    [Plugin] extrudeEdgesByLathe
    104 Posts 43 Posters 69.8k Views 43 Watching
      Blackpercula
      Thanks... 😛
        justinbae
        ITS SIMPLY AMAZING!!!!
        THANX!!!
          Here's v2.0
          http://forums.sketchucation.com/viewtopic.php?p=184477#p184477
          With v2.0 it's been renamed as 'extrudeEdgesByLathe' - it's been deBabelized and appears on a combined Toolbar - 'Extrusion Tools', plus various minor tweaks...
          • N Offline
            Nixy_janus
            thank you,i get so much help from you!
              cmoreink
              Respect TIG! 😄
              by the way, any news on a new version of EEbR?
              my portfolio
                Here's v2.1, with the ES lingvo file updated by Defisto.
                  Here's v2.2 - a typo preventing the Plugins Menu item working has been corrected. 😳
                    Here's v2.3 - FR lingvo file updated by Pilou...
                    • mitcorbM Offline
                      mitcorb
                      Feedback:
                      The Plugins Dropdown Menu commands for the extrusion suite appear to be operational with your latest revisions.
                      Thank you, again.
                      • ArcA Offline
                        Arc
                        Here is Chinese lingvo file by me from http://www.SuBlog.net
                        中文汉化包
                          Arc
                          Thank you.
                          I shall include it in the next update - meanwhile any Chinese users can download it now and unzip it into their ../Plugins/TIGtools/ folder.
                          I note you have called it 'extrudeEdgesByLatheCN.lingvo' BUT I think it should be 'extrudeEdgesByLatheZH-CN.lingvo' ?
                          I think locale for a Chinese PC is ZH-CN ?
                          If it is then the file needs renaming to suit that: otherwise the locale test won't find it and the text will default to English[US]...
                          To check this please type [or copy/paste] in the Ruby Console Sketchup.get_locale.upcase, for you it should return ZH-CN ? For me it'd be EN-US. Whatever it returns is what the 'suffix' on the file name should be...
                          Thanks for the help 🤓
                            Request
                            "A zoom extents" before the first dialog box for have all the object on the screen for an more easy answer 😄
                            (or a zoom wkindow of the generated object)
                            Maybe the same for the other EEb...
                            • ArcA Offline
                              Arc
                              @tig said:
                              Arc
                              Thank you.
                              It's not auto use extrudeEdgesByLatheZH-CN.lingvo file. I usually change the filename and overwhite extrudeEdgesByRailsEN-US.lingvo file.
                                Aha ! 💭
                                That way you can even have a EN-US locale but with Chinese text...
                                I know Pilou does that with the FR version...
                                However if you have your locale set to something other than EN-US then any lingvo file in your desired language needs to be named ScriptNameLOCALE.lingvo where LOCALE= your-locale code obtained from using Sketchup.get_locale.upcase in the Ruby Console.
                                This way you can have an EN-US locale but map your desired language lingvo files using that suffix... then you can use SUp even in Esperanto [EO] if you have a translation !
                                  Request
                                  I thought of that but as you can orbit whilst picking the curves you CAN ensure you can see everything before committing to it...
                                  One of my longer term plans is/was to add a combined web-dialog to the end so you could still orbit/pan/zoom to view the mesh and change the settings and when satisfied press OK... 🤓
                                    Here's v2.4 - FR lingvo file update by Pilou.
                                    • U Offline
                                      unclex
                                      wonderful
                                      • jeff hammondJ Offline
                                        hey Tig,
                                        here's a request for the lathe tool to tuck away for those rainy days 😄
                                        your extrusion suite has radically changed the way i model in SU as i very rarely use the followme tool anymore.. lathe pretty much fixes the multiple problems i encounter with
                                        anyway, the only problem i have with lathe.rb is when i'm trying to rotate to an approximate degree (ie - **~**74° etc.).. would it be possible to incorporate a protractor of sorts that can measure the actual angle instead of typing it in?
                                        (see attached skp for example situation)
                                        thanks!
                                        latheQ.skp
                                          As you know [sssh 😉 ] I'm looking at some other related extrusion tools and these will involve a protractor to rotate stuff with before making the shapes - so when that's working perhaps I can bolt it on to EEbyLathe 😄
                                            sweet!
                                            i do have a decent workaround for now that still gives me the accuracy i'm after so i'll just wait patiently (with fingers crossed 😄 )
                                            • 3 / 6
