    [Plugin] extrudeEdgesByLathe
    104 Posts 43 Posters 83.8k Views 43 Watching
      cmoreink
      Respect TIG! πŸ˜„
      by the way, any news on a new version of EEbR?
      my portfolio
        Here's v2.1, with the ES lingvo file updated by Defisto.
        http://forums.sketchucation.com/viewtopic.php?p=184477#p184477
          Here's v2.2 - a typo preventing the Plugins Menu item working has been corrected. 😳
            Here's v2.3 - FR lingvo file updated by Pilou...
            • mitcorbM Offline
              mitcorb
              Feedback:
              The Plugins Dropdown Menu commands for the extrusion suite appear to be operational with your latest revisions.
              Thank you, again.
              • ArcA Offline
                Arc
                Here is Chinese lingvo file by me from http://www.SuBlog.net
                δΈ­ζ–‡ζ±‰εŒ–εŒ…
                  Arc
                  Thank you.
                  I shall include it in the next update - meanwhile any Chinese users can download it now and unzip it into their ../Plugins/TIGtools/ folder.
                  I note you have called it 'extrudeEdgesByLatheCN.lingvo' BUT I think it should be 'extrudeEdgesByLatheZH-CN.lingvo' ?
                  I think locale for a Chinese PC is ZH-CN ?
                  If it is then the file needs renaming to suit that: otherwise the locale test won't find it and the text will default to English[US]...
                  To check this please type [or copy/paste] in the Ruby Console Sketchup.get_locale.upcase, for you it should return ZH-CN ? For me it'd be EN-US. Whatever it returns is what the 'suffix' on the file name should be...
                  Thanks for the help πŸ€“
                    Request
                    "A zoom extents" before the first dialog box for have all the object on the screen for an more easy answer πŸ˜„
                    (or a zoom wkindow of the generated object)
                    Maybe the same for the other EEb...
                    • ArcA Offline
                      Arc
                      @tig said:
                      Arc
                      Thank you.
                      It's not auto use extrudeEdgesByLatheZH-CN.lingvo file. I usually change the filename and overwhite extrudeEdgesByRailsEN-US.lingvo file.
                        Aha ! πŸ’­
                        That way you can even have a EN-US locale but with Chinese text...
                        I know Pilou does that with the FR version...
                        However if you have your locale set to something other than EN-US then any lingvo file in your desired language needs to be named ScriptNameLOCALE.lingvo where LOCALE= your-locale code obtained from using Sketchup.get_locale.upcase in the Ruby Console.
                        This way you can have an EN-US locale but map your desired language lingvo files using that suffix... then you can use SUp even in Esperanto [EO] if you have a translation !
                        πŸ€“
                          Request
                          I thought of that but as you can orbit whilst picking the curves you CAN ensure you can see everything before committing to it...
                          One of my longer term plans is/was to add a combined web-dialog to the end so you could still orbit/pan/zoom to view the mesh and change the settings and when satisfied press OK... πŸ€“
                            Here's v2.4 - FR lingvo file update by Pilou.
                            • U Offline
                              unclex
                              wonderful
                              • jeff hammondJ Offline
                                hey Tig,
                                here's a request for the lathe tool to tuck away for those rainy days πŸ˜„
                                your extrusion suite has radically changed the way i model in SU as i very rarely use the followme tool anymore.. lathe pretty much fixes the multiple problems i encounter with
                                anyway, the only problem i have with lathe.rb is when i'm trying to rotate to an approximate degree (ie - **~**74Β° etc.).. would it be possible to incorporate a protractor of sorts that can measure the actual angle instead of typing it in?
                                (see attached skp for example situation)
                                thanks!
                                latheQ.skp
                                  As you know [sssh πŸ˜‰ ] I'm looking at some other related extrusion tools and these will involve a protractor to rotate stuff with before making the shapes - so when that's working perhaps I can bolt it on to EEbyLathe πŸ˜„
                                    sweet!
                                    i do have a decent workaround for now that still gives me the accuracy i'm after so i'll just wait patiently (with fingers crossed πŸ˜„ )
                                      balloon
                                      Thank you Tig! Much appreciated!!!
                                        New version added http://forums.sketchucation.com/viewtopic.php?p=184477#p184477
                                          DIEGO-RODRIGUEZ
                                          Hi Tig. excellent update.
                                          I attach the file to Spanish translation.
                                          add the missing lines.
                                          Two suggestions:
                                          • Please delete the sound it makes when we choose the tool. is very annoying.
                                          • The command Ctrl + z does not work properly.
                                          • Would be more practical angle by reference to generate 0 to 360. instead of 0 to 180 and 180 to 360
                                          extrudeEdgesByLatheES.rar
                                            http://forums.sketchucation.com/viewtopic.php?p=184477#p184477 is the latest version with new lingvos.
                                            • 4 / 6
