    [Plugin] Manifold v2.2
    126 Posts 19 Posters 61.2k Views 19 Watching
      driven
      EDIT: CRASHED OUT SU 20 seconds no crash report, and SU restarted on a new drawing, now that has [bnever happened before, and I mean everever SU doesn't restart....[/b]]I let it cook and see the results it in the morning...
      how odd, so I think I'll play some more
        Run with the Ruby Console open for error reports - a new version will be available soon that I hope will be more robust...
          @tig said:
          Three-faced-edged external-faces now usually kept. [fixed TT's ball-breaker boxy mess πŸ˜„ ]
          Very interesting. I was stomped on this when I some time ago tried to make a remove_inner_faces script. Will have to snoop around the code. I'll probably dig up some more fun geometry - thing I got a batch of trouble-samples... πŸ˜„
            @tig said:
            I'm thinking perhaps to move these vertices to heal these tiny gaps rather than fail making edges that are too small inside a 'rescue' ?
            You need to rescue? Doesn't add_face return nil if it fails?
              Yes BUT then I do things with the face that fail if it's nil - if the points are non-planar - which I can't see how but it rarely says they are - perhaps co-linear there's an error - therefore a rescue seems appropriate - I need to look at how I get these points.
              At the moment to 'heal' a gap we find an edge with only one face and if it has a shared vertex with another edge then we try to use three points from their vertices' points to make a face - however it's possible for the points to be co-linear or virtually so and no face gets made... I'm looking at a more robust algorithm that ensure such edges are 'faceable' before trying it... πŸ˜’
                That was a quick fix BUT it will fail with very convoluted shapes that have inner faces like driven's pretzel ! I looking at an even better fix...
                • EarthMoverE Offline
                  EarthMover
                  I'm still a little confused about the use of this plugin. Would it be of any value for anyone who is not doing 3D printing?
                  Content Creator at Skapeup
                    Probably not... but it does remove internal partition faces in a volume and fixes any 'holes'... πŸ˜„
                      driven
                      any form of additive or subtractive rapid prototyping will require good clean meshes to work from, 3D printing is just one of many format used on a day to day basis.
                      in more generalised modeling if you ever intersect or bool two solids and then try to continue with more advanced manipulations (readily available to SU ruby users) then chances are at some stage you've had to manually repair the mesh, this tool does it for you.
                      I was doing test last night using it between bool operations on the standard SU shapes, and was surprised. A. how many little holes it found and B. how many holes the bool tool had left.
                      Rendering engines that have been developed for solids will perform much quicker on a manifold objects
                      So if you never use need to modify after intersecting two objects, and only ever upload to google earth or make sheet material products then this type of tool is probably not needed...
                        driven
                        took 15 mins but did a fine job this one TIG
                        34000 polys
                        • N Offline
                          notareal
                          Nice... apart from 3D printing. I think this can be used for healing models for rendering... when dielectric or SSS materials are used, there are a similar requirement as for 3D printing.
                          Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                            EarthMover
                            Can you elaborate? Curious about the logic of the renderer. Would it be similarly for meshes requiring displacement?
                              driven
                              I know when I put a light source inside that dragon before xmas, light leaked out of all the holes in the mesh, so I had to fix them. cap hole didn't do it. you had ago at that one didn't you?
                                EarthMover
                                I did. I didn't have any issue with light leaks...but I used a higher poly version than most.
                                I wasn't sure if the plugin subdivided the mesh as well. I guess I should download and try. I keep telling myself I have to stop adding unnecessary plugins as it is becoming hard to deal with a plugins list three pages long!! Time to clean house.
                                • Chris FullmerC Offline
                                  Just remember while you are cleaning house, all mine fit nicely into a single menu item πŸ˜„
                                  TIG, this is a WAAAY COOL plugin! I have no idea how it works, but it has been on my list of plugins I'd like to write some day. This is invaluable for file conversion and mesh cleanup and 3d printing, and, and, and...
                                    driven
                                    time comparison
                                    some time check, sorry the fonts so small.
                                      EarthMover
                                      ....and I can't thank you enough for having the foresight to do that. I wish there were some way to better organize all the scripters plugins as you have with yours.
                                        Here's v1.3 http://forums.sketchucation.com/viewtopic.php?p=218691#p218691
                                        1.3 20100126
                                        Trapped near colinear/planar points giving healing crashes.
                                        Very small edges [0.1mm] now 'erased' by combining their vertices.
                                        Orienting faces is now 'foolproof' - unless it's not made 'manifold'.
                                        Now it only asks Yes/No to change to Xray mode if that's not on already.
                                        Unhealed or Failed Fixes now reported, with failed edges shown as ... or -.- clines in Error Group.
                                        [TIP: Move or Copy the error-group to one side to better see any errors - but if there are red/green faces obscuring the error dotted-lines showing problem edges etc then edit this error-group by treble clicking on a face till you have selected all then delete-key - now the error dotted-lines [clines] can be seen... manually edit and then retry 'manifold']
                                        TO DO: Get three-faced-edges external-faces to be retained in 'pretzels'. πŸ˜’ groan......
                                        Feedback please...
                                          driven
                                          I was about to post a drawing with timings for 1.2 and VolumeCalc2, so I'lll re-run it with 1.3, should be interesting..... cheers TIG, watch this space
                                            Tig, did you see this post by Google's Tyler: http://forums.sketchucation.com/viewtopic.php?f=15&t=25175&p=218997#p218989
                                            Might be useful to predict when SU will be able to create faces/edges?
                                            • 3 / 7
