    New API doc - typos and questions
    370 Posts 35 Posters 269.8k Views 35 Watching
      @thomthom said:
      Sketchup.write_default
      Sketchup.read_default
      http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/sketchup.html#write_default
      http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/sketchup.html#read_default
      [..] the string associated with a value within the specified sub-section section of a .INI file or registry (within the Software > @Last Software > SketchUp section).
      Is it really stored under @Last any more?
      No, / Google / Sketchup 7 / etc... πŸ˜‰
        Group.move!
        http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/group.html#move!
        .move! moves to an absolute point. Worth noting in the manual.
        • Dan RathbunD Offline
          Dan Rathbun
          Geom::Point3d.+
          http://code.google.com/apis/sketchup/docs/ourdoc/point3d.html#+
          The '+' operator is a fast way to add to the current x, y and z values of a point, or to set the values of a point by adding to other points together.
          The end of the sentence should read, "...by adding **two** other points together."
          Returns:
          vector a Vector object
          There is no defined object named 'vector'. If we follow the example the class of the result is given as Geom::Point3d.
          pt2 = Geom;;Point3d.new(100,200,300)
          pt3 = pt2 + [1,1,1]
          >> Point3d(101, 201, 301)
          pt3.class
          >> Geom;;Point3d
          Arguments:
          point2 A Point3d object.
          An ArugemtError exception is raised if point2 is a Point3d object.
          Valid argument classes are: Array or Vector3d. This means to use a Point3d as an argument, you must convert to Array. Example:
          pt3 = pt1 + pt2.to_a
          This method needs to be fixed to take a Point3d object and internally convert it to an Array...
          # internal to + method
          if arg[0].is_a? Point3d { arg[0]=arg[0].to_a }
          ...or a Vector3d:
          if arg[0].is_a? Point3d { arg[0]=[0,0,0].vector_to(arg[0]) }
          either way. The current implementation is clumsy.
          I'm not here much anymore.
            Dan Rathbun
            **Geom::Point3d.-**
            http://code.google.com/apis/sketchup/docs/ourdoc/point3d.html#-
            Returns:
            There is no defined object named 'vector', but there IS one named ' Vector3d'. If we follow the example the class of the result is given as Geom::Vector3d.
            pt3 = pt2 - [1,1,1]
            >> Vector3d(99, 199, 299)
            pt3.class
            >> Geom;;Vector3d
            It seems a bit strange that + returns Point3d, but - returns Vector3d.
              Dan Rathbun
              Geom::Point3d.offset
              Code example has errors:
              [line1]replace"point ="with"point1 ="
              [line1]use parameter delimiters both lines
              [line3]replace".offset**!**"with".offset"
              add comments
              Corrected code:
              point1 = Geom;;Point3d.new(10,10,10)
              vector = Geom;;Vector3d.new(0,0,1)
              point2 = point1.offset vector
              # point1 is unchanged
              # point2 is Point3d(10, 10, 11)
              Geom::Point3d.offset!
              add comments
              point2 = point1.offset! vector
              # point1 now equals point2
                Dan Rathbun
                Geom::Vector3d.x=
                http://code.google.com/apis/sketchup/docs/ourdoc/vector3d.html#x=
                Geom::Vector3d.y=
                http://code.google.com/apis/sketchup/docs/ourdoc/vector3d.html#y=
                Geom::Vector3d.z=
                http://code.google.com/apis/sketchup/docs/ourdoc/vector3d.html#z=
                #Anchors: '=' char should be replaced with 'equals' in links.
                All 3 methods suffer from the same return class anomoly as the Vector3d.[]= method, in that they return the class of the argument (which may not always be Float.) In contrast, the .x, .y and .z methods always return class Float.
                Propose that the .x=, .y= and .z= methods should be modified to return Float as the .x, .y and .z methods do.
                Propose to add note: "See the **.set!** method to set all three coordinates in one statement." ( .. to the description sections, of each of the three methods.)
                  Dan Rathbun
                  Geom::Vector3d.set!
                  http://code.google.com/apis/sketchup/docs/ourdoc/vector3d.html#set!
                  This is a shortcut for writing:
                  Clarify: "This is a shortcut for setting all coordinates of the vector, instead of setting them individually in three statements."
                  You may also call this method with an array or another vector:
                  Confusing. (I first took this mean that the SU extended Array class had an Array.set! method; which is NOT the case.)
                  Clarify: "You may also call this method with an Array or a Vector3d object as the first argument,(and any other arguments will then be ignored.)"
                  Add: "If only one Numeric argument is supplied, or if a one element Array is supplied, then only the x value will be changed. IF only 2 values are supplied, in the same way, then the z value will remain unchanged.
                  All coordinate values must be implicitly convertable to Float class.
                  (If you pass a nil value, a TypeError exception is raised.)"
                  Arguments:
                  x ____ The x value for the vector.
                  y ____ The y value for the vector.
                  z ____ The z value for the vector.
                  vector2 ____ A Vector3d object.
                  Remove 4th argument. (There is no valid fourth argument for this method. All args beyond 3 are ignored.)
                  Clarify: (suggested Argument list)
                  Arguments:
                  x ____ The x value for the vector, a Vector3d object, or an Array.
                  y ____ The y value for the vector. (optional)
                  z ____ The z value for the vector. (optional)
                  Better Code Example:
                  vector = Geom;;Vector3d.new 0,0,1
                  vector.set! 1,0,0  # three Numeric arguments
                  vector2 = Geom;;Vector3d.new 1,2,3
                  vector.set! vector2  # one Vector3d argument
                  # vector now is (1,2,3)
                  array1 = Array.new(4,5,6)
                  vector.set! array1[2]  # one Numeric argument
                  # vector now is (6,2,3)
                  vector2.set! array1  # one Array argument
                  # vector2 now is (4,5,6)
                  vector.set! [5,4]  # one Array with 2 values
                  # vector now is (5,4,3)
                  # change x and z in one statement, this way;
                  vector.set! 9, vector.y, 8
                  # vector now is (9,4,8)
                    Dan Rathbun
                    Geom::Vector3d.[=]
                    [="]http://code.google.com/apis/sketchup/docs/ourdoc/vector3d.html#[]=[/url]
                    Again the HTML anchor may cause problems in some browsers, suggest '#subscriptEquals'
                    Obviously the #[]= anchor tag in the url cannot even be displayed properly in this forum.All of the #anchor links to methods using special chars need to be changed to comply with the HTML spec, as ThomThom noted:
                    ID and NAME tokens must begin with a letter ([A-Za-z]) and may be followed by any number of letters, digits ([0-9]), hyphens ("-"), underscores ("_"), colons (":"), and periods ("."). [url:nfjuel6m]http://www.w3.org/TR/html4/types.html#type-name]("http)
                    Returns:
                    value _______ the newly set coordinate value
                    the Geom::Vector3d.[] method returns class Float
                    BUT, the Geom::Vector3d.[]= method returns the class of the argument.
                    The code example may be misleading to the unwary,
                    value = vector[i] = coordinate
                    ..if the class of the coordinate variable is Integer then the class of the value variable will also be Integer.
                    This causes a coder to do a two-step expression if they want a Float, ie:
                    coordinate = 2
                    vector[i] = coordinate # returns Integer 2
                    value = vector[i]  # value.class >> Float
                    %(#FF4000)[Two Issues:
                    1. Is 'coordinate' the correct term, or would 'component' be a better term when refering to vectors?1. If all the rest of the methods that return subscript values from a Vector3d object are Float, then perhaps this method should as well, regardless of the class of the argument.]
                      Dan Rathbun
                      Geom::Point3d.<
                      http://code.google.com/apis/sketchup/docs/ourdoc/point3d.html#%3C
                      Returns:
                      true if the point2 is closer to the origin.
                      Following the example, I get the opposite result.
                      TheReturns:should probably read,
                      " *true* if the point2 is **farther** from the origin; *false* if the point2 is closer to the origin (than the receiver.)
                        @thomthom said:
                        Group.move!
                        It doesn't seem to though - we've been testing it in another thread this afternoon and it seem that it moves relative to the transformation-origin NOT the model's ORIGIN - you first have to do a transformation by vector from where it is to the ORIGIN and then off again to the absolute point ?
                          @dan rathbun said:
                          Ruby code can no longer use the nil return value in a conditional boolean statement.
                          There is also no way now to determine how many Dictionary objects, there are within an AttributeDictionaries collection (No Methods: .size, .length, .count, or .empty?)
                          There are no methods but several easy combos to do it...
                          You make an array of it and than get its length ?
                          len = AttributeDictionaries.to_a.length
                          or use 'each' ?
                          len = 0;AttributeDictionaries.each{|d|len += 1}
                          Where len is the AttributeDictionaries length ?
                            AttributeDictionaries.to_a.length works.
                              ComponentInstance.explode
                              http://code.google.com/apis/sketchup/docs/ourdoc/componentinstance.html#explode
                              Code example is irrelevant - doesn't show the use of .explode.
                                RenderingOptions
                                http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/renderingoptions.html
                                FogColor
                                # FogDensity
                                FogEnd
                                FogStart
                                # FogType
                                FogUseBkColor
                                Bold entries returns nil.
                                The RenderingOptions I get when I iterate the collection is:
                                BackgroundColor
                                BandColor
                                ConstructionColor
                                DepthQueWidth
                                DisplayColorByLayer
                                DisplayDims
                                DisplayFog
                                DisplayInstanceAxes
                                DisplaySketchAxes
                                DisplayText
                                DisplayWatermarks
                                DrawDepthQue
                                DrawGround
                                DrawHidden
                                DrawHorizon
                                DrawLineEnds
                                DrawProfilesOnly
                                DrawSilhouettes
                                DrawUnderground
                                EdgeColorMode
                                EdgeDisplayMode
                                EdgeType
                                ExtendLines
                                FaceBackColor
                                FaceColorMode
                                FaceFrontColor
                                FogColor
                                FogEndDist
                                FogStartDist
                                FogUseBkColor
                                ForegroundColor
                                GroundColor
                                GroundTransparency
                                HideConstructionGeometry
                                HighlightColor
                                HorizonColor
                                InactiveHidden
                                InstanceHidden
                                JitterEdges
                                LineEndWidth
                                LineExtension
                                LockedColor
                                MaterialTransparency
                                ModelTransparency
                                RenderMode
                                SectionActiveColor
                                SectionCutWidth
                                SectionDefaultCutColor
                                SectionInactiveColor
                                ShowViewName
                                SilhouetteWidth
                                SkyColor
                                Texture
                                TransparencySort
                                If the differences is due to changes between SU version I hope the docs will say when they where removed instead of removing them from the manual. Good to know the history.
                                • chrisglasierC Offline
                                  chrisglasier
                                  Probably picked up before but I just noticed it. So just in case ...
                                  Drawingelement.visible=SketchUp 6.0+
                                  The visible= method is used to set the visible status for an element. This method performs an opposite function to the hidden= method.
                                  Arguments:
                                  visibility true if you want to hide the element, false if not
                                  Returns:
                                  status true if the element has been hidden, false if the element has not been hidden.
                                    Dan Rathbun
                                    My previous post onSketchup::AttributeDictionarieshas been REVISED See the original post:
                                    http://forums.sketchucation.com/posting.php?mode=reply&f=180&t=17047#pr218516
                                      Dan Rathbun
                                      AttributeDictionaries (Introduction )
                                      http://code.google.com/apis/sketchup/docs/ourdoc/attributedictionaries.html
                                      You access this class not by performing an AttributeDictionaries.new but by grabbing a handle from an existing entity.
                                      ... which is refering to Sketchup::Entity.attribute_dictionaries
                                      http://code.google.com/apis/sketchup/docs/ourdoc/entity.html#attribute_dictionaries
                                      @dan rathbun said:
                                      http://forums.sketchucation.com/viewtopic.php?f=180&t=17047&p=208352#p208352
                                      This only works for model objects (seems the model has an empty dictionary list by default.) Other entities will return nil (as they do not have an AttributeDictionaries object created until after an AttributeDictionary has been attached.); the API should note that first a script needs to create an AttributeDictionary object, before the AttributeDictionaries object can be 'grabbed' (because it does not yet exist.)
                                      UPDATE (2010JAN23-DanRathbun) PC ver 7.1.6860:
                                      REVISED (2010JAN28-DanRathbun):In, SU ver 7.1, IF the Dynamic Components extension is turned OFF, the entity.attribute_dictionariesmethod will appear to always return aSketchup::AttributeDictionariesobject for the entity, regardless of whether there are any memberSketchup::AttributeDictionary%(#4040BF)[objects.
                                      In addition, (if DCs are OFF,) all of the methods of the]Sketchup::AttributeDictionaryclass (except.name,) will no longer work!
                                      Theentity.attribute_dictionariesmethod was NOT changed in the previous release, as I thought. The method works as the API says it does, returning "nil if there are none." BUT the Dynamic Components extension must be enabled."
                                      There is also no way to determine how many Dictionary objects, there are within an AttributeDictionaries collection (NoMethods: .size, .length, .count, or .empty?)
                                        Dan Rathbun
                                        Re: General
                                        @richmorin said:
                                        Class and method names could be turned into links
                                        to the appropriate API page, for ease of navigation.
                                        Rich, note the left Nav column. The second box labeled "Quick Reference" has exactly these Class index and Method index links.
                                        Re: Array class Introduction
                                        @richmorin said:
                                        Specific
                                        http://code.google.com/apis/sketchup/docs/ourdoc/array.html
                                        > The SketchUp Array class adds ...
                                        > SketchUp adds ...
                                        The correct ruby term is **extends** (as in extending a base class.) The way it is currently worded, a reader might misconstrue that the class is a custom class within the Sketchup namespace (ie, Sketchup::Array ), which is NOT the case. My version would read " Sketchup extends the standard Ruby Array class with additional methods.."
                                        @richmorin said:
                                        (same subject... Array class Introduction)
                                        > Specifically, it contains methods ...
                                        > Specifically, it adds methods ...
                                        The word ***add*** is better here, because it's more specific (as to the manner in which the base Array class was extended.)
                                        Re: AttributeDictionaries.each
                                        > ... all of the attributes dictionaries.
                                        >                attribute
                                        For clarity I would suggest rewording the method description as: " *The each method is used to iterate through the entire list of attribute dictionary objects*."
                                        Throws an exception if there are no keys.
                                        (1) What specific exception is thrown? KeyError or IndexError or a custom SU error class? (the API should state what it is we may need to trap with a rescue clause.)
                                        (2) Error conditions are not documented in a uniform manner throughout the API. Sometimes they are noted in the method description paragraph; sometimes (as in this case,) as a separate paragraph of the description section; other times in the ***Returns:*** section. Perhaps it's time to add a third ***Exceptions:*** section list, where the list labels would be exception class names and the defintion text would be the reason why the exception is raised.
                                        (3) Why does this method raise an exception, and the *.[]* method returns *nil* when there are no keys (or matches)? IMHO, the proper ruby way is to raise the correct exception in both cases, AND provide the *.empty?*, *.has_key?* and *.length* (or similar named) methods so scripts can use them in conditional statements when checking the Dictionary lists. Example:
                                         model = Sketchup.active_model
                                         attrdicts = model.attribute_dictionaries
                                         if not attrdicts.empty?
                                           attrdicts.each {|key,value| puts key.to_s+" is "+value.to_s }
                                         else
                                           puts "Dictionary List is Empty!"
                                        It just seems strange, as these are Array or Hash type classes, and they didn't inherit some of the basic funtionality, that they should have. Which brings us to...
                                        **(4) AttributeDictionaries.member?** is undocumented. Not that it does us any good, as it only takes an object, not a string name (returns false even for vaild dictionary names.) This means you need to know it exists in the first place, so why would we need to test it's membership? *.member?* is normally an alias for *.has_key?*, so if this method could be updated to ALSO take the dictionary string name, it would serve us well.
                                        Re: AttributeDictionaries Introduction
                                        This only works for [ruby:2bffgwcd]model[/ruby:2bffgwcd] objects (seems the model has an empty dictionary list by default.) Other entities will return nil (as they do not have an AttributeDictionaries object created until after an AttributeDictionary has been attached.); the API should note that first a script needs to create an AttributeDictionary object, before the AttributeDictionaries object can be 'grabbed' (because it does not yet exist.)
                                        REVISED (2010JAN28-DanRathbun) See later post (this forum):
                                        [url=http://forums.sketchucation.com/viewtopic.php?f=180&t=17047&p=218516#p218516:2bffgwcd]http://forums.sketchucation.com/viewtopic.php?f=180&...p218516[/url:2bffgwcd]
                                        [i:2bffgwcd]Re: AttributeDictionary Introduction[/i:2bffgwcd]
                                        An Entity or Model object can have any number of AttributeDictionaries.
                                        [url:2bffgwcd]http://code.google.com/apis/sketchup/docs/ourdoc/attributedictionary.html[/url:2bffgwcd]
                                        This is confounding the use of the two differnet class names. (The parent should have been named [i:2bffgwcd]DictionaryList[/i:2bffgwcd], or better yet, [i:2bffgwcd]AttributeLibrary[/i:2bffgwcd]. [as in: shelf space for many dictionary volumes.]) Actually each entity can have only 1 [ruby:2bffgwcd]AttributeDictionaries[/ruby:2bffgwcd] object. The sentecnce should read "[ruby:2bffgwcd]An Entity or Model object can have any number of AttributeDictionary objects[/ruby:2bffgwcd]."
                                        Both AttributeDictionaries and AttributeDictionary Introductions should have an 'also see note' directing readers to Entity class methods [ruby:2bffgwcd].attribute_dictionary[/ruby:2bffgwcd] and [ruby:2bffgwcd].attribute_dictionaries[/ruby:2bffgwcd] on how to create them.
                                        It would have been nice to have a [ruby:2bffgwcd]new[/ruby:2bffgwcd] method for the child dictionary objects at least. We could then call something like:
                                        myEntity = Sketchup.active_model.selection[0]
                                        # this is more intuitive
                                        attrdict = AttributeDictionary.new("My Dictionary", myEntity)
                                        # this is not so
                                        attrdict = myEntity.attribute_dictionary("My Dictionary", true)
                                          Layer.page_behavior
                                          http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/layer.html#page_behavior
                                          Only lists two flags:
                                          LAYER_VISIBLE_BY_DEFAULT 0x0000,
                                          LAYER_HIDDEN_BY_DEFAULT 0x0001.
                                          But Layer.page_behavior= lists other constants.
                                          http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/layer.html#page_behavior=
                                          * LAYER_USES_DEFAULT_VISIBILITY_ON_NEW_PAGES: 0x0000,
                                          * LAYER_IS_VISIBLE_ON_NEW_PAGES: 0x0010,
                                          * LAYER_IS_HIDDEN_ON_NEW_PAGES: 0x0020.
                                          Meaning the constants in the getter should be the same for the setter.
                                          LAYER_VISIBLE_BY_DEFAULT: 0x0000 LAYER_USES_DEFAULT_VISIBILITY_ON_NEW_PAGES: 0x0000 LAYER_HIDDEN_BY_DEFAULT: 0x0001 LAYER_IS_VISIBLE_ON_NEW_PAGES: 0x0010 LAYER_IS_HIDDEN_ON_NEW_PAGES: 0x0020
                                          And .page_behavior can be any bitwise combination of these.
                                            To create a layer which is only visible on a single page, you can set its page behavior flags to LAYER_HIDDEN_BY_DEFAULT | LAYER_IS_HIDDEN_ON_NEW_PAGES
                                            When I used that to set the behaviour of a layer on a model I get an error message when I save saying that something was messed up and this is the result of SU fixing it:
                                            Results of Validity Check.
                                            The behavior for CLayer (178941) is not valid - fixed
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 14 / 19
