    New API doc - typos and questions
    370 Posts 35 Posters 355.3k Views 35 Watching
      @thomthom said:
      Entities.add_curve
      http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/entities.html#add_curve
      Returns an array of edges - not a Curve object.
      Ita's the same as add_circle which returns an array od edges and to find the just made curves curve you use edges=entities.add_curve(array_of_points) curve=edges[0].curve
      But strangely not with add_arc which returns an ArcCurve ?
      It would be unadvisable to change what the API does with these add_ methods - rather it we should keep it as is and fix the API's Guide to reflect it properly - too many scripts already get the curve from the edges array and would fail if it were updated to return the curve not the curve's edges...
        Nope, also returns an array.
        Agree.
          Agree.
          Perhaps I meant to say, "... add_arc which says it returns an ArcCurve wrongly!" πŸ˜’
            Sketchup.write_default
            Sketchup.read_default
            http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/sketchup.html#write_default
            http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/sketchup.html#read_default
            [..] the string associated with a value within the specified sub-section section of a .INI file or registry (within the Software > @Last Software > SketchUp section).
            Is it really stored under @Last any more?
              No, / Google / Sketchup 7 / etc... πŸ˜‰
                Group.move!
                http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/group.html#move!
                .move! moves to an absolute point. Worth noting in the manual.
                • Dan RathbunD
                  Dan Rathbun
                  Geom::Point3d.+
                  http://code.google.com/apis/sketchup/docs/ourdoc/point3d.html#+
                  The '+' operator is a fast way to add to the current x, y and z values of a point, or to set the values of a point by adding to other points together.
                  The end of the sentence should read, "...by adding **two** other points together."
                  Returns:
                  vector a Vector object
                  There is no defined object named 'vector'. If we follow the example the class of the result is given as Geom::Point3d.
                  pt2 = Geom;;Point3d.new(100,200,300)
                  pt3 = pt2 + [1,1,1]
                  >> Point3d(101, 201, 301)
                  pt3.class
                  >> Geom;;Point3d
                  Arguments:
                  point2 A Point3d object.
                  An ArugemtError exception is raised if point2 is a Point3d object.
                  Valid argument classes are: Array or Vector3d. This means to use a Point3d as an argument, you must convert to Array. Example:
                  pt3 = pt1 + pt2.to_a
                  This method needs to be fixed to take a Point3d object and internally convert it to an Array...
                  # internal to + method
                  if arg[0].is_a? Point3d { arg[0]=arg[0].to_a }
                  ...or a Vector3d:
                  if arg[0].is_a? Point3d { arg[0]=[0,0,0].vector_to(arg[0]) }
                  either way. The current implementation is clumsy.
                  I'm not here much anymore.
                  • Dan RathbunD
                    Dan Rathbun
                    **Geom::Point3d.-**
                    http://code.google.com/apis/sketchup/docs/ourdoc/point3d.html#-
                    Returns:
                    There is no defined object named 'vector', but there IS one named ' Vector3d'. If we follow the example the class of the result is given as Geom::Vector3d.
                    pt3 = pt2 - [1,1,1]
                    >> Vector3d(99, 199, 299)
                    pt3.class
                    >> Geom;;Vector3d
                    It seems a bit strange that + returns Point3d, but - returns Vector3d.
                    • Dan RathbunD
                      Dan Rathbun
                      Geom::Point3d.offset
                      Code example has errors:
                      [line1]replace"point ="with"point1 ="
                      [line1]use parameter delimiters both lines
                      [line3]replace".offset**!**"with".offset"
                      add comments
                      Corrected code:
                      point1 = Geom;;Point3d.new(10,10,10)
                      vector = Geom;;Vector3d.new(0,0,1)
                      point2 = point1.offset vector
                      # point1 is unchanged
                      # point2 is Point3d(10, 10, 11)
                      Geom::Point3d.offset!
                      add comments
                      point2 = point1.offset! vector
                      # point1 now equals point2
                      • Dan RathbunD
                        Dan Rathbun
                        Geom::Vector3d.x=
                        http://code.google.com/apis/sketchup/docs/ourdoc/vector3d.html#x=
                        Geom::Vector3d.y=
                        http://code.google.com/apis/sketchup/docs/ourdoc/vector3d.html#y=
                        Geom::Vector3d.z=
                        http://code.google.com/apis/sketchup/docs/ourdoc/vector3d.html#z=
                        #Anchors: '=' char should be replaced with 'equals' in links.
                        All 3 methods suffer from the same return class anomoly as the Vector3d.[]= method, in that they return the class of the argument (which may not always be Float.) In contrast, the .x, .y and .z methods always return class Float.
                        Propose that the .x=, .y= and .z= methods should be modified to return Float as the .x, .y and .z methods do.
                        Propose to add note: "See the **.set!** method to set all three coordinates in one statement." ( .. to the description sections, of each of the three methods.)
                        • Dan RathbunD
                          Dan Rathbun
                          Geom::Vector3d.set!
                          http://code.google.com/apis/sketchup/docs/ourdoc/vector3d.html#set!
                          This is a shortcut for writing:
                          Clarify: "This is a shortcut for setting all coordinates of the vector, instead of setting them individually in three statements."
                          You may also call this method with an array or another vector:
                          Confusing. (I first took this mean that the SU extended Array class had an Array.set! method; which is NOT the case.)
                          Clarify: "You may also call this method with an Array or a Vector3d object as the first argument,(and any other arguments will then be ignored.)"
                          Add: "If only one Numeric argument is supplied, or if a one element Array is supplied, then only the x value will be changed. IF only 2 values are supplied, in the same way, then the z value will remain unchanged.
                          All coordinate values must be implicitly convertable to Float class.
                          (If you pass a nil value, a TypeError exception is raised.)"
                          Arguments:
                          x ____ The x value for the vector.
                          y ____ The y value for the vector.
                          z ____ The z value for the vector.
                          vector2 ____ A Vector3d object.
                          Remove 4th argument. (There is no valid fourth argument for this method. All args beyond 3 are ignored.)
                          Clarify: (suggested Argument list)
                          Arguments:
                          x ____ The x value for the vector, a Vector3d object, or an Array.
                          y ____ The y value for the vector. (optional)
                          z ____ The z value for the vector. (optional)
                          Better Code Example:
                          vector = Geom;;Vector3d.new 0,0,1
                          vector.set! 1,0,0  # three Numeric arguments
                          vector2 = Geom;;Vector3d.new 1,2,3
                          vector.set! vector2  # one Vector3d argument
                          # vector now is (1,2,3)
                          array1 = Array.new(4,5,6)
                          vector.set! array1[2]  # one Numeric argument
                          # vector now is (6,2,3)
                          vector2.set! array1  # one Array argument
                          # vector2 now is (4,5,6)
                          vector.set! [5,4]  # one Array with 2 values
                          # vector now is (5,4,3)
                          # change x and z in one statement, this way;
                          vector.set! 9, vector.y, 8
                          # vector now is (9,4,8)
                          • Dan RathbunD
                            Dan Rathbun
                            Geom::Vector3d.[=]
                            [="]http://code.google.com/apis/sketchup/docs/ourdoc/vector3d.html#[]=[/url]
                            Again the HTML anchor may cause problems in some browsers, suggest '#subscriptEquals'
                            Obviously the #[]= anchor tag in the url cannot even be displayed properly in this forum.All of the #anchor links to methods using special chars need to be changed to comply with the HTML spec, as ThomThom noted:
                            ID and NAME tokens must begin with a letter ([A-Za-z]) and may be followed by any number of letters, digits ([0-9]), hyphens ("-"), underscores ("_"), colons (":"), and periods ("."). [url:nfjuel6m]http://www.w3.org/TR/html4/types.html#type-name]("http)
                            Returns:
                            value _______ the newly set coordinate value
                            the Geom::Vector3d.[] method returns class Float
                            BUT, the Geom::Vector3d.[]= method returns the class of the argument.
                            The code example may be misleading to the unwary,
                            value = vector[i] = coordinate
                            ..if the class of the coordinate variable is Integer then the class of the value variable will also be Integer.
                            This causes a coder to do a two-step expression if they want a Float, ie:
                            coordinate = 2
                            vector[i] = coordinate # returns Integer 2
                            value = vector[i]  # value.class >> Float
                            %(#FF4000)[Two Issues:
                            1. Is 'coordinate' the correct term, or would 'component' be a better term when refering to vectors?1. If all the rest of the methods that return subscript values from a Vector3d object are Float, then perhaps this method should as well, regardless of the class of the argument.]
                            • Dan RathbunD
                              Dan Rathbun
                              Geom::Point3d.<
                              http://code.google.com/apis/sketchup/docs/ourdoc/point3d.html#%3C
                              Returns:
                              true if the point2 is closer to the origin.
                              Following the example, I get the opposite result.
                              TheReturns:should probably read,
                              " *true* if the point2 is **farther** from the origin; *false* if the point2 is closer to the origin (than the receiver.)
                                @thomthom said:
                                Group.move!
                                It doesn't seem to though - we've been testing it in another thread this afternoon and it seem that it moves relative to the transformation-origin NOT the model's ORIGIN - you first have to do a transformation by vector from where it is to the ORIGIN and then off again to the absolute point ?
                                  @dan rathbun said:
                                  Ruby code can no longer use the nil return value in a conditional boolean statement.
                                  There is also no way now to determine how many Dictionary objects, there are within an AttributeDictionaries collection (No Methods: .size, .length, .count, or .empty?)
                                  There are no methods but several easy combos to do it...
                                  You make an array of it and than get its length ?
                                  len = AttributeDictionaries.to_a.length
                                  or use 'each' ?
                                  len = 0;AttributeDictionaries.each{|d|len += 1}
                                  Where len is the AttributeDictionaries length ?
                                    AttributeDictionaries.to_a.length works.
                                      ComponentInstance.explode
                                      http://code.google.com/apis/sketchup/docs/ourdoc/componentinstance.html#explode
                                      Code example is irrelevant - doesn't show the use of .explode.
                                        RenderingOptions
                                        http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/renderingoptions.html
                                        FogColor
                                        # FogDensity
                                        FogEnd
                                        FogStart
                                        # FogType
                                        FogUseBkColor
                                        Bold entries returns nil.
                                        The RenderingOptions I get when I iterate the collection is:
                                        BackgroundColor
                                        BandColor
                                        ConstructionColor
                                        DepthQueWidth
                                        DisplayColorByLayer
                                        DisplayDims
                                        DisplayFog
                                        DisplayInstanceAxes
                                        DisplaySketchAxes
                                        DisplayText
                                        DisplayWatermarks
                                        DrawDepthQue
                                        DrawGround
                                        DrawHidden
                                        DrawHorizon
                                        DrawLineEnds
                                        DrawProfilesOnly
                                        DrawSilhouettes
                                        DrawUnderground
                                        EdgeColorMode
                                        EdgeDisplayMode
                                        EdgeType
                                        ExtendLines
                                        FaceBackColor
                                        FaceColorMode
                                        FaceFrontColor
                                        FogColor
                                        FogEndDist
                                        FogStartDist
                                        FogUseBkColor
                                        ForegroundColor
                                        GroundColor
                                        GroundTransparency
                                        HideConstructionGeometry
                                        HighlightColor
                                        HorizonColor
                                        InactiveHidden
                                        InstanceHidden
                                        JitterEdges
                                        LineEndWidth
                                        LineExtension
                                        LockedColor
                                        MaterialTransparency
                                        ModelTransparency
                                        RenderMode
                                        SectionActiveColor
                                        SectionCutWidth
                                        SectionDefaultCutColor
                                        SectionInactiveColor
                                        ShowViewName
                                        SilhouetteWidth
                                        SkyColor
                                        Texture
                                        TransparencySort
                                        If the differences is due to changes between SU version I hope the docs will say when they where removed instead of removing them from the manual. Good to know the history.
                                        • chrisglasierC
                                          chrisglasier
                                          Probably picked up before but I just noticed it. So just in case ...
                                          Drawingelement.visible=SketchUp 6.0+
                                          The visible= method is used to set the visible status for an element. This method performs an opposite function to the hidden= method.
                                          Arguments:
                                          visibility true if you want to hide the element, false if not
                                          Returns:
                                          status true if the element has been hidden, false if the element has not been hidden.
                                          • Dan RathbunD
                                            Dan Rathbun
                                            My previous post onSketchup::AttributeDictionarieshas been REVISED See the original post:
                                            http://forums.sketchucation.com/posting.php?mode=reply&f=180&t=17047#pr218516
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 14 / 19
