    [Plugin] Layer Manager New Release
    66 Posts 34 Posters 71.0k Views 34 Watching
    • Didier BurD Offline
      Didier Bur
      Workaround:
      Open the main rb file with a texte editor,
      go to line 160
      type: layers_tb.show
      save the rb file
      the end of file must look like:
      layers_tb.add_item(cmd10)
      layers_tb.show
      # End of load
      $layer_manager_menu_loaded = true
      file_loaded("fr_layer_manager_extension_v6.rb")
      restart SU, you're done.
      DB
      • mariochaM Offline
        mariocha
        Ok, workaround works fine on my Mac.! 😄
        Now is there also one for the Main toolbar on top? Icons do not stick there either. 😛
        merci beaucoup.
        updt: I tried to find one plugin that would do it to see how it was done. But it seems like it's a real problem since not one of my plugins can keep its icons up there. Be it LightUP, Subd&Smooth, JPP, Tools-on-Surface or BezierSpline. ❓ ❓
        %(#008000)[Mario C.
        • W Offline
          watkins
          Where can I find the latest version of this plugin?
          Regards,
          Bob
            Didier Bur
            Below is a preview of next release, still at beta:
            I have split the script in 2 toolbars: 1 for the tools, 1 for the layers configs.
            Features of toolbar 1:
            Set layer of clicked object current
            Set layer of clicked object current and isolated
            Set layer of clicked object invisible
            All layers visible
            All layers invisible (except current)
            Toggle visibility of all layers
            Select/Deselect layer content
            Move selection to current layer (digs in compos and groups)
            Set layers of selection isolated (digs in compos and groups)
            Set layers of selection invisible (digs in compos and groups)
            Show layers by filter (add to visible layers)
            Isolate layers by filter (digs in compos and groups)
            Hide layers by filter (digs in compos and groups)
            Toggle display color by layer
            Match layer property of clicked object
            Create layer and control behavior
            Delete layer (digs in compos and groups)
            Lock layer
            Unlock layer
            The other toolbar should have the same features than the previous release had, more or less.
            Regards,
            DB
            • BepB Offline
              Bep
              Hello Didier,
              It would be great iff the new version of your tool also be able to pasword protect for instance a invisable/locked layer.
              Will it be?
              If not,do you think it is possible inside Sketchup?
              Thanks for all your efforts.
              Greetings,
              Bep van Malde
              "History is written by the winners"
                dedmin
                Doesn't work with cyrillic names. Seems a lot of things are like this 😉
                  what doesn't work? some functions? or the plugin as a whole?
                    dedmin
                    http://screencast.com/t/ZGU4OWNhYmI
                    • Z Offline
                      zdouk
                      @bob james said:
                      Curious problem on my Macs (work and home): The Layer Manager toolbar does not appear automatically. Each time I open SU7 I have to go to View/Tool Palettes and click on Layer Manager. Sort of a nuisance, but Layer Manager is a major player for me in SU.
                      Is this normal or do I have a problem? ❓
                      This pluggin seem magnificient however I have an issue similar to yours Bob. Except , the layer manager tool bar does not even show under the "view-->toolbars" menu. help? I do I get it to display?
                      Mazdak
                      Landscape Architect / Paysagiste
                      http://www.land8.fr
                        This type of plugin is loaded as an 'extension', so it needs to be registered before it appears in the View>Toolbars list
                        To register it [once only needed] open Window>Preferences > Extensions tab, scroll to find 'Layer Manager' and tick its box: it should them be available on the View>Toolbars list 🤓
                        • Z Offline
                          zdouk
                          Tig! you ARE the Big Cat.
                          However, it does not show there either... 👊
                          Mazdak
                          http://www.land8.fr
                            Have you loaded the many files into the right folders ?
                            The file layer_manager_extension_v6.rb is the only file that must go into the ../Plugins/ folder
                            All other files that came with the plugin [there are m_a_n_y] need to be in a sub-folder ../Plugins/Layer Manager/
                            The first rb file loads all of the others and the images for the toolbar etc that MUST be in the sub-folder.
                              monkeybss
                              This layer manager is wonderful,it makes life so much easier, at least for those used to the layer manager in Autocad!Thank you!
                              • halroachH Offline
                                halroach
                                1. I'm trying to add a keyboard shortcut for "set layer of clicked object invisible" but I cannot find the function name for it.
                                  Ideas?
                                2.In the previous version of Layer Manager, I set a short cut for that command - and all the selected lines' layers would disappear.
                                Now with the new interface I have to click on each line separately which takes a lot longer.
                                I just might install the older version... Unless there would be a way to have both methods?
                                Wonderful Plugin!!
                                FlexTools - Super Quick Windows, Doors, Slats...
                                • bagateloB Offline
                                  bagatelo
                                  Is there something like "Put selected objects on a new layer and hide this Layer" ?
                                  • Bob JamesB Offline
                                    Bob James
                                    Back in 2006 Jim Foltz wrote a plugin called add_hidden_layer.rb
                                    I searched for it but could not find it: maybe you'll have more luck
                                      matt.gordon320
                                      Hi Didier, Great job as usual! I'm just starting to use this plugin, and it's quite powerful so far. I was curious if there's any way to map keyboard shortcuts to step back and forth through the layer states that I've set up?
                                      I have Shift Left + Right to step through scenes, and I thought this would go hand in hand to create a seriously powerful workflow.
                                      Thanks again!
                                      • Clayton49C Offline
                                        Clayton49
                                        To all,
                                        I just checked again as of March 28th 2014 on my SU Pro extension warehouse & it still say's this extension was uninstalled as not compatible. I generally don't like work-arounds, so need SU HQ to validate this asap. Any news from the author in the meantime will be most appreciated. Having said that, has anyone just installed it long hand for SU Pro 2014, if so does it work..???
                                        I hope SU HQ gives this the thumbs up soon, I'm now using SU Pro 2014 & am lost without it. This extension saves loads of time & makes the SU layer manager look very dumb indeed.
                                        As a side note, I'd love SU HQ to make an update on this or extension of their own to make the layer manager manage things similar to this extension.
                                        Over & out,
                                        Clayton
                                        Over & out,
                                        Clayton.
                                        %(#008000)[Trotman & Taylor
                                        Architectural Consultants]
                                        • BoxB Offline
                                          There is an easy fix for this. I've tested it in windows and it works on this plugin. On the appropriate file, this is copied from the lines to tubes thread.
                                          @tig said:
                                          Didier needs to rework his rb file for v2014 compatibility and republish it...
                                          BUT you can do it temporarily for your own use, even though his script is 'packed'.
                                          Open the file lines2tubes.rb in Notepad, and go to the end:
                                          Change
                                          ...}.unpack("m")**.to_s**
                                          to read
                                          ...}.unpack("m")**[0]**
                                          Save the changes.
                                          Restart SketchUp.
                                          The script will then load and work in v2014 !
                                          This simple fix can be applied to any of Didier's 'packed' scripts that aren't working in v2014.
                                          These edited scripts will also load and work in earlier SketchUp versions too... 🤓
                                          Having said all that there is also a much newer Layers tool which you may find better.
                                          http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=53906
                                            BUT if it has other 'internal coding issues' [which you can't read] it might still fail in v2014 - but you would have better clue as to what's up...
                                            • 2 / 4
