    [Plugin] Manifold v2.2
    126 Posts 19 Posters 68.6k Views 19 Watching
      @earthmover said:
      I'm still a little confused about the use of this plugin. Would it be of any value for anyone who is not doing 3D printing?
      Probably not... but it does remove internal partition faces in a volume and fixes any 'holes'... πŸ˜„
        driven
        any form of additive or subtractive rapid prototyping will require good clean meshes to work from, 3D printing is just one of many format used on a day to day basis.
        in more generalised modeling if you ever intersect or bool two solids and then try to continue with more advanced manipulations (readily available to SU ruby users) then chances are at some stage you've had to manually repair the mesh, this tool does it for you.
        I was doing test last night using it between bool operations on the standard SU shapes, and was surprised. A. how many little holes it found and B. how many holes the bool tool had left.
        Rendering engines that have been developed for solids will perform much quicker on a manifold objects
        So if you never use need to modify after intersecting two objects, and only ever upload to google earth or make sheet material products then this type of tool is probably not needed...
          driven
          took 15 mins but did a fine job this one TIG
          34000 polys
          • N Offline
            notareal
            Nice... apart from 3D printing. I think this can be used for healing models for rendering... when dielectric or SSS materials are used, there are a similar requirement as for 3D printing.
            Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
            • EarthMoverE Offline
              EarthMover
              Can you elaborate? Curious about the logic of the renderer. Would it be similarly for meshes requiring displacement?
              Content Creator at Skapeup
                driven
                I know when I put a light source inside that dragon before xmas, light leaked out of all the holes in the mesh, so I had to fix them. cap hole didn't do it. you had ago at that one didn't you?
                  EarthMover
                  I did. I didn't have any issue with light leaks...but I used a higher poly version than most.
                  I wasn't sure if the plugin subdivided the mesh as well. I guess I should download and try. I keep telling myself I have to stop adding unnecessary plugins as it is becoming hard to deal with a plugins list three pages long!! Time to clean house.
                  • Chris FullmerC Offline
                    Just remember while you are cleaning house, all mine fit nicely into a single menu item πŸ˜„
                    TIG, this is a WAAAY COOL plugin! I have no idea how it works, but it has been on my list of plugins I'd like to write some day. This is invaluable for file conversion and mesh cleanup and 3d printing, and, and, and...
                      driven
                      time comparison
                      some time check, sorry the fonts so small.
                        EarthMover
                        ....and I can't thank you enough for having the foresight to do that. I wish there were some way to better organize all the scripters plugins as you have with yours.
                          Here's v1.3 http://forums.sketchucation.com/viewtopic.php?p=218691#p218691
                          1.3 20100126
                          Trapped near colinear/planar points giving healing crashes.
                          Very small edges [0.1mm] now 'erased' by combining their vertices.
                          Orienting faces is now 'foolproof' - unless it's not made 'manifold'.
                          Now it only asks Yes/No to change to Xray mode if that's not on already.
                          Unhealed or Failed Fixes now reported, with failed edges shown as ... or -.- clines in Error Group.
                          [TIP: Move or Copy the error-group to one side to better see any errors - but if there are red/green faces obscuring the error dotted-lines showing problem edges etc then edit this error-group by treble clicking on a face till you have selected all then delete-key - now the error dotted-lines [clines] can be seen... manually edit and then retry 'manifold']
                          TO DO: Get three-faced-edges external-faces to be retained in 'pretzels'. πŸ˜’ groan......
                          Feedback please...
                            driven
                            I was about to post a drawing with timings for 1.2 and VolumeCalc2, so I'lll re-run it with 1.3, should be interesting..... cheers TIG, watch this space
                              Tig, did you see this post by Google's Tyler: http://forums.sketchucation.com/viewtopic.php?f=15&t=25175&p=218997#p218989
                              Might be useful to predict when SU will be able to create faces/edges?
                                Thanks - I did - hence the small line 'erasing' algorithm... πŸ˜‰
                                  @driven said:
                                  Hi all
                                  can anyone confirm if they can see TIGtoolbar, while running manifold1.3, this drawing really slow compared to 1.2 and I just noticed I don't have the TIG-RRby icons in the toolbar which have never vanished before....
                                  Check your files are in the same folders as shown in the original zip ?
                                  It might be a bit slower running because the new algorithms ?
                                  Try it one something simpler first ?? πŸ˜‰
                                    driven
                                    Hi all
                                    johnEDIT: TOOLbar sorted didn't update TIG folder in my rush to try 1.3, so that shouldn't effect performance, must be something else
                                      driven
                                      @tig said:
                                      @driven said:
                                      Hi all
                                      I was editing while you were writing, and yes Ill go back to the slow start procedure, It was simply tea time and I though "this model works with 1,2, I'll just quickly re-run it, etc.."
                                        driven
                                        from my understanding...
                                        I've got the reference somewhere if you want me dig it out, this is two two manifold objects sharing an edge...
                                        basic are quicker, easy start...
                                        • N Offline
                                          notareal
                                          Light leaks are one issue. But more problematic could be if you like to produce caustics or SSS (not single face). Broken mesh might not be that obvious like it's with light leak, but result will be wrong... you just wonder why you cannot get proper caustics.
                                            driven
                                            TIG,
                                            This would pass
                                            probably showing the obvious
                                            • 3 / 7
