    [Plugin] extrudeEdgesByLathe
    104 Posts 43 Posters 85.5k Views 43 Watching
      Arc
      Thank you.
      I shall include it in the next update - meanwhile any Chinese users can download it now and unzip it into their ../Plugins/TIGtools/ folder.
      I note you have called it 'extrudeEdgesByLatheCN.lingvo' BUT I think it should be 'extrudeEdgesByLatheZH-CN.lingvo' ?
      I think locale for a Chinese PC is ZH-CN ?
      If it is then the file needs renaming to suit that: otherwise the locale test won't find it and the text will default to English[US]...
      To check this please type [or copy/paste] in the Ruby Console Sketchup.get_locale.upcase, for you it should return ZH-CN ? For me it'd be EN-US. Whatever it returns is what the 'suffix' on the file name should be...
      Thanks for the help πŸ€“
        Request
        "A zoom extents" before the first dialog box for have all the object on the screen for an more easy answer πŸ˜„
        (or a zoom wkindow of the generated object)
        Maybe the same for the other EEb...
        • ArcA
          Arc
          @tig said:
          Arc
          Thank you.
          It's not auto use extrudeEdgesByLatheZH-CN.lingvo file. I usually change the filename and overwhite extrudeEdgesByRailsEN-US.lingvo file.
            Aha ! πŸ’­
            That way you can even have a EN-US locale but with Chinese text...
            I know Pilou does that with the FR version...
            However if you have your locale set to something other than EN-US then any lingvo file in your desired language needs to be named ScriptNameLOCALE.lingvo where LOCALE= your-locale code obtained from using Sketchup.get_locale.upcase in the Ruby Console.
            This way you can have an EN-US locale but map your desired language lingvo files using that suffix... then you can use SUp even in Esperanto [EO] if you have a translation !
            πŸ€“
              Request
              I thought of that but as you can orbit whilst picking the curves you CAN ensure you can see everything before committing to it...
              One of my longer term plans is/was to add a combined web-dialog to the end so you could still orbit/pan/zoom to view the mesh and change the settings and when satisfied press OK... πŸ€“
                Here's v2.4 - FR lingvo file update by Pilou.
                http://forums.sketchucation.com/viewtopic.php?p=184477#p184477
                • U
                  unclex
                  wonderful
                  • jeff hammondJ
                    hey Tig,
                    here's a request for the lathe tool to tuck away for those rainy days πŸ˜„
                    your extrusion suite has radically changed the way i model in SU as i very rarely use the followme tool anymore.. lathe pretty much fixes the multiple problems i encounter with
                    anyway, the only problem i have with lathe.rb is when i'm trying to rotate to an approximate degree (ie - **~**74Β° etc.).. would it be possible to incorporate a protractor of sorts that can measure the actual angle instead of typing it in?
                    (see attached skp for example situation)
                    thanks!
                    latheQ.skp
                      As you know [sssh πŸ˜‰ ] I'm looking at some other related extrusion tools and these will involve a protractor to rotate stuff with before making the shapes - so when that's working perhaps I can bolt it on to EEbyLathe πŸ˜„
                      • jeff hammondJ
                        sweet!
                        i do have a decent workaround for now that still gives me the accuracy i'm after so i'll just wait patiently (with fingers crossed πŸ˜„ )
                        • B
                          balloon
                          Thank you Tig! Much appreciated!!!
                            New version added http://forums.sketchucation.com/viewtopic.php?p=184477#p184477
                              DIEGO-RODRIGUEZ
                              Hi Tig. excellent update.
                              I attach the file to Spanish translation.
                              add the missing lines.
                              Two suggestions:
                              • Please delete the sound it makes when we choose the tool. is very annoying.
                              • The command Ctrl + z does not work properly.
                              • Would be more practical angle by reference to generate 0 to 360. instead of 0 to 180 and 180 to 360
                              extrudeEdgesByLatheES.rar
                                http://forums.sketchucation.com/viewtopic.php?p=184477#p184477 is the latest version with new lingvos.
                                  Two suggestions:
                                  I posted the new ES lingvo file before I read this - can you please read it and [re]advise...
                                  The 'beep' sound it makes is a UI.beep - edit the file and find that line in the code and add a # at the start of the line to stop it loading.
                                  It is not Ctrl+Z for the angle-direction 'toggle' - it's < Ctrl> alone...
                                  I know it would be better to have 0 to 360 degrees... BUT its coding has missed me so far - hence the 0-180 & 180-360, with a toggle <Alt>...
                                    I didn't read the 6 pages prior so if this is already covered I apologise...
                                    Attached is a .skp that Lathe removes faces from when 'Remove Co-Planar edges is chosen?
                                    No Ruby Console messages
                                    EebyL_Error.skp
                                      Interestingly, when I tested it I got 6+ more facets erased!
                                      I know why it's happening...
                                      When you test for coplanar-ness you look at the face normals.
                                      You erase edges that bound a pair of faces with the same normals.
                                      However, it was realized by @last/Google that this doesn't always work...
                                      You can have two faces that will heal into one if there common edge is erased BUT they won't return the same normal ! The tiniest variation in the normal would prevent that...
                                      It's all down to tolerances of how SUp works out face normals etc that are really 'equal'...
                                      In Line#755 it says ... e.faces[0].normal.dot(e.faces[1].normal) > 0.99999999999 - i.e. it's almost one!
                                      If I add/subtract an extra 9 on the end it's even worse??
                                      My own separate 'erase_coplanar_edges' tool uses 0.99999999 and that fails too... but with only two faces lost that time! But if I try to use its 0.9999999 test in EEbyLathe it'll still knack up...
                                      So... it's not an error just one of the limitations of the tolerances that crop up when you have managed just to get some 'not quite' coplanar faces and try to remove some 'not quite' coplanar edges...
                                      If it knacks up then all you can do is to undo it one step back to keep coplanar edges - try other coplanar fixing tools and report back... OR just learn to love them... otherwise try to make forms that don't mess with SUp's head πŸ˜’
                                        There is a minor correction to this tool so the 'db' translation for the 'start_operation' is now done correctly - there is also an updated ES lingvo file - thanks to deFisto...
                                          No file attached πŸ˜•
                                          It's relatively simple to select all and smooth/unsmooth.
                                          Use Hidden Geometry ON to see what's happening
                                          It's also relatively simple to do it to a selection.
                                          You can also use a selection of edges and Entity Info to uncheck smooth/soft [and hidden] settings for edges.
                                          The tool produces smoothed-edges if desired.
                                          I'm not sure what you are trying to do that it doesn't do OR what isn't easy to do by hand later ???
                                          • pbacotP
                                            The file is attached. I see it there. I reloaded and perhaps you viewed in the moment that I did that.
                                            The edges I need to smooth are many and selection would need to be almost one by one, to not get the wrong edges. If this is best way, so be it. If I create many versions of this model, I want to be more efficient if I can.
                                            Also I should say, look at both scenes.
                                            Thanks, Peter
                                            • 4 / 6
