare it's not been reported before...
                        I'll look at it...
                        ๐Ÿ˜’ ๐Ÿ˜•
                          A new version is now available here http://forums.sketchucation.com/viewtopic.php?p=217663#p217663 which fixes the helical rail glitch that was reported...
                            DareDevil
                            ๐Ÿ˜ It's working ! Thanks you TIG !
                              Tool has been updated
                              2.9 20100220 Color coding of picked curves added.
                              Profile=Cyan
                              Rail1=Magenta
                              Rail2=DarkVioletRed
                              MeldingProfile=DarkCyan
                              See here for download link http://forums.sketchucation.com/viewtopic.php?p=201286#p201286
                                stefx
                                I have missed the website for a bit and I see this wonderful plugin!
                                I was waiting for that since long time....for many shapes i was still using rhino's tool:sweep2rails.
                                I am going to play with that but I want to ask:
                                I create due rails e my curve profile and it works well, but if I would like just a line rather than a curve....it looks like an error.
                                Sorry probably i have to read better, anyone has a simple answer?
                                thank you.
                                  stefx
                                  I am still trying...but not results... ๐Ÿ˜ž
                                  When i try to select a simple line rather than a curve (just the first step before the selection of the 2 rails), it is impossible to select anything, but if i draw a curve it wors immediately.
                                  It looks like strange!
                                  I know....it is a stupid error by me!
                                    I calll the plug then click a "line" first: no problem โ˜€
                                    Sure! you have not divided it!!! ๐Ÿ˜‰ 'see my previous post! ๐Ÿค“
                                    A simple line not divided can't be selected !
                                    • X Offline
                                      xrok1
                                      i've even downloaded the example file and the latest .zip and i still can't get this to work. the lines change colors, i get all the dialog boxes reverse...etc, but no result. ๐Ÿ˜ข
                                      โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
                                        stefx
                                        Thank you very much Pilou!
                                        Job Done!
                                        I needed so much that script working well because i need to create something like that:
                                        http://img403.imageshack.us/img403/1400/catturaspirale.jpg
                                        I have seen something similar in this topic.
                                        I need 2 different spiral curve and then a surface that run through the 2 spirals.
                                        Any tips?
                                          No problem
                                          Draw your 2 helix curves and just one "divided line"
                                          Call the plug, CLick the line, CLick curve rail 1, click curve rail 2, click again the line!
                                          I suggest you to draw just one module then make a group or a component then copy past it!
                                            stefx
                                            Job done!
                                            Thank you!
                                            Quick and without problems!
                                            I have tried to download the plugin "curvemaker" from the website http://www.drawmetal.com but the website doesn't work. Any info about that?
                                            I think that could be a good plugin.
                                            thanks a lot!
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 19
                                            • 20
                                            • 14 / 20
