    [Plugin] Manifold v2.2
    126 Posts 19 Posters 82.5k Views 19 Watching
      How do you determine what an internal face is?
        See the code remove_inner_faces() - it seems to work... probably break when pressed ??? This is my first beta release...
        I had a complex method involving doing an MIR type scan slice in the Z and then the X [to catch flat internal faces] progressively through the group [though not needed at every 0.5mm since we can determine any 3-faced edges and just start a small amount into them to get the relevant faces] and then intersecting the slice with the group and finding any split surfaces made where an internal face intersected it etc and then finding a point on that split-line and testing it to see if it was on a face that's internal and then erasing it etc etc... BUT dough-nut shaped groups really screwed this up so I reverted to the simpler version you see here... πŸ˜’
          It sure seem to work at whatever I've thrown at it so far.
          Mind if I sample the code logic for an implementation in Cleanup?
          btw:
          Error; #<NoMethodError; undefined method `db' for #<Sketchup;;Face;0xf54e668>>
          C;/PROGRA~2/Google/GOOGLE~1/Plugins/manifold.rb;293;in `orient_manifold_faces'
          C;/PROGRA~2/Google/GOOGLE~1/Plugins/manifold.rb;332;in `orient_faces'
          C;/PROGRA~2/Google/GOOGLE~1/Plugins/manifold.rb;330;in `each'
          C;/PROGRA~2/Google/GOOGLE~1/Plugins/manifold.rb;330;in `orient_faces'
          C;/PROGRA~2/Google/GOOGLE~1/Plugins/manifold.rb;95;in `activate'
          C;/PROGRA~2/Google/GOOGLE~1/Plugins/manifold.rb;454;in `select_tool'
          C;/PROGRA~2/Google/GOOGLE~1/Plugins/manifold.rb;454;in `manifold'
          C;/PROGRA~2/Google/GOOGLE~1/Plugins/manifold.rb;470
          C;/PROGRA~2/Google/GOOGLE~1/Plugins/manifold.rb;470;in `call'
          though the script appear to complete...
          And why did you comment out the disable_ui argument? (line 85) @model.start_operation((db("Manifold")))#,true) ### ?
            On a sidenote: you can save some lines in your remove_inner_faces method by using more of Ruby's Enumerator and Array methods:
            def remove_inner_faces()
            	faces = @gents.select { |e| e.class==Sketchup;;Face }
            	faces_to_go = faces.select { |face| face.outer_loop.edges.any? { |e| e.faces.length > 2  } }
            	faces_to_go.each{|e|
            		if e.valid?
            			clone_removed_into_error_group([e]+e.edges)
            			e.erase! if e.valid?
            		end#if
            I just noticed them not too long ago while having another look at the Ruby docs, I realised I could cut down a number of lines in most my scripts.
              Just noticed, when I reload your script, load 'manifold.rb' it keeps adding more menu items.
              Think it's because of the last line: file_loaded(__FILE__)
              Should it not be: file_loaded(File.basename(__FILE__)) ?
                Just realised the cause of the error I reported earlier:
                You're calling msg=(db("Manifold: Orienting Faces")) from within the class Sketchup::Face scope, while db() is defined within the Manifold class.
                Making db() into a Class method instead of Instance method def self.db(string) and changing
                msg=(db("Manifold: Orienting Faces")) to msg=(Manifold.db("Manifold: Orienting Faces")) (line 304)
                and
                puts(db("Manifold: orient faces aborted.")) to puts(Manifold.db("Manifold: orient faces aborted.")) (line 318)
                makes it work.
                  The groups that it creates, is it suppose to be offset from the original group?
                    whopops ! update in the pipeline... 😳
                    I'll also fix the db() error...
                      > 		if e.valid?
                      > 		end#if
                      > end
                      Never mind this code. Seems to have a bug in it.
                        Got a case where the internal faces is removing too much. See attached file. Run the script on the large cube.
                        manifold tester.skp
                          Here's v1.1 with some glitch fixes http://forums.sketchucation.com/viewtopic.php?p=218691#p218691
                            I'll look into it...
                            EDIT: removes innermost groups of outer-faces [?] AND leaves internal-faces edges behind [that's an easy fix] ❓
                              driven
                              fantastic,
                              go out on a family errand and come back to a whole new playing field, anything I can do to help?
                              a 'test' skp, if you need something more taxing,
                              or I'll try repairing it myself when you've got the next one up...
                              or need a tester... whatever you need...
                              this slow to hand stitch example of what I'm try to do with 3D printed stainless
                              about 25% of the poly count I would normally use for this sort of thing, and not triangulated.
                                driven
                                I'll look at your problem - TT has already come up with one set of problems to fix !
                                With yours I get a non-planar points error - since there's only 3 of them it seems a bit strange... πŸ˜•
                                We're really at 'beta' testing now - I only outlined the ideas some hours ago and issued this as my first go - it WILL get better πŸ˜‰
                                  Very useful for boats builders πŸ˜‰
                                    driven
                                    and don't forget the humble Air Bed makers of the world...
                                    TIG,
                                    I did this simply to save you having to draw-up or look for something relevant to test on
                                    the last 3 letters in watertight might contain none planer points, one had to be over-drawn with a poly-line and two unsoftened with eraser on the bottoms, before I could JPP them, oh the bottom of that A I made a real hash of.. missed it out and went back... I was in a rush...
                                    I made the ring quite well, two joints (triangulated) near you name, I chose a ragged font in an attempt to create tiny voids and was surprised how well it came out. Fredo's Joint PushPull is remarkably clean, I have another test piece on file that is pilfered with bad seams if that's more useful.
                                    I'll give anything a spin, it's great that your on the case...
                                      Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=218691#p218691
                                      Basic Ticker added. Better processing for inner faces.
                                      Three-faced-edged external-faces now usually kept. [fixed TT's ball-breaker boxy mess πŸ˜„ ]
                                      FR lingvo updated by Pilou. πŸ˜‰
                                      Still struggling with driven's monster...
                                      More feedback and ideas please... πŸ€“
                                        driven
                                        More feedback and ideas please... :ugeek:
                                        that's the simple version, so far it's taken 2hrs 14 min and 49seconds just to explode all the groups so I can then re-group to test the plug on it (and it's only 600,000+ poly's)
                                        I just fired up the other computer so I'll do some simple tests on it, while I wait
                                          I've added some more error reporting in the console to my own version so I can at least see what these errors are - seems related almost exclusively now to healing very tiny holes ?
                                          I'm thinking perhaps to move these vertices to heal these tiny gaps rather than fail making edges that are too small inside a 'rescue' ? It would change the model's form, but so slightly you'd never notice...
                                          Watch this space πŸ€“
                                            driven
                                            Did you scale it up even more?
                                            • 1 / 7
