    New API doc - typos and questions
    370 Posts 35 Posters 310.8k Views 35 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      Geom::Vector3d.set!
      http://code.google.com/apis/sketchup/docs/ourdoc/vector3d.html#set!
      This is a shortcut for writing:
      Clarify: "This is a shortcut for setting all coordinates of the vector, instead of setting them individually in three statements."
      You may also call this method with an array or another vector:
      Confusing. (I first took this mean that the SU extended Array class had an Array.set! method; which is NOT the case.)
      Clarify: "You may also call this method with an Array or a Vector3d object as the first argument,(and any other arguments will then be ignored.)"
      Add: "If only one Numeric argument is supplied, or if a one element Array is supplied, then only the x value will be changed. IF only 2 values are supplied, in the same way, then the z value will remain unchanged.
      All coordinate values must be implicitly convertable to Float class.
      (If you pass a nil value, a TypeError exception is raised.)"
      Arguments:
      x ____ The x value for the vector.
      y ____ The y value for the vector.
      z ____ The z value for the vector.
      vector2 ____ A Vector3d object.
      Remove 4th argument. (There is no valid fourth argument for this method. All args beyond 3 are ignored.)
      Clarify: (suggested Argument list)
      Arguments:
      x ____ The x value for the vector, a Vector3d object, or an Array.
      y ____ The y value for the vector. (optional)
      z ____ The z value for the vector. (optional)
      Better Code Example:
      vector = Geom;;Vector3d.new 0,0,1
      vector.set! 1,0,0  # three Numeric arguments
      vector2 = Geom;;Vector3d.new 1,2,3
      vector.set! vector2  # one Vector3d argument
      # vector now is (1,2,3)
      array1 = Array.new(4,5,6)
      vector.set! array1[2]  # one Numeric argument
      # vector now is (6,2,3)
      vector2.set! array1  # one Array argument
      # vector2 now is (4,5,6)
      vector.set! [5,4]  # one Array with 2 values
      # vector now is (5,4,3)
      # change x and z in one statement, this way;
      vector.set! 9, vector.y, 8
      # vector now is (9,4,8)
      I'm not here much anymore.
        Dan Rathbun
        Geom::Vector3d.[=]
        [="]http://code.google.com/apis/sketchup/docs/ourdoc/vector3d.html#[]=[/url]
        Again the HTML anchor may cause problems in some browsers, suggest '#subscriptEquals'
        Obviously the #[]= anchor tag in the url cannot even be displayed properly in this forum.All of the #anchor links to methods using special chars need to be changed to comply with the HTML spec, as ThomThom noted:
        ID and NAME tokens must begin with a letter ([A-Za-z]) and may be followed by any number of letters, digits ([0-9]), hyphens ("-"), underscores ("_"), colons (":"), and periods ("."). [url:nfjuel6m]http://www.w3.org/TR/html4/types.html#type-name]("http)
        Returns:
        value _______ the newly set coordinate value
        the Geom::Vector3d.[] method returns class Float
        BUT, the Geom::Vector3d.[]= method returns the class of the argument.
        The code example may be misleading to the unwary,
        value = vector[i] = coordinate
        ..if the class of the coordinate variable is Integer then the class of the value variable will also be Integer.
        This causes a coder to do a two-step expression if they want a Float, ie:
        coordinate = 2
        vector[i] = coordinate # returns Integer 2
        value = vector[i]  # value.class >> Float
        %(#FF4000)[Two Issues:
        1. Is 'coordinate' the correct term, or would 'component' be a better term when refering to vectors?1. If all the rest of the methods that return subscript values from a Vector3d object are Float, then perhaps this method should as well, regardless of the class of the argument.]
          Dan Rathbun
          Geom::Point3d.<
          http://code.google.com/apis/sketchup/docs/ourdoc/point3d.html#%3C
          Returns:
          true if the point2 is closer to the origin.
          Following the example, I get the opposite result.
          TheReturns:should probably read,
          " *true* if the point2 is **farther** from the origin; *false* if the point2 is closer to the origin (than the receiver.)
            @thomthom said:
            Group.move!
            http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/group.html#move!
            .move! moves to an absolute point. Worth noting in the manual.
            It doesn't seem to though - we've been testing it in another thread this afternoon and it seem that it moves relative to the transformation-origin NOT the model's ORIGIN - you first have to do a transformation by vector from where it is to the ORIGIN and then off again to the absolute point ?
              @dan rathbun said:
              Ruby code can no longer use the nil return value in a conditional boolean statement.
              There is also no way now to determine how many Dictionary objects, there are within an AttributeDictionaries collection (No Methods: .size, .length, .count, or .empty?)
              There are no methods but several easy combos to do it...
              You make an array of it and than get its length ?
              len = AttributeDictionaries.to_a.length
              or use 'each' ?
              len = 0;AttributeDictionaries.each{|d|len += 1}
              Where len is the AttributeDictionaries length ?
                AttributeDictionaries.to_a.length works.
                  ComponentInstance.explode
                  http://code.google.com/apis/sketchup/docs/ourdoc/componentinstance.html#explode
                  Code example is irrelevant - doesn't show the use of .explode.
                    RenderingOptions
                    http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/renderingoptions.html
                    FogColor
                    # FogDensity
                    FogEnd
                    FogStart
                    # FogType
                    FogUseBkColor
                    Bold entries returns nil.
                    The RenderingOptions I get when I iterate the collection is:
                    BackgroundColor
                    BandColor
                    ConstructionColor
                    DepthQueWidth
                    DisplayColorByLayer
                    DisplayDims
                    DisplayFog
                    DisplayInstanceAxes
                    DisplaySketchAxes
                    DisplayText
                    DisplayWatermarks
                    DrawDepthQue
                    DrawGround
                    DrawHidden
                    DrawHorizon
                    DrawLineEnds
                    DrawProfilesOnly
                    DrawSilhouettes
                    DrawUnderground
                    EdgeColorMode
                    EdgeDisplayMode
                    EdgeType
                    ExtendLines
                    FaceBackColor
                    FaceColorMode
                    FaceFrontColor
                    FogColor
                    FogEndDist
                    FogStartDist
                    FogUseBkColor
                    ForegroundColor
                    GroundColor
                    GroundTransparency
                    HideConstructionGeometry
                    HighlightColor
                    HorizonColor
                    InactiveHidden
                    InstanceHidden
                    JitterEdges
                    LineEndWidth
                    LineExtension
                    LockedColor
                    MaterialTransparency
                    ModelTransparency
                    RenderMode
                    SectionActiveColor
                    SectionCutWidth
                    SectionDefaultCutColor
                    SectionInactiveColor
                    ShowViewName
                    SilhouetteWidth
                    SkyColor
                    Texture
                    TransparencySort
                    If the differences is due to changes between SU version I hope the docs will say when they where removed instead of removing them from the manual. Good to know the history.
                    • chrisglasierC Offline
                      chrisglasier
                      Probably picked up before but I just noticed it. So just in case ...
                      Drawingelement.visible=SketchUp 6.0+
                      The visible= method is used to set the visible status for an element. This method performs an opposite function to the hidden= method.
                      Arguments:
                      visibility true if you want to hide the element, false if not
                      Returns:
                      status true if the element has been hidden, false if the element has not been hidden.
                        Dan Rathbun
                        My previous post onSketchup::AttributeDictionarieshas been REVISED See the original post:
                        http://forums.sketchucation.com/posting.php?mode=reply&f=180&t=17047#pr218516
                          Dan Rathbun
                          AttributeDictionaries (Introduction )
                          http://code.google.com/apis/sketchup/docs/ourdoc/attributedictionaries.html
                          You access this class not by performing an AttributeDictionaries.new but by grabbing a handle from an existing entity.
                          ... which is refering to Sketchup::Entity.attribute_dictionaries
                          http://code.google.com/apis/sketchup/docs/ourdoc/entity.html#attribute_dictionaries
                          @dan rathbun said:
                          http://forums.sketchucation.com/viewtopic.php?f=180&t=17047&p=208352#p208352
                          This only works for model objects (seems the model has an empty dictionary list by default.) Other entities will return nil (as they do not have an AttributeDictionaries object created until after an AttributeDictionary has been attached.); the API should note that first a script needs to create an AttributeDictionary object, before the AttributeDictionaries object can be 'grabbed' (because it does not yet exist.)
                          UPDATE (2010JAN23-DanRathbun) PC ver 7.1.6860:
                          REVISED (2010JAN28-DanRathbun):In, SU ver 7.1, IF the Dynamic Components extension is turned OFF, the entity.attribute_dictionariesmethod will appear to always return aSketchup::AttributeDictionariesobject for the entity, regardless of whether there are any memberSketchup::AttributeDictionary%(#4040BF)[objects.
                          In addition, (if DCs are OFF,) all of the methods of the]Sketchup::AttributeDictionaryclass (except.name,) will no longer work!
                          Theentity.attribute_dictionariesmethod was NOT changed in the previous release, as I thought. The method works as the API says it does, returning "nil if there are none." BUT the Dynamic Components extension must be enabled."
                          There is also no way to determine how many Dictionary objects, there are within an AttributeDictionaries collection (NoMethods: .size, .length, .count, or .empty?)
                            Dan Rathbun
                            Re: General
                            @richmorin said:
                            Class and method names could be turned into links
                            to the appropriate API page, for ease of navigation.
                            Rich, note the left Nav column. The second box labeled "Quick Reference" has exactly these Class index and Method index links.
                            Re: Array class Introduction
                            @richmorin said:
                            Specific
                            http://code.google.com/apis/sketchup/docs/ourdoc/array.html
                            > The SketchUp Array class adds ...
                            > SketchUp adds ...
                            The correct ruby term is **extends** (as in extending a base class.) The way it is currently worded, a reader might misconstrue that the class is a custom class within the Sketchup namespace (ie, Sketchup::Array ), which is NOT the case. My version would read " Sketchup extends the standard Ruby Array class with additional methods.."
                            @richmorin said:
                            (same subject... Array class Introduction)
                            > Specifically, it contains methods ...
                            > Specifically, it adds methods ...
                            The word ***add*** is better here, because it's more specific (as to the manner in which the base Array class was extended.)
                            Re: AttributeDictionaries.each
                            > ... all of the attributes dictionaries.
                            >                attribute
                            For clarity I would suggest rewording the method description as: " *The each method is used to iterate through the entire list of attribute dictionary objects*."
                            Throws an exception if there are no keys.
                            (1) What specific exception is thrown? KeyError or IndexError or a custom SU error class? (the API should state what it is we may need to trap with a rescue clause.)
                            (2) Error conditions are not documented in a uniform manner throughout the API. Sometimes they are noted in the method description paragraph; sometimes (as in this case,) as a separate paragraph of the description section; other times in the ***Returns:*** section. Perhaps it's time to add a third ***Exceptions:*** section list, where the list labels would be exception class names and the defintion text would be the reason why the exception is raised.
                            (3) Why does this method raise an exception, and the *.[]* method returns *nil* when there are no keys (or matches)? IMHO, the proper ruby way is to raise the correct exception in both cases, AND provide the *.empty?*, *.has_key?* and *.length* (or similar named) methods so scripts can use them in conditional statements when checking the Dictionary lists. Example:
                             model = Sketchup.active_model
                             attrdicts = model.attribute_dictionaries
                             if not attrdicts.empty?
                               attrdicts.each {|key,value| puts key.to_s+" is "+value.to_s }
                             else
                               puts "Dictionary List is Empty!"
                            It just seems strange, as these are Array or Hash type classes, and they didn't inherit some of the basic funtionality, that they should have. Which brings us to...
                            **(4) AttributeDictionaries.member?** is undocumented. Not that it does us any good, as it only takes an object, not a string name (returns false even for vaild dictionary names.) This means you need to know it exists in the first place, so why would we need to test it's membership? *.member?* is normally an alias for *.has_key?*, so if this method could be updated to ALSO take the dictionary string name, it would serve us well.
                            Re: AttributeDictionaries Introduction
                            This only works for [ruby:2bffgwcd]model[/ruby:2bffgwcd] objects (seems the model has an empty dictionary list by default.) Other entities will return nil (as they do not have an AttributeDictionaries object created until after an AttributeDictionary has been attached.); the API should note that first a script needs to create an AttributeDictionary object, before the AttributeDictionaries object can be 'grabbed' (because it does not yet exist.)
                            REVISED (2010JAN28-DanRathbun) See later post (this forum):
                            [url=http://forums.sketchucation.com/viewtopic.php?f=180&t=17047&p=218516#p218516:2bffgwcd]http://forums.sketchucation.com/viewtopic.php?f=180&...p218516[/url:2bffgwcd]
                            [i:2bffgwcd]Re: AttributeDictionary Introduction[/i:2bffgwcd]
                            An Entity or Model object can have any number of AttributeDictionaries.
                            [url:2bffgwcd]http://code.google.com/apis/sketchup/docs/ourdoc/attributedictionary.html[/url:2bffgwcd]
                            This is confounding the use of the two differnet class names. (The parent should have been named [i:2bffgwcd]DictionaryList[/i:2bffgwcd], or better yet, [i:2bffgwcd]AttributeLibrary[/i:2bffgwcd]. [as in: shelf space for many dictionary volumes.]) Actually each entity can have only 1 [ruby:2bffgwcd]AttributeDictionaries[/ruby:2bffgwcd] object. The sentecnce should read "[ruby:2bffgwcd]An Entity or Model object can have any number of AttributeDictionary objects[/ruby:2bffgwcd]."
                            Both AttributeDictionaries and AttributeDictionary Introductions should have an 'also see note' directing readers to Entity class methods [ruby:2bffgwcd].attribute_dictionary[/ruby:2bffgwcd] and [ruby:2bffgwcd].attribute_dictionaries[/ruby:2bffgwcd] on how to create them.
                            It would have been nice to have a [ruby:2bffgwcd]new[/ruby:2bffgwcd] method for the child dictionary objects at least. We could then call something like:
                            myEntity = Sketchup.active_model.selection[0]
                            # this is more intuitive
                            attrdict = AttributeDictionary.new("My Dictionary", myEntity)
                            # this is not so
                            attrdict = myEntity.attribute_dictionary("My Dictionary", true)
                              Layer.page_behavior
                              http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/layer.html#page_behavior
                              Only lists two flags:
                              LAYER_VISIBLE_BY_DEFAULT 0x0000,
                              LAYER_HIDDEN_BY_DEFAULT 0x0001.
                              But Layer.page_behavior= lists other constants.
                              http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/layer.html#page_behavior=
                              * LAYER_USES_DEFAULT_VISIBILITY_ON_NEW_PAGES: 0x0000,
                              * LAYER_IS_VISIBLE_ON_NEW_PAGES: 0x0010,
                              * LAYER_IS_HIDDEN_ON_NEW_PAGES: 0x0020.
                              Meaning the constants in the getter should be the same for the setter.
                              LAYER_VISIBLE_BY_DEFAULT: 0x0000 LAYER_USES_DEFAULT_VISIBILITY_ON_NEW_PAGES: 0x0000 LAYER_HIDDEN_BY_DEFAULT: 0x0001 LAYER_IS_VISIBLE_ON_NEW_PAGES: 0x0010 LAYER_IS_HIDDEN_ON_NEW_PAGES: 0x0020
                              And .page_behavior can be any bitwise combination of these.
                                To create a layer which is only visible on a single page, you can set its page behavior flags to LAYER_HIDDEN_BY_DEFAULT | LAYER_IS_HIDDEN_ON_NEW_PAGES
                                When I used that to set the behaviour of a layer on a model I get an error message when I save saying that something was messed up and this is the result of SU fixing it:
                                Results of Validity Check.
                                The behavior for CLayer (178941) is not valid - fixed
                                  Tools.pop_tool
                                  http://code.google.com/apis/sketchup/docs/ourdoc/tools.html#pop_tool
                                  Returns: tool
                                  the last pushed Tool object.
                                  I only get true or false.
                                    Dan Rathbun
                                    Sketchup::ViewObserver
                                    http://code.google.com/apis/sketchup/docs/ourdoc/viewobserver.html
                                    (Introduction Section > Code example:)
                                    # This is an example of an observer that watches tool interactions.
                                    The comment line should read:" # This is an example of an observer that watches **for changes to a view**."
                                      WebDialog
                                      http://code.google.com/apis/sketchup/docs/ourdoc/webdialog.html
                                      The Ruby WebDialog class allows you to create and interact with DHTML dialog boxes from Ruby. This is the best way to generate complex, embedded UIs inside SketchUp, but it does generally require HTML and Javascript expertise.
                                      If your goal is to simply display a website to your users, consider using UI.getURL, which will show them a web page in their default browser rather than inside a dialog in SketchUp.
                                      See this blog post for a detailed, step-by-step example: http://sketchupapi.blogspot.com/2008/02/sharing-data-between-sketchup-ruby-and.html
                                      No such thing as UI.getURL. But there is UI.openURL
                                      URL not marked up as a clickable link.
                                        Dan Rathbun
                                        UI::WebDialog
                                        Limiting the WebDialog Size and setting :resizable=false still allows MSIE window to have a working Maximize button on the captionbar. Clicking it maximizes the dialog (which should not be so.) The 'Size' option in the SystemMenu dropdown is greyed, as it should be, 'Maximize' in the menu is also active.
                                        ` opts = Hash.new
                                        other options set
                                        opts[:resizable] = false
                                        dlg=UI::WebDialog.new( opts )
                                        dlg.min_height = 100
                                        dlg.max_height = 100
                                        dlg.min_width = 200
                                        dlg.max_width = 200
                                        dlg.set_size(200,100)
                                        dlg.show`
                                        _
                                          Dan Rathbun
                                          Sketchup.load
                                          http://code.google.com/apis/sketchup/docs/ourdoc/sketchup.html#load
                                          The Sketchup.load method does NOT expose the wrap argument, so we can specify wrap=true for rbs scripts.
                                          For some unknown reason, the Google team defeated, or just didn't pass the 2nd argument (wrap) on to the aliased standard load, when they overrode it to handle rbs decrypting.
                                          Please fix this!
                                          _
                                            View.draw_points
                                            http://code.google.com/apis/sketchup/docs/ourdoc/view.html#draw_points
                                            Bug in the system: http://forums.sketchucation.com/viewtopic.php?f=180&t=26404
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 14 / 19
