    New API doc - typos and questions
    370 Posts 35 Posters 355.3k Views 35 Watching
    • Dan RathbunD
      Dan Rathbun
      Geom::Vector3d.[=]
      [="]http://code.google.com/apis/sketchup/docs/ourdoc/vector3d.html#[]=[/url]
      Again the HTML anchor may cause problems in some browsers, suggest '#subscriptEquals'
      Obviously the #[]= anchor tag in the url cannot even be displayed properly in this forum.All of the #anchor links to methods using special chars need to be changed to comply with the HTML spec, as ThomThom noted:
      ID and NAME tokens must begin with a letter ([A-Za-z]) and may be followed by any number of letters, digits ([0-9]), hyphens ("-"), underscores ("_"), colons (":"), and periods ("."). [url:nfjuel6m]http://www.w3.org/TR/html4/types.html#type-name]("http)
      Returns:
      value _______ the newly set coordinate value
      the Geom::Vector3d.[] method returns class Float
      BUT, the Geom::Vector3d.[]= method returns the class of the argument.
      The code example may be misleading to the unwary,
      value = vector[i] = coordinate
      ..if the class of the coordinate variable is Integer then the class of the value variable will also be Integer.
      This causes a coder to do a two-step expression if they want a Float, ie:
      coordinate = 2
      vector[i] = coordinate # returns Integer 2
      value = vector[i]  # value.class >> Float
      %(#FF4000)[Two Issues:
      1. Is 'coordinate' the correct term, or would 'component' be a better term when refering to vectors?1. If all the rest of the methods that return subscript values from a Vector3d object are Float, then perhaps this method should as well, regardless of the class of the argument.]
      I'm not here much anymore.
      • Dan RathbunD
        Dan Rathbun
        Geom::Point3d.<
        http://code.google.com/apis/sketchup/docs/ourdoc/point3d.html#%3C
        Returns:
        true if the point2 is closer to the origin.
        Following the example, I get the opposite result.
        TheReturns:should probably read,
        " *true* if the point2 is **farther** from the origin; *false* if the point2 is closer to the origin (than the receiver.)
          @thomthom said:
          Group.move!
          http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/group.html#move!
          .move! moves to an absolute point. Worth noting in the manual.
          It doesn't seem to though - we've been testing it in another thread this afternoon and it seem that it moves relative to the transformation-origin NOT the model's ORIGIN - you first have to do a transformation by vector from where it is to the ORIGIN and then off again to the absolute point ?
            @dan rathbun said:
            Ruby code can no longer use the nil return value in a conditional boolean statement.
            There is also no way now to determine how many Dictionary objects, there are within an AttributeDictionaries collection (No Methods: .size, .length, .count, or .empty?)
            There are no methods but several easy combos to do it...
            You make an array of it and than get its length ?
            len = AttributeDictionaries.to_a.length
            or use 'each' ?
            len = 0;AttributeDictionaries.each{|d|len += 1}
            Where len is the AttributeDictionaries length ?
              AttributeDictionaries.to_a.length works.
                ComponentInstance.explode
                http://code.google.com/apis/sketchup/docs/ourdoc/componentinstance.html#explode
                Code example is irrelevant - doesn't show the use of .explode.
                  RenderingOptions
                  http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/renderingoptions.html
                  FogColor
                  # FogDensity
                  FogEnd
                  FogStart
                  # FogType
                  FogUseBkColor
                  Bold entries returns nil.
                  The RenderingOptions I get when I iterate the collection is:
                  BackgroundColor
                  BandColor
                  ConstructionColor
                  DepthQueWidth
                  DisplayColorByLayer
                  DisplayDims
                  DisplayFog
                  DisplayInstanceAxes
                  DisplaySketchAxes
                  DisplayText
                  DisplayWatermarks
                  DrawDepthQue
                  DrawGround
                  DrawHidden
                  DrawHorizon
                  DrawLineEnds
                  DrawProfilesOnly
                  DrawSilhouettes
                  DrawUnderground
                  EdgeColorMode
                  EdgeDisplayMode
                  EdgeType
                  ExtendLines
                  FaceBackColor
                  FaceColorMode
                  FaceFrontColor
                  FogColor
                  FogEndDist
                  FogStartDist
                  FogUseBkColor
                  ForegroundColor
                  GroundColor
                  GroundTransparency
                  HideConstructionGeometry
                  HighlightColor
                  HorizonColor
                  InactiveHidden
                  InstanceHidden
                  JitterEdges
                  LineEndWidth
                  LineExtension
                  LockedColor
                  MaterialTransparency
                  ModelTransparency
                  RenderMode
                  SectionActiveColor
                  SectionCutWidth
                  SectionDefaultCutColor
                  SectionInactiveColor
                  ShowViewName
                  SilhouetteWidth
                  SkyColor
                  Texture
                  TransparencySort
                  If the differences is due to changes between SU version I hope the docs will say when they where removed instead of removing them from the manual. Good to know the history.
                  • chrisglasierC
                    chrisglasier
                    Probably picked up before but I just noticed it. So just in case ...
                    Drawingelement.visible=SketchUp 6.0+
                    The visible= method is used to set the visible status for an element. This method performs an opposite function to the hidden= method.
                    Arguments:
                    visibility true if you want to hide the element, false if not
                    Returns:
                    status true if the element has been hidden, false if the element has not been hidden.
                    • Dan RathbunD
                      Dan Rathbun
                      My previous post onSketchup::AttributeDictionarieshas been REVISED See the original post:
                      http://forums.sketchucation.com/posting.php?mode=reply&f=180&t=17047#pr218516
                      • Dan RathbunD
                        Dan Rathbun
                        AttributeDictionaries (Introduction )
                        http://code.google.com/apis/sketchup/docs/ourdoc/attributedictionaries.html
                        You access this class not by performing an AttributeDictionaries.new but by grabbing a handle from an existing entity.
                        ... which is refering to Sketchup::Entity.attribute_dictionaries
                        http://code.google.com/apis/sketchup/docs/ourdoc/entity.html#attribute_dictionaries
                        @dan rathbun said:
                        http://forums.sketchucation.com/viewtopic.php?f=180&t=17047&p=208352#p208352
                        This only works for model objects (seems the model has an empty dictionary list by default.) Other entities will return nil (as they do not have an AttributeDictionaries object created until after an AttributeDictionary has been attached.); the API should note that first a script needs to create an AttributeDictionary object, before the AttributeDictionaries object can be 'grabbed' (because it does not yet exist.)
                        UPDATE (2010JAN23-DanRathbun) PC ver 7.1.6860:
                        REVISED (2010JAN28-DanRathbun):In, SU ver 7.1, IF the Dynamic Components extension is turned OFF, the entity.attribute_dictionariesmethod will appear to always return aSketchup::AttributeDictionariesobject for the entity, regardless of whether there are any memberSketchup::AttributeDictionary%(#4040BF)[objects.
                        In addition, (if DCs are OFF,) all of the methods of the]Sketchup::AttributeDictionaryclass (except.name,) will no longer work!
                        Theentity.attribute_dictionariesmethod was NOT changed in the previous release, as I thought. The method works as the API says it does, returning "nil if there are none." BUT the Dynamic Components extension must be enabled."
                        There is also no way to determine how many Dictionary objects, there are within an AttributeDictionaries collection (NoMethods: .size, .length, .count, or .empty?)
                        • Dan RathbunD
                          Dan Rathbun
                          Re: General
                          @richmorin said:
                          Class and method names could be turned into links
                          to the appropriate API page, for ease of navigation.
                          Rich, note the left Nav column. The second box labeled "Quick Reference" has exactly these Class index and Method index links.
                          Re: Array class Introduction
                          @richmorin said:
                          Specific
                          http://code.google.com/apis/sketchup/docs/ourdoc/array.html
                          > The SketchUp Array class adds ...
                          > SketchUp adds ...
                          The correct ruby term is **extends** (as in extending a base class.) The way it is currently worded, a reader might misconstrue that the class is a custom class within the Sketchup namespace (ie, Sketchup::Array ), which is NOT the case. My version would read " Sketchup extends the standard Ruby Array class with additional methods.."
                          @richmorin said:
                          (same subject... Array class Introduction)
                          > Specifically, it contains methods ...
                          > Specifically, it adds methods ...
                          The word ***add*** is better here, because it's more specific (as to the manner in which the base Array class was extended.)
                          Re: AttributeDictionaries.each
                          > ... all of the attributes dictionaries.
                          >                attribute
                          For clarity I would suggest rewording the method description as: " *The each method is used to iterate through the entire list of attribute dictionary objects*."
                          Throws an exception if there are no keys.
                          (1) What specific exception is thrown? KeyError or IndexError or a custom SU error class? (the API should state what it is we may need to trap with a rescue clause.)
                          (2) Error conditions are not documented in a uniform manner throughout the API. Sometimes they are noted in the method description paragraph; sometimes (as in this case,) as a separate paragraph of the description section; other times in the ***Returns:*** section. Perhaps it's time to add a third ***Exceptions:*** section list, where the list labels would be exception class names and the defintion text would be the reason why the exception is raised.
                          (3) Why does this method raise an exception, and the *.[]* method returns *nil* when there are no keys (or matches)? IMHO, the proper ruby way is to raise the correct exception in both cases, AND provide the *.empty?*, *.has_key?* and *.length* (or similar named) methods so scripts can use them in conditional statements when checking the Dictionary lists. Example:
                           model = Sketchup.active_model
                           attrdicts = model.attribute_dictionaries
                           if not attrdicts.empty?
                             attrdicts.each {|key,value| puts key.to_s+" is "+value.to_s }
                           else
                             puts "Dictionary List is Empty!"
                          It just seems strange, as these are Array or Hash type classes, and they didn't inherit some of the basic funtionality, that they should have. Which brings us to...
                          **(4) AttributeDictionaries.member?** is undocumented. Not that it does us any good, as it only takes an object, not a string name (returns false even for vaild dictionary names.) This means you need to know it exists in the first place, so why would we need to test it's membership? *.member?* is normally an alias for *.has_key?*, so if this method could be updated to ALSO take the dictionary string name, it would serve us well.
                          Re: AttributeDictionaries Introduction
                          This only works for [ruby:2bffgwcd]model[/ruby:2bffgwcd] objects (seems the model has an empty dictionary list by default.) Other entities will return nil (as they do not have an AttributeDictionaries object created until after an AttributeDictionary has been attached.); the API should note that first a script needs to create an AttributeDictionary object, before the AttributeDictionaries object can be 'grabbed' (because it does not yet exist.)
                          REVISED (2010JAN28-DanRathbun) See later post (this forum):
                          [url=http://forums.sketchucation.com/viewtopic.php?f=180&t=17047&p=218516#p218516:2bffgwcd]http://forums.sketchucation.com/viewtopic.php?f=180&...p218516[/url:2bffgwcd]
                          [i:2bffgwcd]Re: AttributeDictionary Introduction[/i:2bffgwcd]
                          An Entity or Model object can have any number of AttributeDictionaries.
                          [url:2bffgwcd]http://code.google.com/apis/sketchup/docs/ourdoc/attributedictionary.html[/url:2bffgwcd]
                          This is confounding the use of the two differnet class names. (The parent should have been named [i:2bffgwcd]DictionaryList[/i:2bffgwcd], or better yet, [i:2bffgwcd]AttributeLibrary[/i:2bffgwcd]. [as in: shelf space for many dictionary volumes.]) Actually each entity can have only 1 [ruby:2bffgwcd]AttributeDictionaries[/ruby:2bffgwcd] object. The sentecnce should read "[ruby:2bffgwcd]An Entity or Model object can have any number of AttributeDictionary objects[/ruby:2bffgwcd]."
                          Both AttributeDictionaries and AttributeDictionary Introductions should have an 'also see note' directing readers to Entity class methods [ruby:2bffgwcd].attribute_dictionary[/ruby:2bffgwcd] and [ruby:2bffgwcd].attribute_dictionaries[/ruby:2bffgwcd] on how to create them.
                          It would have been nice to have a [ruby:2bffgwcd]new[/ruby:2bffgwcd] method for the child dictionary objects at least. We could then call something like:
                          myEntity = Sketchup.active_model.selection[0]
                          # this is more intuitive
                          attrdict = AttributeDictionary.new("My Dictionary", myEntity)
                          # this is not so
                          attrdict = myEntity.attribute_dictionary("My Dictionary", true)
                            Layer.page_behavior
                            http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/layer.html#page_behavior
                            Only lists two flags:
                            LAYER_VISIBLE_BY_DEFAULT 0x0000,
                            LAYER_HIDDEN_BY_DEFAULT 0x0001.
                            But Layer.page_behavior= lists other constants.
                            http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/layer.html#page_behavior=
                            * LAYER_USES_DEFAULT_VISIBILITY_ON_NEW_PAGES: 0x0000,
                            * LAYER_IS_VISIBLE_ON_NEW_PAGES: 0x0010,
                            * LAYER_IS_HIDDEN_ON_NEW_PAGES: 0x0020.
                            Meaning the constants in the getter should be the same for the setter.
                            LAYER_VISIBLE_BY_DEFAULT: 0x0000 LAYER_USES_DEFAULT_VISIBILITY_ON_NEW_PAGES: 0x0000 LAYER_HIDDEN_BY_DEFAULT: 0x0001 LAYER_IS_VISIBLE_ON_NEW_PAGES: 0x0010 LAYER_IS_HIDDEN_ON_NEW_PAGES: 0x0020
                            And .page_behavior can be any bitwise combination of these.
                              To create a layer which is only visible on a single page, you can set its page behavior flags to LAYER_HIDDEN_BY_DEFAULT | LAYER_IS_HIDDEN_ON_NEW_PAGES
                              When I used that to set the behaviour of a layer on a model I get an error message when I save saying that something was messed up and this is the result of SU fixing it:
                              Results of Validity Check.
                              The behavior for CLayer (178941) is not valid - fixed
                                Tools.pop_tool
                                http://code.google.com/apis/sketchup/docs/ourdoc/tools.html#pop_tool
                                Returns: tool
                                the last pushed Tool object.
                                I only get true or false.
                                • Dan RathbunD
                                  Dan Rathbun
                                  Sketchup::ViewObserver
                                  http://code.google.com/apis/sketchup/docs/ourdoc/viewobserver.html
                                  (Introduction Section > Code example:)
                                  # This is an example of an observer that watches tool interactions.
                                  The comment line should read:" # This is an example of an observer that watches **for changes to a view**."
                                    WebDialog
                                    http://code.google.com/apis/sketchup/docs/ourdoc/webdialog.html
                                    The Ruby WebDialog class allows you to create and interact with DHTML dialog boxes from Ruby. This is the best way to generate complex, embedded UIs inside SketchUp, but it does generally require HTML and Javascript expertise.
                                    If your goal is to simply display a website to your users, consider using UI.getURL, which will show them a web page in their default browser rather than inside a dialog in SketchUp.
                                    See this blog post for a detailed, step-by-step example: http://sketchupapi.blogspot.com/2008/02/sharing-data-between-sketchup-ruby-and.html
                                    No such thing as UI.getURL. But there is UI.openURL
                                    URL not marked up as a clickable link.
                                    • Dan RathbunD
                                      Dan Rathbun
                                      UI::WebDialog
                                      Limiting the WebDialog Size and setting :resizable=false still allows MSIE window to have a working Maximize button on the captionbar. Clicking it maximizes the dialog (which should not be so.) The 'Size' option in the SystemMenu dropdown is greyed, as it should be, 'Maximize' in the menu is also active.
                                      ` opts = Hash.new
                                      other options set
                                      opts[:resizable] = false
                                      dlg=UI::WebDialog.new( opts )
                                      dlg.min_height = 100
                                      dlg.max_height = 100
                                      dlg.min_width = 200
                                      dlg.max_width = 200
                                      dlg.set_size(200,100)
                                      dlg.show`
                                      _
                                      • Dan RathbunD
                                        Dan Rathbun
                                        Sketchup.load
                                        http://code.google.com/apis/sketchup/docs/ourdoc/sketchup.html#load
                                        The Sketchup.load method does NOT expose the wrap argument, so we can specify wrap=true for rbs scripts.
                                        For some unknown reason, the Google team defeated, or just didn't pass the 2nd argument (wrap) on to the aliased standard load, when they overrode it to handle rbs decrypting.
                                        Please fix this!
                                        _
                                          View.draw_points
                                          http://code.google.com/apis/sketchup/docs/ourdoc/view.html#draw_points
                                          Bug in the system: http://forums.sketchucation.com/viewtopic.php?f=180&t=26404
                                          • Dan RathbunD
                                            Dan Rathbun
                                            UI::WebDialog
                                            The following methods need to be documented:
                                            %(#BF0000)[last_height
                                            last_height=
                                            last_width
                                            last_width=]
                                            We are also still wishing to know what the extra Mac parameter for WebDialog.new is for, ie:
                                            :mac_only_use_nswindow = boolean
                                            What's the difference? ... and what's the default?
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 14 / 19
